Hvordan finne forskjeller i større datalister, rasktest mulig?
Dataene er sortert, sa du?
$ time ./a.out
> /home/olav/Documents/103375239.doc
< /home/olav/Documents/gameofthrones.doc
< /home/olav/Documents/.hiddenpornofiles/nudepic1.jpg
< /home/olav/Documents/.hiddenpornofiles/nudepic2.jpg
< /home/olav/Documents/.hiddenpornofiles/nudepic3.jpg
< /home/olav/Documents/.hiddenpornofiles/nudepic4.jpg
< /home/olav/Documents/porn.doc
> /home/olav/file753898663.txt
> /home/olav/file75400904.txt
> /home/olav/file75535687.txt
> /home/olav/file755566055.txt
> /home/olav/file75574336.txt
< /home/olav/Music
< /home/olav/Pictures
< /home/olav/.profile.conf
< /home/olav/raid
< /home/olav/.ssh/id_pub.rsa
< /usr/local/etc/989929161.conf
< /usr/local/etc/98994238.conf
< /usr/local/etc/989950314.conf
< /usr/local/etc/99962676.conf
< /usr/local/etc/nginx.conf
< /usr/local/etc/postgresql.conf
< /usr/local/etc/smb.conf
real 0m0.083s
user 0m0.068s
sys 0m0.012s
Inkludert innlesning. Er et par antagelser jeg ikke kan gjøre, så blir noen sjekker for mye. Men men. Mistenker at mesteparten her sitter i IO.
#include <fstream>
#include <iostream>
static inline void helper( std::ifstream& file1,
	std::ifstream& file2,
	std::string& line1,
	std::string&line2, bool right ) {
const char* arrow = right ? "> " : "< ";
while( line1 < line2 && file1.good() ) {
	std::cout << arrow << line1 << "\n";
	std::getline( file1, line1 );
if( line1 == line2 ) return;
if( !file1.good() ) return;
helper( file2, file1, line2, line1, !right );
int main() {
std::string line1, line2;
std::cout.sync_with_stdio( false );
std::ifstream file1( "data5.txt" );
std::ifstream file2( "data6.txt" );
while( file1.good() && file2.good() ) {
	std::getline( file2, line2 );
	if( line1 == line2 ) continue;
	if( line1 < line2 )
		helper( file1, file2, line1, line2, true );
	else helper( file2, file1, line2, line1, false );
while( file1.good() ) {
	std::cout << "> " << line1 << "\n";
while( file2.good() ) {
	std::cout << "< " << line2 << "\n";
std::cout.flush();
Veldig nice Lycantrophe!
Testa den nettopp her, 5x raskare enn Python og det inkludert innlesning! :)
+ For veldig lettlest kode også!
Sånt som det der får meg til å misunne folk som kan C eller C++.
Gjest Slettet+9871234
Viktigst i prioritert rekkefølge:
  1. Algoritmer og datastrukturer.
  2. Maskinvare.
  3. Språk, tolket kontra kompilert kode.
Etter mitt syn gir det liten mening - ceteris paribus - å sammenligne tolket med kompilert kode. Det er fint at der er noen her inne som ikke er blinde og kan C :hmm:
Konverterte koden til Lycantrophe til Java. Blei ca 50% treigare etter 20 looper som varma opp JVM'en.
Tipper det er compareTo() og equals() som drar ned ytelsen.
package no.diskusjon;
import java.io.BufferedReader;
import java.io.File;
import java.io.FileReader;
import java.io.IOException;
import java.util.Date;
public class Main {
   private static void helper(BufferedReader br1, BufferedReader br2,
				    String line1, String line2, boolean right)
    throws IOException{
    String arrow = right ? "> " : "< ";
    while(line1.compareTo(line2) < line2.compareTo(line1)){
	    System.out.println(arrow+line1+"\n");
	    line1 = br1.readLine();
    if(line1.equals(line2)) {
	    return;
    helper(br2, br1, line2, line1, !right);
   public static long start(){
    final File file1 = new File("/home/olav/Downloads/data5.txt");
    final File file2 = new File("/home/olav/Downloads/data6.txt");
    String line1;
    String line2;
    try{
	    BufferedReader br1 = new BufferedReader(new FileReader(file1));
	    BufferedReader br2 = new BufferedReader(new FileReader(file2));
	    long start = new Date().getTime();
	    while(((line1 = br1.readLine()) != null) &&
			    (line2 = br2.readLine()) != null){
			    continue;
		    else if( line1.compareTo(line2) < line2.compareTo(line1) ){
			    helper(br1, br2, line1, line2, true);
		    else{
			    helper(br2, br1, line2, line1, false);
	    while ((line1 = br1.readLine()) != null){
		    System.out.println("> " + line1 + "\n");
	    while ((line2 = br2.readLine()) != null){
		    System.out.println("< " + line2 + "\n");
	    return new Date().getTime() - start;
    } catch(IOException e){
	    return -1l;
   public static void main(String[] args) {
    long ms = -1;
    for(int i = 0; i < 20; i++){
	    ms = start();
    System.out.println(ms);
