Lager et tic tac toe program i c++.
Programmet er 1 player. Dvs at computeren tar et random move ved sin tur, gitt ved:
srand(1);
position = rand() % 8; // tilfeldig nummer mellom 0 og 8
Jeg har 9 arrays som representerer de 9 felt i tic-tac-toe. Nummer 0-8.
Hvis jeg tester programmet, og hvis jeg f.eks taster inn 0 og deretter 2. Da vil programmet ende opp i en uendelig loop. Hva er grunnen til det? Her er programmet mitt.
#include <string>
#include <iostream>
#include <cstdlib>
using namespace std;
string displayBoard(string board[9]);   // displays tic tac toe board
bool isGameOver(string board[9]);	   // checks if game is over
void displayGameWelcome();			  // displays welcome message
// Credits
// http://www.codingmix.com/2010/07/simples-cplusplus-tic-tac-toe-game-ever_24.html
int main()
  string board[9];		  // tic tac toe, top row 0 thru 2, middle row 3 thru 5, bottom row 6 thru 8
  int position = 0;		 // player's position
  bool gameOver = false;	// flag variable to mark end of the game
  bool validMove = false;   // determines if move is valid or not
  // initializing board with blank spaces
  for (int i = 0; i < 9; i++)
  board[i] = " ";
  while (!gameOver)
  // player #1's turn **************************
  validMove = false;
  while (!validMove)
	 cout << "Enter your position: ";
	 cin >> position;
	 if (position >= 0 && position <= 8 && board[position] == " ")
		validMove = true;
		board[position] = "x";  // placing x in desired board location
	 else if (position >= 0 && position <= 8 && board[position] != " ")
		cout << "That position is already occupied." << endl;
		cout << displayBoard(board) << endl;
  else
cout << "Invalid number" << endl;
  if (isGameOver(board))
	 gameOver = true;
  continue;
  // player #2's turn **********************************
  validMove = false;
  while (!validMove)
	 srand(1);
  if (board[0] == "x" && board[1] == "x")
position = 2;
  else if (board[3] == "x" && board[4] == "x")
position = 5;
  else if (board[6] == "x" && board[7] == "x")
position = 8;
  else if (board[0] == "x" && board[4] == "x" )
position = 8;
  else if (board[2] == "x" && board[4] == "x")
position = 6;
  else if (board[0] == "x" && board[3] == "x")
position = 6;
  else if (board[1] == "x" && board[4] == "x")
position = 7;
  else if (board[2] == "x" && board[5] == "x")
position = 8;
		validMove = true;
		board[position] = "o";  // placing o in desired board position
  else
	 gameOver = true;
  }// end of validMove while loop
  system("pause");
  return 0;
}// end of main
// ************************** functions *************************
cout << "WELCOME TO TIC TAC TOE" << endl;\
cout << "This game is developed by Mats Gausdal" << endl;
cout << "****************************\n\n\n";
}// end of displayGameWelcome
if (board[0] == "x" && board[1] == "x" && board[2] == "x")
 cout << endl << "The game is over - x wins" << endl;
 return true;
else if (board[3] == "x" && board[4] == "x" && board[5] == "x")
 return true;
else if (board[6] == "x" && board[7] == "x" && board[8] == "x")
 return true;
else if (board[0] == "x" && board[4] == "x" && board[8] == "x")
 return true;
else if (board[2] == "x" && board[4] == "x" && board[6] == "x")
 return true;
else if (board[0] == "x" && board[3] == "x" && board[6] == "x")
 return true;
else if (board[1] == "x" && board[4] == "x" && board[7] == "x")
 return true;
else if (board[2] == "x" && board[5] == "x" && board[8] == "x")
 return true;
else if (board[0] == "o" && board[1] == "o" && board[2] == "o")
 cout << endl << "The game is over - o wins" << endl;
 return true;
else if (board[3] == "o" && board[4] == "o" && board[5] == "o")
 return true;
else if (board[6] == "o" && board[7] == "o" && board[8] == "o")
 return true;
else if (board[0] == "o" && board[4] == "o" && board[8] == "o")
 return true;
else if (board[2] == "o" && board[4] == "o" && board[6] == "o")
 return true;
else if (board[0] == "o" && board[3] == "o" && board[6] == "o")
 return true;
else if (board[1] == "o" && board[4] == "o" && board[7] == "o")
 return true;
else if (board[2] == "o" && board[5] == "o" && board[8] == "o")
 return true;
else if (board[0] != " " && board[1] != " " && board[2] != " " && board[3] != " " && board[4] != " " && board[5] != " " && board[6] != " " && board[7] != " " && board[8] != " ")
 cout << "It's a draw!" << endl;
 return true;
// more to do here (don't forget to check for draw)
return false;
}// end of isGameOver
// displays tic tac toe board in the format
// |0 1 2|
// |3 4 5|
// |6 7 8|
  string str = "";
  if (i == 0)
	 str = str  + "|" + board[i];
  else if (i == 2 || i == 5)
	 str = str + board[i] + "|\n|";
  else if (i == 8)
	 str = str +  board[i] + "|\n";
  else
	 str = str + board[i];
  return str;
}// end of displayBoard
Du må forenkle denne koden vesentlig.
1. Ikke bruk string for board. Dette burde være en char[3][3].
2. Sjekken for om noen har vunnet bær være vesentlig enklere.
3. Du reseeder som gjør at datamaskinen vil prøve det samme tallet igjen og igjen og igjen
#include <string>
#include <iostream>
#include <cstdlib>
const string displayBoard(const char board[3][3]);   // displays tic tac toe board
const bool isGameOver(const char board[3][3]);		  // checks if game is over
// Credits
// [url="http://www.codingmix.com/2010/07/simples-cplusplus-tic-tac-toe-game-ever_24.html"]http://www.codingmix...me-ever_24.html[/url]
int main()
   char board[3][3];			   // tic tac toe, top row 0 thru 2, middle row 3 thru 5, bottom row 6 thru 8
    ((char*)board)[i] = ' ';
   srand(time(NULL));
   while (true)
    while (true)
	    cin >> position;
	    if(position < 0 || position > 8)
		    cout << "Invalid number." << endl;
		    continue;
	    int x = position % 3;
	    int y = position / 3;
	    if (board[x][y] == ' ')
		    board[x][y] = 'x';  // placing x in desired board location
		    break;
	    else
		    continue;
	    break;
    while (true)
	    int x = rand() % 3;
	    int y = rand() % 3;
	    if(board[x][y] == ' ')
		    board[x][y] = 'o';
		    break;
	    break;
   cin.get();
   return 0;
}// end of main
const bool equal(const char c1, const char c2, const char c3)
   return c1 == c2 && c3 == c1;
const char WhoWon(const char board[3][3])
 for(int i = 0; i < 3; i++)
   if(equal(board[i][0], board[i][1], board[i][2]) && board[i][0] != ' ')
  return board[i][0];
   if(equal(board[0][i], board[1][i], board[2][i]) && board[0][i] != ' ')
  return board[i][0];
 if(equal(board[0][0], board[1][1], board[2][2]) && board[0][0] != ' ')
   return board[0][0];
 if(equal(board[2][0], board[1][1], board[0][2]) && board[2][0] != ' ')
   return board[2][0];
 return ' ';
   const char result = WhoWon(board);
   if(result == ' ')
    return false;
   cout << "Game is over - " << result << " won!" << endl;
   return true;
// |0 1 2|
// |3 4 5|
// |6 7 8|
   string str = "";
   for (int i = 0; i < 3; i++)
    str += "|";
    for(int j = 0; j < 3; j++)
	    str += board[j][i];
	    if(j < 2)
		    str += ' ';
    str += "|";
    str += "\n";
   return str;
Endret av GeirGrusom
Hvor oppstår den uendelige loopen - den første while'n (player 1) eller den andre (player 2)?
Det er player 2.
@GeirGrusom
Jeg gjør dette for et prosjekt i c++ klassen. Læreren min krever at jeg må bruke srand(1); Takk for svar.
Det er player 2.
@GeirGrusom
Men hvis du gjør det foran rand() så vil den prøve det samme tallet igjen og igjen kan være grunnen til den evige loopen. Kall srand(1) én gang på starten av programmet.
Har testet programmet du gav meg. Trenger hjelp med dette.
	  return board[i][0];
	  return board[i][0];
return board[0][0];
return board[2][0];
 return ' ';
Hva er funksjonen til equal?
Og WhoWon sjekker x og y koordinatene mot hverandre, og etter mine øyner burde den funke 100% men allikevel så klarer den ikke f.eks. denne:
Litt vanskelig og se. Men int x = (board[0][3], board[1][3], board[2][3])
Og hvorfor vinner "o" her?
Samme xy koordinater for "x" som forrige. Den viser at "o" vinner, når "x" burde vinne.
Endret av matshg
equal er bare korthåndsfunksjon for å sjekke om de tre verdiene er like. Den sjekker om a = b og c = a som vil si at alle tre er like.
Det er en programmeringsfeil fra min side i koden:
			  return board[i][0];
			  return board[0][i];
    return board[0][0];
    return board[2][0];
 return ' ';
Takk for hjelpen. Bare en liten ting. Hvis det blir uavgjort, hvordan får jeg programmet til å vise det er draw?
Fant det ut ved å gjøre dette
   if(result == ' ')
	    return false;
if (result !=' ')
 cout << "It's a draw" << endl;
   return true;
