Kjell Magne Skrevet 28. april 2013 Del Skrevet 28. april 2013 Hei! Lurer på om disse delene vil fungere bra til server jeg skal bygge? Er prosessoren sterk nok? Leste at FreeNAS krever mye minne, er 8 GB nok med 2 brukere? Trenger også tips til kabling av nettverk. Får inn Telenor fiber med TV til høsten. LC Power Miditower 7027B Sort med 420W strømforsyning MSI H61M-P22 (G3) Socket-1155 m-ATX, H61, DDR3, 3xG3-PCIe,VGA, DVI Intel Celeron G540 2,5Ghz Socket 1155 2MB, BOXED m/vifte Kingston HyperX 8GB 1333MHz DDR3 Black 2x4GB, Non-ECC CL9 XMP Seagate Barracuda® Green 1TB, 3,5" SATA 6Gb/s, (SATA 3.0), 32MB, 5900 RPM Lenke til kommentar
dbass Skrevet 29. april 2013 Del Skrevet 29. april 2013 (endret) Jeg vil regne med at du ikke trenger så veldig mye CPU. Når det gjelder RAM står det følgende: RAM The best way to get the most out of your FreeNAS® system is to install as much RAM as possible. If your RAM is limited, consider using UFS until you can afford better hardware. ZFS typically requires a minimum of 8 GB of RAM in order to provide good performance. The more RAM, the better the performance, and the FreeNAS® Forums provide anecdotal evidence from users on how much performance is gained by adding more RAM. For systems with large disk capacity (greater than 6 TB), a general rule of thumb is 1 GB of RAM for every 1TB of storage. This post describes how RAM is used by ZFS. NOTE: by default, ZFS disables pre-fetching (caching) for systems containing less than 4 GB of usable RAM. Not using pre-fetching can greatly reduce performance. 4 GB of usable RAM is not the same thing as 4 GB installed RAM as the operating system resides in RAM. This means that the practical pre-fetching threshold is 6 GB, or 8 GB of installed RAM. You can still use ZFS with less RAM, but performance will be affected. If you plan to use ZFS deduplication, a general rule of thumb is 5 GB RAM per TB of storage to be deduplicated. If you use Active Directory with FreeNAS®, add an additional 2 GB of RAM for winbind's internal cache. If you are installing FreeNAS® on a headless system, disable the shared memory settings for the video card in the BIOS. http://doc.freenas.o...Recommendations Endret 29. april 2013 av dbass Lenke til kommentar
kometenk Skrevet 29. april 2013 Del Skrevet 29. april 2013 Kan jeg få spørre om hva freeNAS er? Lenke til kommentar
Mr D Skrevet 29. april 2013 Del Skrevet 29. april 2013 (endret) Kan jeg få spørre om hva freeNAS er? Open source NAS (network attached storage) software.http://www.freenas.org/ Endret 29. april 2013 av Mr D 1 Lenke til kommentar
kometenk Skrevet 29. april 2013 Del Skrevet 29. april 2013 Open source NAS (network attached storage) software. http://www.freenas.org/ Takk for svar! Lenke til kommentar
Kjell Magne Skrevet 29. april 2013 Forfatter Del Skrevet 29. april 2013 (endret) Takk for svar. Ser ut som 8 gb blir helt på grensen, spesielt hvis jeg skal utvide med flere disker. Hvordan bør jeg gå fram når jeg skal kable til rom der jeg må ha flere uttak? Telenor sa jeg måtte ha CAT 6 kabel. Hvilken switch/router bør jeg velge når jeg skal gå fra modem til sovereom og derfra til stue? Telenor ville helst ha egen kabel fra tuner direkte til modem. Endret 29. april 2013 av Kjell Magne Lenke til kommentar
dbass Skrevet 29. april 2013 Del Skrevet 29. april 2013 Fra modem til Router, og fra router til evt. switcher inn i neste rom. Hvilke ytelse er det du er ute etter? CAT6 støtter 10Gbit, men da må du ha utstyr som støtter det også, noe som er dyrt. CAT5e støtter 1Gbit, og trenger du mer enn 122MB/s ville jeg vurdert å kjøpe 10Gbit switcher og routere, men husk at det er svindyrt Lenke til kommentar
