Dette gjør meg syk! (modem warning)
b-real
Må nå si dette er noe av det bøseste jeg vet om...
http://www.fast-autos.net/lingenfelter/lin...elter427tt.html
Engine
Type: Twin-Turbo V8
Displacement: 7007 cc
Horsepower: 802 bhp @ 4600 rpm
Torque: 866 lb-ft @ 3600 rpm
Redline: 6500 rpm
Performance
0-60 mph: 1.97 sec
0-100 mph: 4.33 sec
Quarter Mile: 8.95 sec @ 153 mph
Skidpad: 1.01g
Top Speed: est 240 mph
ganske koslig den bilen der ja ^^
240*1,8=432
ca 432km/t er jo ikke så galt da... :roll:
F1 360 02 NOVITEC SUPERSPORT Bi-compressor
including 2 supercharger with modified turbine-blades and separated oil-circuit,
modified induction tract complete heat-insulated, watercooled intercoolers with
additional watercoolers, pumps, reinforced v-ripped belts with dynamic belt-
tensioners, injectors, modified motronic in combination with NOVITEC- tectronic and Carbon
airfilter-housing.
performance: 446 kw (606 hp) / 8.600 rpm
max. boost-pressure: 0,61 bar
max. torque: 615 Nm / 6.250 rpm
Vmax: 344 km/h (in combination with NOVITEC gear-ratio)
0 - 100 km/h: 3,7 sec
Enhver hadde blitt syk (bilsyk) av en sånn en.
Den pheteste bilen jeg finner er denne:
se felgene
ferarri kan gå bak en busk å skamme seg i forhold til dette intriøret
Se motoren
skulle ønske jeg hadde dame med slik rumpe
Litt spes:
Number of cylinders 16
Displacement 7,993 cc
Power output 736 kW (1001 bhp) at 6,000 rpm
Torque 1,250 Nm from 2,200 - 5,500 rpm
Top speed 406 km/h
Acceleration 0 - 300 km/h under 14.0 seconds
1001 Hestekrefter
8 L
