Mr. Hermonella Skrevet 8. mai 2013 Del Skrevet 8. mai 2013 Heisann:) Tenkte og skaffe meg en Rasberry Pie for Bitcoin Mining også lurer jeg på hvor jeg kan skaffe det billigst mulig? Hva trenger jeg av utstyr? Er det noe mer jeg burte tenke på? Lenke til kommentar https://www.diskusjon.no/topic/1512774-rasberry-pie-billigst-mulig/
Twinflower Skrevet 8. mai 2013 Del Skrevet 8. mai 2013 (endret) 1: Det er Raspberry Pi (3.14) 2: Du klarer ikke å mine en femtiøring med en rasberry. edit: http://bitcoin.org/en/you-need-to-know Bitcoins' date=' like gold, are beholden to no government; they can’t be printed by any central bank, and they certainly won’t be subject to hyperinflation, since the global supply of bitcoins will never exceed 21 million. Like gold, bitcoins are mined; but unlike gold, no one can stumble over some large seam and make a fortune. Mining for bitcoins involves an enormous amount of computer power, and very little luck, and the global rate at which new bitcoins will be mined is both predetermined and slowing down. There were about 3 million coins outstanding at the beginning of 2010, there are about 11 million coins outstanding today, and we’ll get to 14 million in early 2014. Come 2021 or so, assuming bitcoins are still used then, the rate of growth of bitcoins will be so low that to a first approximation the money supply will be constant [/quote'] Endret 8. mai 2013 av Twinflower Lenke til kommentar https://www.diskusjon.no/topic/1512774-rasberry-pie-billigst-mulig/#findComment-20514858
mobile999 Skrevet 8. mai 2013 Del Skrevet 8. mai 2013 Raspberry Lenke til kommentar https://www.diskusjon.no/topic/1512774-rasberry-pie-billigst-mulig/#findComment-20515141
