Multikort USB Mass Storage leser - Hvordan mounter jeg?
kyrsjo
Kjøpt en multikort kortleser (i Tyskland) som leser SM, CF, Memory Stick, MMC pg SD. Det står at den er Mass Storage kompatibel. Når jeg skulle lese bildene mine fra SmartMedia kortet mitt, fikk jeg ikke mountet den, den kom bare med dette:
[root@localhost root]# mount -t vfat /dev/sda /mnt/cam/
mount: wrong fs type, bad option, bad superblock on /dev/sda,
      or too many mounted file systems
[root@localhost root]# mount -t vfat /dev/sda1 /mnt/cam/
mount: /dev/sda1 is not a valid block device
Har tidligere mountet kameraet mitt (også USB Mass storage) fra /dev/sda1til /mnt/cam, det er ikke noe problemer.
Dette er hva jeg får på dmesg ved innkopling
hub.c: new USB device 00:1d.1-1, assigned address 8
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 8
sda : READ CAPACITY failed.
sda : status = 1, message = 00, host = 0, driver = 08
Info fld=0xa00 (nonstd), Current sd00:00: sense key Not Ready
sda : block size assumed to be 512 bytes, disk size 1GB.
sda: test WP failed, assume Write Enabled
sda: I/O error: dev 08:00, sector 0
unable to read partition table
Device not ready.  Make sure there is a disc in the drive.
sdb : READ CAPACITY failed.
sdb : status = 1, message = 00, host = 0, driver = 08
Info fld=0x0, Current sd00:00: sense key Not Ready
Additional sense indicates Medium not present
sdb : block size assumed to be 512 bytes, disk size 1GB.
sdb: Write Protect is off
sdb: I/O error: dev 08:10, sector 0
og ved utkopling:
usb.c: USB disconnect on device 00:1d.1-1 address 8
sdb: test WP failed, assume Write Enabled
Kortet disse testene ble gjort på var et 16 MB SmartMedia kort.
Har prøvd å mounte sda 1-8, sda(1)-sde(1), osv. Har søkt på google.
cat /proc/scsi/scsi:
[root@localhost root]# cat /proc/scsi/scsi
Attached devices:
Host: scsi0 Channel: 00 Id: 00 Lun: 00
 Vendor: Fujifilm Model: FinePix 1400Zoom Rev: 1000
 Type:   Direct-Access                    ANSI SCSI revision: 02
Host: scsi1 Channel: 00 Id: 00 Lun: 00
 Vendor: GENERIC  Model: Card Reader   CF Rev: v26F
(ja, kameraet var montert, men prøvde og å mounte den før kameraet ble plugget inn - men hvorfor blir ikke en utplugget device fjernet???)
Hadde vært digg med å plugge inn - virker momentant á la Mac OS X / Win XP. Men noe må man jo ofre?!?!? Ikke så veldig stort problem - kameraet står i FSTAB. Har USB 1 på alt.
Får fire disker i windows.
Noen må da vite, i alle fall svaret på noen av spørsmålene! Noen som har noen gode ideer til hvordan man kan få til automounting?
Tror den skal funke på Mac OSX, noen som vet hvilke filer jeg bør lese der etter mounting, som kan gi meg et tips om hvordan gjøre det på Linux?
Noen her på forumet må da ha gjort dette før...
Og ikke kom her og si at jeg ikke har gitt nok info!!
Før noe blir satt inn:
cat: /proc/scsi/scsi: No such file or directory
Setter inn (med 32 MB smart-media)
hub.c: new USB device 00:1d.1-1, assigned address 2
usb.c: USB device 2 (vend/prod 0x3538/0x15) is not claimed by any active driver.SCSI subsystem driver Revision: 1.00
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
scsi0 : SCSI emulation for USB Mass Storage devices
USB Mass Storage device found at 2
USB Mass Storage support registered.
Prøver å mounte:
[root@localhost root]# mount -t vfat /dev/sda2 /mnt/cam
mount: /dev/sda2 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sda3 /mnt/cam
mount: /dev/sda3 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sda4 /mnt/cam
mount: /dev/sda4 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sda5 /mnt/cam
mount: /dev/sda5 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sda6 /mnt/cam
mount: /dev/sda6 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sda7 /mnt/cam
mount: /dev/sda7 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sda8 /mnt/cam
mount: /dev/sda8 is not a valid block device
Nope.
Scsi - "fila":
Attached devices:
Tester litt til på mounting:
[root@localhost root]# mount -t vfat /dev/sdb1 /mnt/cam
mount: /dev/sdb1 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb2 /mnt/cam
mount: /dev/sdb2 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb3 /mnt/cam
mount: /dev/sdb3 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb4 /mnt/cam
mount: /dev/sdb4 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb5 /mnt/cam
mount: /dev/sdb5 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb6 /mnt/cam
mount: /dev/sdb6 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb7 /mnt/cam
mount: /dev/sdb7 is not a valid block device
[root@localhost root]# mount -t vfat /dev/sdb8 /mnt/cam
mount: /dev/sdb8 is not a valid block device
Trekker ut kontakten:
usb.c: USB disconnect on device 00:1d.1-1 address 2
Scsi fila:
Attached devices:
Det var vel det...
