Final Fantasy XIV - A Realm Reborn
Character Data From Beta Test Phase 3
All character data will be deleted at the end of beta test phase 3. Although character data from Version 1.0 will also be deleted, data from the final save on October 31, 2012 will be transferred again at the beginning of beta test phase 4.
The Beta Test Phase 3 Client
Both the Windows and PS3 clients used for beta test phase 3 cannot be used for beta test phase 4 or official service. Please delete the client at the end of this beta test phase.
Du skal kunne være med automatisk til phase 4.
Endret av Orbitz
Fra Lodestone:
For those who have registered a beta code by Wednesday, July 31, 2013 4:59 (GMT), you will automatically be accepted to participate in Beta Test phase 4 (final Beta Test). If you have not yet registered a beta code, please make sure to complete the registration process before the above date.
For those of you who have not yet applied for the Beta Test, please submit your application by Monday, July 22, 2013 (GMT).
Application Period:
Until Monday, July 22, 2013
* On the above date and time, the Beta Tester Application Site will be temporarily closed and will reopen when Beta Test phase 4(final Beta Test) begins.
Registration Period:
Until Wednesday, July 31, 2013 4:59 (GMT)
* If your beta code has not been registered by the above date and time, you will need to resubmit your application at the Beta Tester Application Site once Beta Test phase 4 begins.
  • 3 uker senere...
Spilte litt på phase 3 betaen så ble så pass interessert at jeg har kjøpt meg spillet. Venter jeg bare på at det skal starte opp :) tror jeg står over denne siste open beta runden denne helgen. Litt bekymret at de har satt maks Level på 20 for betaen så ingen for sett end gamet enda
Endret av Murgel
Hvordan er det å spille dette uten å ha spilt noe særlig FF fra før? Jeg husker jeg kosa meg mye med FFVII som unggutt, men har ikke rørt serien før eller etter etter det spillet.
Jeg liker sjangeren MMO svært godt, spesielt RPG. Liker godt Aion og den type spill. Ellers er jeg veldig glad i PVP, utforsking av store åpne verdener, crafting, player events osv.
Er A Realm Reborn noe for meg? Er det mulig å få beta tilgang nå?
Du kan prøve det gratis denne helgen Josso. vist du har sjans. Neste helg så starter det, tror jeg. Og tror nok dette er spill som ja er kun satt i FF verden. Historien har ikke noe ellers med å gjøre FF verden.
Beste er å teste det. Og se om det er noe for deg eller ikke.
Takk for gode og raske svar!
Jeg kikka litt rundt på den ofisielle siden til spillet, men finner ingenting om open beta der? Må jeg kanskje vente til i morgen før jeg får mulighet å registere/laste ned spillet? Sikkert bare jeg som er blind :-P
Mener å huske at Open beta framgangen vil kanskje bli overført til retail. Så best å velge servere etc som dere har tenkt å spille på denne helga. Forøvrig spilt det siden closed beta og liker det veldig godt. Skal spille på Diabolos.
Tror det er veldig begrenset med PvP. Har nesten ikke sett til noe PvP i closed beta, og var veldig lite Pvp også i FF11. Hopp inn i Diabolos så kan jeg veilede deg litt hvis du vil. Logger på etter jobb.
Endret av Nanoflare
Minner om at jeg står som leder for et nordisk LS/FC som kommer til å spille aktivt på Ragnarok, både gamle og nye spillere er velkomne til å bli med og spille sammen med oss hvis du har lyst.
Ser ut til at ragnarok serveren er stengt for nye spillere for øyeblikket :(
Endret av Biamor
