Taxman Skrevet 18. september 2003 Del Skrevet 18. september 2003 fikk epost fra min brebåndleverandør i dag. Snokene fra BayTSP har funnet ut at jeg gjorde noe på Edonkey nettverket jeg ikke skulle ha gjort Jeg fikk bare en advarsel fra min leverandør at hvis det dukket opp flere klager på meg så ville de iverksette "tiltak". Jeg bare lurte på om noen andre har fått tilsvarende brev, og hvordan deres ISP'er reagerte. Her følger "gladnyheten" som jeg fant postkassen min. -------------------------- Dear Sir or Madam: BayTSP, Inc. ("BayTSP") swears under penalty of perjury that Paramount Pictures Corporation ("Paramount") has authorized BayTSP to act as its agent for copyright infringement notification. BayTSP's search of the protocol listed below has detected infringements of Paramount's copyright interests on your IP addresses as detailed in the attached report. BayTSP has reasonable good faith belief that use for the material in the manner complained of in the attached report is not authorized by Paramount, its agents, or the law. The information provided herein is accurate to the best of our knowledge. Therefore, this letter is an official notification under provisions of section 512© of the U.S. Digital Millennium Copyright Act to effect removal of the detected infringement listed in the attached report. The Berne Convention for the Protection of Literary and Artistic Works, the Universal Copyright Convention, as well as bilateral treaties with other countries allow for protection of client's copyrighted work even beyond U.S. borders. The attached documentation specifies the exact location of the infringement. The Notice ID identifies the copyrighted works by file identification number. We hereby request that you immediately remove or block access to the infringing material, as specified in the copyright laws, and insure the user refrains from using or sharing with others Paramount's materials in the future. Please send us a prompt response indicating the actions you have taken to resolve this matter. Please reference the Notice ID number above in your response. Nothing in this letter shall serve as a waiver of any rights or remedies of Paramount with respect to the alleged infringement, all of which are expressly reserved. Should you need to contact me, I may be reached at the following address: Mark Ishikawa Chief Executive Officer BayTSP, Inc. PO Box 1314 Los Gatos, CA 95031 v: 408-559-1100 f: 408-377-2174 [email protected] *pgp public key is available on the key server at ldap://keyserver.pgp.com Note: The information transmitted in this Notice is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, reproduction, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from all computers. - ---- Infringed Work: Beavis And Butt-Head Do America Infringing FileName: Beavis.And.Butthead.Do.America.(1996).Syrling.ShareReactor.avi Lenke til kommentar
phnx85 Skrevet 18. september 2003 Del Skrevet 18. september 2003 Altså, dette brevet ble sendt til din ISP, som vidre sendte det til deg og sa at hvis de fikk flere klager så skulle de iverksette "tiltak"? Har jeg forstått det riktig? Hvilken ISP har du? Lenke til kommentar
Taxman Skrevet 18. september 2003 Forfatter Del Skrevet 18. september 2003 Du har nok forstått det riktig ja. De hadde ip'n min, sendte dette brevet til min isp - som sendte meg en advarsel og la ved "brevet" Min leverandør er BKK, et firma som jeg bare har gode ord å si om (selv om de endret fra 8 mb og skrudd farten nedover). Jeg har allerede tatt advarselen, og sluttet med aktiviteten. Ikke vits i å gi noen grunn til å la dem ta fra meg nettilgangen min. Det jeg lurte på var om de hadde satt i gang storaksjon, og at flere ISP 'er har fått advarsler fra dem, eller om jeg var den eneste som vant i "lotto" denne gangen. Lenke til kommentar
KAS Skrevet 15. oktober 2003 Del Skrevet 15. oktober 2003 Siden vi hører så lite om sånt på dette forumet, kan det tyde på at det (heldigvis) bare er et fåtall av ISP'ene våre som bryr seg, eller at kun et fåtall av folk som får slike advarsler våger/vet å legge det ut her. Denne er fra USA. Legg merke til protokollen. From: UNC Copyright Office To: [email protected] Cc: [email protected],[email protected] Subject: Notice of Claimed Copyright Infringement [Remedy Ticket 410216] Date: Fri, 03 Oct 2003 11:33:50 -0400 Mr. XXX XXX: The copyright violation notice below was forwarded to us. In accordance with the university's copyright infringement policy found at http://www.unc.edu/policy/copyinfringe.html, the network administrators will disable access to the following system and files: IP ADDRESS: 152.19.XXX.XXX INFRINGEMENT: The.Italian.Job VXR Screener (audio fixed) Your system has been removed from UNC's network and you must meet with the Postmaster staff in the Undergradute Library. You will be contacted by our Postmaster's office for an acceptable use meeting. Copyright infringement is a violation of the data network appropriate use policy. See http://www.unc.edu/policy/aupol.html. This note serves as notification to you of the copyright complaint and our actions. If appropriate, you may provide us with a written statement that the removal or disabling of access was based on a mistake or misidentification. This counter notice must meet the requirements of 17 U.S.C. 512(g)(3). Upon receipt of the counter notice, we will transmit the counter notice to the complainant and unless that person notifies us that he/she has filed a court action to restrain you from the infringing activity associated with this complaint, access will be restored in ten to fourteen business days in accordance with university policy. Thank you, UNC Copyright Office (919) 962-5322 http://www.unc.edu/policy/ ------------------------------------------------------------ Subject: [Fwd: *** DMCA Notice [Notice ID: 819361]] -------- Original Message -------- Subject: *** DMCA Notice [Notice ID: 819361] Date: Wed, 1 Oct 2003 23:05:40 -0700 From: [email protected] Reply-To: [email protected] To: [email protected] -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 North Carolina Research and Education Network NCSU-Computing Center Box 7109 Notice ID:819361 Notice Date:1 Oct 2003 20:22:43 GMT Dear Sir or Madam: BayTSP, Inc. ("BayTSP") swears under penalty of perjury that Paramount Pictures Corporation ("Paramount") has authorized BayTSP to act as its agent for copyright infringement notification. BayTSP's search of the protocol listed below has detected infringements of Paramount's copyright interests on your IP addresses as detailed in the attached report. BayTSP has reasonable good faith belief that use for the material in the manner complained of in the attached report is not authorized by Paramount, its agents, or the law. The information provided herein is accurate to the best of our knowledge. Therefore, this letter is an official notification under provisions of section 512© of the U.S. Digital Millennium Copyright Act to effect removal of the detected infringement listed in the attached report. The attached documentation specifies the exact location of the infringement. The Notice ID identifies the copyrighted works by file identification number. We hereby request that you immediately remove or block access to the infringing material, as specified in the copyright laws, and insure the user refrains from using or sharing with others Paramount's materials in the future. Please send us a prompt response indicating the actions you have taken to resolve this matter. Please reference the Notice ID number above in your response. Nothing in this letter shall serve as a waiver of any rights or remedies of Paramount with respect to the alleged infringement, all of which are expressly reserved. Should you need to contact me, I may be reached at the following address: Mark Ishikawa Chief Executive Officer BayTSP, Inc. PO Box 1314 Los Gatos, CA 95031 v: 408-341-2300 f: 408-341-2399 [email protected] Note: The information transmitted in this Notice is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, reproduction, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from all computers. This infringement notice contains an XML tag that can be used to automate the processing of this data. If you would like more information on how to use this tag please contact BayTSP. - ---- Infringed Work: Italian Job, The Infringing FileName: The.Italian.Job VXR Screener (audio fixed) Infringing FileSize: 1116629256 Protocol: BitTorrent Infringers IP Address: 152.19.xxx.xxx Infringer's User Name: None Infringement Timestamp: 1 Oct 2003 04:16:02 GMT ----- End forwarded message ----- Lenke til kommentar
Jattajatta Skrevet 15. oktober 2003 Del Skrevet 15. oktober 2003 Du brukte vel ikke tilfeldigvis PeerGuardian? Der er BayTSP registrert med flere IP'er og du kunne kanskje unngått å få et slikt brev. Dersom de hadde (har) brukt en ny IP til å ta deg hadde du hatt den i en logg nå. Lenke til kommentar
KAS Skrevet 17. oktober 2003 Del Skrevet 17. oktober 2003 Svarte du dem? Hva skrev du i så fall? Det er jo ganske arrogant å true med iverksettelse av tiltak uten å ha hørt hva kunden har å si først. Hender jo at de gjør feil, de som sender ut disse brevene også. Lenke til kommentar
Taxman Skrevet 18. oktober 2003 Forfatter Del Skrevet 18. oktober 2003 Om jeg svarte dem? Nope.. Skyldig som jeg var, så bare stakk jeg hodet ned i sanden og håpet hele tingen ville forsvinne :-) Det er vel ISP'n som skal svare hva de har iverksatt - jeg ser ingen grunn til å skriv til bayTSP og la dem få vite hvem jeg er (alt de vet er at en IP fra min leverandør har vært slemme med film). De (min ISP) har ikke gjort noen såkalte "tiltak" mot meg, utover å sende en advarsel om at BayTSP hadde varslet dem. Grei deal for meg. For å si det slik - hvis jeg noen gang skulle laste ned noe igjen, så ville jeg nok lagt inn ip'ene fra PG i blokklista. Men snill som jeg er så laster jo ikke jeg ned noe som helst lenger Lenke til kommentar
