Vil at dette programmet skal skrive ut 5 heltall med 3 spaces i mellomrom. Noen som kan hjelpe?
// Five.java
// Program breaks apart a five-digit number
// Java extension package
import javax.swing.JOptionPane;
public class Five {
public static void main( String args[] )
int orginalNumber;
int number;
String inputString;
// read five-digit number from user as a String
inputString = JOptionPane.showInputDialog(
"Enter five digit integer:" );
// converts inputString to an integer and assigns it to number
orginalNumber = Integer.parseInt( inputString );
// determine the 5 digits
int digit1, digit2, digit3, digit4, digit5;
digit1 = orginalNumber / 10000;
number = orginalNumber % 10000;
digit2 = orginalNumber / 1000;
number = orginalNumber % 1000;
digit3 = orginalNumber / 100;
number = orginalNumber % 100;
digit4 = orginalNumber / 10;
number = orginalNumber % 10;
digit5 = orginalNumber / 1;
number = orginalNumber % 1;
String result;
result = digit1 + ("");
result = digit2 + ("");
result = digit3 + ("");
result = digit4 + ("");
result = digit5 + ("");
// display results
JOptionPane.showMessageDialog( null, result,
"Digits in " + orginalNumber, JOptionPane.INFORMATION_MESSAGE );
System.exit( 0 );
} // end class Five
