Ipaq 5550 vs. 5555
Vizio
Har bestilt meg en HP Ipaq 5550, men så kom jeg til å lure på.. hva er forskjellen mellom den og 5555 versjonen?
btw. gleder jeg dyrisk til den kommer :lol:
Jeg er ikke sikker, men fant ut dette ved å søke på Google i 2 sekunder (som du også kunne gjort før du spurte):
Fra http://www.bargainpda.com/default.asp?newsID=1571:
Note: This is a review of both the iPaq 5550 and 5555, which are essentially the same unit, and differ only in software bundle, location of sale, internal tracking, or insert-HP-story-of-the-week-here. Truthfully, nobody is really sure what's different about them, and that seems to include HP customer service reps. So in other words, don't worry about about which to buy. The model number isn't even marked on the case, so what does it matter?
Fra http://www.pdabuyersguide.com/ipaq5555.htm:
They're the same. HP uses two different numbers: one for corporate channel sales (5550) and 5555 for retail sales channels. There may be some small variations in software bundles, but most all bonus 3rd party apps should be the same.
Virker som om begge er enig om at hardware'en er nøyaktig det samme, og at den eneste merkbare forksjellen er hvilken software som følger med.
