Neste Gen skjermkort Nvidia (gtx 700)
For å si det slik: Take my money:
ASUS ROG SWIFT PG278Q, delivering 1440p at 120Hz with NVIDIA G-Sync
We have a 1ms response time, mixed with G-Sync, ASUS' GamePlus, which is an OSD overlay, a single DisplayPort 1.2 port, dual USB 3.09 ports and VESA wall mount capabilities. It also comes with a 6mm bezel
Read more at
http://www.tweaktown.com/news/34693/asus-rog-swift-pg278q-delivering-1440p-at-120hz-with-nvidia-g-sync/index.html#Ijzi0EVARq3IMJeB.99
Asus says of the decision to use a TN panel, "Not all TN’s are made the same: the premium panel used in the PG278Q is of very high quality. IPS panels (and their derivatives like PVA/MVA etc) are not suitable for a multitude of reasons: 1) the response rate is simply not fast enough to react to the active change in refresh rate and 2) They cannot reliably achieve >60Hz without significantly affecting the quality of the image. IGZO technology (and LTPS – low temperature polysilicon – likewise) – yields 100′s of times faster electron mobility versus standard amorphous silicon panels – and thus can provide a response rate comparable to TN (up to 60Hz currently), but, however desirable this technology is, it is still currently cost prohibitively for many PC gaming enthusiasts in 2014, which is why ROG has used a better price:performance, high quality TN panel."
Endret av Nizzen
Read more at
Asus says of the decision to use a TN panel, "Not all TNs are made the same: the premium panel used in the PG278Q is of very high quality. IPS panels (and their derivatives like PVA/MVA etc) are not suitable for a multitude of reasons: 1) the response rate is simply not fast enough to react to the active change in refresh rate and 2) They cannot reliably achieve >60Hz without significantly affecting the quality of the image. IGZO technology (and LTPS low temperature polysilicon likewise) yields 100′s of times faster electron mobility versus standard amorphous silicon panels and thus can provide a response rate comparable to TN (up to 60Hz currently), but, however desirable this technology is, it is still currently cost prohibitively for many PC gaming enthusiasts in 2014, which is why ROG has used a better price:performance, high quality TN panel."
pris? rundt 6000?
Du får ikke kjøpt "overklokkbare" i norske butikker, så nei.
Det var KUN en versjon av EN skjerm i korea som helt tilfeldig viste seg at kunne overklokkes. Etter et års tid så klarte de å komme opp med noen nye skjermer med den samme elektronikken, men da fortsatt i form av lokale korea-monitorer.
Ps: Grunnen til man brydde seg om dette, var fordi (det per dags dato) er eneste måten å få høy oppfriskningsrate kombinert med IPS-panel og 1440p.
Din skjerm er jo verken, og ser ikke noe poeng å overklokke en slik skjerm. Da kan man jo først som sist bare kjøpe en vanlig 120/144 Hz TN-skjerm med 1080p som har eksistert lenge.
Det har faktisk vært eneste måten å få 120 Hz 2560x1440 uavhenging av panel-type :)
De fleste skjermer kan overklokkes. F.eks Asus 27" LED PB278Q jan overklokkes til ca 85 hz. Litt lotteri som overklokking ellers om hvor heldig man er.
Hmm, jeg har ikke hørt det har gått med mer enn 4-5 Hz, så det var nytt for meg. :)
Sant nok. :)
