plz.. se på .vbe scriptet mitt og se om dere ser noen feil.
Jeg driver å lager et logon script for win200 server, men får ikke til å mappe opp drives etter rettigheter. Her ser dere hva jeg har scriptet, ser dere noen åpenbare feil ? plz.. hjelp meg.
'PATH and FILE: %logonserver%NETLOGONlogon.vbs
'Required files: logon.html
'This script is made for XXX
'Designed by Kim Tore Baardseth
'Version: 1.0.0
'VERSION DATE AUTHOR
'1.0.0 20030618 Kim Tore Baardseth
''' Starting script
Option Explicit
'On Error Resume Next
''' Dim all posible variables
Dim IE
Dim IE_URL
Dim IE_Status
Dim WSHShell
Dim WSHNetwork
Dim strMappedDrives
Dim nReturnCode
Dim strUser
Dim Group
Dim MemberOf
Dim Child
Dim DefPrinter
Dim varNow
''' Set all required objects
DefPrinter = "nt-serverprinter"
IE_URL = "nt-serverscriptlogon.html"
''' Open a Internet Explorer Window
Call CreateIE()
''' Loading all required object
IE_Status = "Laster inn nødvendige objekter..." & vbNewLine
ie.document.all.IE_Status.InnerText = IE_Status
Set WSHShell = WScript.CreateObject("WScript.Shell")
Set WSHNetwork = WScript.CreateObject("WScript.Network")
''' Mapping Drives based on users rights
IE_Status = IE_Status + "Sjekker hvilken grupper du er medlem av..." & vbNewLine
strUser="WinNT://" & wshNetwork.UserDomain & "/" & WSHNetwork.UserName
Set Group = GetObject(strUser)
Set MemberOf=Group.Groups
For Each Child in MemberOf
if (UCASE(Left(Child.Name,2)) ="A_") then
IE_Status = IE_Status + "Kobler opp disken F: mot fellesområdet ditt..." & vbNewLine
MapDrive "F:", "nt-servermarked" & UCASE(Child.Name)
End If
if (UCASE(Left(Child.Name,2)) ="P_") then
IE_Status = IE_Status + "Kobler opp disken P: mot programområdet..." & vbNewLine
MapDrive "P:", "nt-serveradministrasjon"
End If
Next
''' Mapping up a network printer
IE_Status = IE_Status + "Setter standard skriver..." & vbNewLine
WSHNetwork.AddWindowsPrinterConnection DefPrinter
WSHNetwork.SetDefaultPrinter DefPrinter
''' Set the system time
IE_Status = IE_Status + "Synkroniserer klokken mot serveren..." & vbNewLine
nReturnCode = wshShell.Run("net time /domain:" & wshNetwork.UserDomain & " /set /yes", 0, TRUE)
If (nReturnCode <> 0) Then
MsgBox "Påloggingsproblem: Klokke " & vbNewLine & vbNewLine &_
"Det er problem med synkroniseringen av klokken på maskinen." & vbNewLine &_
"Ta kontakt med Brukerstøttesenteret vårt på TLF 4120" & vbNewLine &_
" " & vbNewLine &_
"Oppgi dennne meldingen til BSS:" & vbNewLine &_
"Problemer med Synkronisering av klokke under påloggingen",_
48,_
"Påloggingsproblem: Klokke"
End If
''' Closing the Internet Explorer Window
IE_Status = IE_Status + "Gjør seg klar til å avslutte påloggingen..." & vbNewLine
If ie.document.all.holdit.checked then
varNow = Now
while DateDiff("s",varNow,Now) < 3
wend
ie.quit()
End if
''' Sub Function for Mapping network Drives
Sub MapDrive(strDrive,strShare)
WSHNetwork.MapNetworkDrive strDrive, strShare
If Err.Number Then
WSHNetwork.RemoveNetworkDrive strDrive
End If
End Sub
''' Sub Function for creating a Internet Explorer Window
Sub CreateIE()
Set IE = CreateObject("InternetExplorer.Application")
With IE
.navigate IE_URL
.resizable=0
.height=330
.width=470
.menubar=0
.toolbar=0
.statusBar=0
.visible=1
End With
while ie.Busy: wend
End Sub
Nå er jeg ikke helt sikker på at dette er grunnen, men jeg mener at
det er en feil i MsgBox-callen som forteller brukeren at det er problemer med å synkronisere klokken.
Tror derfor du må erstatte de linjene med disse:
MsgBox "Påloggingsproblem: Klokke " & vbNewLine & vbNewLine & _
"Det er problem med synkroniseringen av klokken på maskinen." & vbNewLine & _
"Ta kontakt med Brukerstøttesenteret vårt på TLF 4120" & vbNewLine & _
" " & vbNewLine & _
"Oppgi dennne meldingen til BSS:" & vbNewLine & _
"Problemer med Synkronisering av klokke under påloggingen", _
48, _
End If
