Testing av Power Color 9800Pro?
Komplett har et (tilsynelatende) godt tilbud i sitt PC 9800PRO kort (PowerColor Radeon 9800 PRO 128MB DDR
AGP, ATI 9800PRO, DVI-I, TV-Out, Retail).
Det er mange spekulasjoner rettet mot denne produsenten generelt og kortet spesielt (noen plasser litt overklokket nadre underklokket).
Hadde vært int. om HW hadde testet dette kortet (eller andre på forumet?).
Vet det finnes mange tester om dette, men misteker at det finnes to "typer" på markedet... greit å vite hvilket komplett selger
Link: http://www.komplett.no/k/ki.asp?action=inf...24&GrpID=1&s=pl
Fra PC's hjemmeside:
Model
Chipset
- RADEON 9800PRO
Support Memory/bandwidth
- 128MB DDR SDRAM
- 256 bit
Connectors
- VGA
- TV-out (S-Video connector)
- DVI Connector
RADEON 9800 Chipset Features
Cinematic Rendering
- Up to 256MB of DDR memory provides increased performance when rendering high resolution textures, characters, and environments
- 256-bit memory interface delivers the bandwidth for real-time 3D graphics and barrier-free performance
- 8-pixel pipeline architecture doubles the rendering power of other graphics processors
Maximum 3D
- SMARTSHADER 2.1 supports the latest Microsoft DirectX9.0 feature set, enabling cinematic quality lighting and shadow effects.
- SMOOTHVISION 2.1 delivers the sharpest, clearest textures without sacrificing frame rates.
- 128-bit full floating point precision enables billions of color variations to render the same lighting and effects as Hollywood studios.
- Featuring CATALYST the industry's most stable 3D acceleration software.
Generation Now Technology
- Supports the latest Microsoft DirectX9.0 and OpenGL feature sets, ensuring long-term compatibility with the hottest gaming releases.
- FULLSTREAM removes blocky artifacts from streaming Internet video to deliver smoother looking, higher quality online content.
- VIDEOSHADER integrates features to provide unprecedented support for digital and high definition video.
Sier ikke noe om core/mem clock!
Our PowerColor 9800 Pro video card was shipped with an oddity that hasn’t happened much around the bunker lately. The card was shipped severely underclocked. Default ATI 9800 Pro video card speeds are 380Mhz core and 340Mhz memory. The PowerColor 9800 Pro we received was clocked at 324Mhz core and 290Mhz memory
Kilde: http://www.hardocp.com/article.html?art=NDgzLDI=
Wow. Here's the first board which has a bit different specifications. Apparently PowerColor didn't think that ATi's reference core speed of 380 Mhz was enough, instead they opted for 400 MHz. They even clocked the memory higher, 760 MHz instead of 680. Not bad! This is the type of thing that we'd like to see more often.
Kilde: http://www.nordichardware.com/reviews/grap.../index.php?ez=7
The PowerColor Radeon 9800 PRO is designed around ATi's R350 chip, making it a representative of the high-end class of cards. The card that was sent to us for testing is equipped with a memory module from Hynix, which is specified for a maximum speed of 900-MHz DDR! The card is clocked to 398 MHz core and 756 MHz memory clock (reference: 380/680). But be warned: other tests of the card in the Internet show that PowerColor also equips the card with slower memory modules, and the card does not clock any higher. So look carefully before you buy.
Kilde: http://www.tomshardware.com/graphic/200307...radeon_9800_pro
Kan man nå se hvorfor det hadde vært int. med test av PC9800pro som selges på norske web shops?
Poenget er at det er forskjelig minne på PC modellene ....
... som om de har to "typer"; et litt overklokket og et litt underklokket.
De har gjort dette med 9600pro og, men har da navn på de: EZ @ 400/400 Bravo @ 400/600 /ati std.)
Står kun en moidell av 9800pro 128MB på deres hjemmesider.
Kortet koster under 3000 på komplett. ... aner ugler i mosen.
Ser på Tomshardware at stock er 398/756 PowerColor Radeon 9800pro clocke rate .Ser at viften er på 47,5dB :o kan det være rett?Det er jo ikke så langt unna dB`en til en Delta vifte.
Vet ikke om det er noe forskjell, er jo samme gpu, men 256 mb utgave av kortet du har lagt link til ihvertfall.
:oops: Så ikke at det var 256mb versjonene,men allikavel da 47,5dB det er ganske mye det :yes:
