Tvilsom microsoft e-post??
midgard
Hei alle!
Fikk nettopp en mail fra denne adressen: Microsoft Corporation Security Section [[email protected]]. Med denne meldingen:
MS Customer
this is the latest version of security update, the "September 2003, Cumulative Patch" update which eliminates all known security vulnerabilities affecting MS Internet Explorer, MS Outlook and MS Outlook Express as well as three new vulnerabilities. Install now to protect your computer.
System requirements Windows 95/98/Me/2000/NT/XP
This update applies to MS Internet Explorer, version 4.01 and later
MS Outlook, version 8.00 and later
MS Outlook Express, version 4.01 and later
Recommendation Customers should install the patch at the earliest opportunity.
How to install Run attached file. Choose Yes on displayed dialog box.
How to use You don't need to do anything after installing this item.
Microsoft Product Support Services and Knowledge Base articles can be found on the Microsoft Technical Support web site. For security-related information about Microsoft products, please visit the Microsoft Security Advisor web site, or Contact Us.
Thank you for using Microsoft products.
Please do not reply to this message. It was sent from an unmonitored e-mail address and we are unable to respond to any replies.
Litt mye å lese kanskje, men det var vedlagt en fil som heter "installer335.exe" som outlook stoppet. Er dette en reel e-post fra MS eller er det et virus?
På forhånd takk
hilsen Midgard
Ja dette var bra, Den siste artikkelen var jo printscreen fra e-posten jeg fikk.
Kan nesten ikke få takket dere nok
takktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakktakk :p
