Poldi Skrevet 17. september 2003 Del Skrevet 17. september 2003 Hallo der ute ............ Er på jakt etter ett prog. som du kan "Sru av Pc'n" til ett gitt tidspunkt. Veit at denne fuksjon finnes i enkelte tweek prog. , men finnes det ett prog. som BARE gjør dette ??? Lenke til kommentar
Silvester Skrevet 18. september 2003 Del Skrevet 18. september 2003 http://www.competent-software.com/english/...n/shutdown.html http://www.hs-lab.com/Products/Shareware/ Lenke til kommentar
GeirGrusom Skrevet 18. september 2003 Del Skrevet 18. september 2003 I Windows XP er det et program som heter shutdown.exe som gjør akkurat dette. Den tar en rekke parameter Lenke til kommentar
Gribler Skrevet 18. september 2003 Del Skrevet 18. september 2003 Description of the Shutdown.exe Tool Shutdown.exe uses the following syntax: shutdown computername /l /a /r /t:xx "msg" /y /c You can use the following switches with Shutdown.exe: computername: Use this switch to specify the remote computer to shut down. If you omit this parameter, the local computer name is used. /l (Note that this is a lowercase "L" character): Use this switch to shut down the local computer /a: Use this switch to quit a shutdown operation. You can do this only during the time-out period. If you use this switch, all other parameters are ignored. /r: Use this switch to restart the computer instead of fully shutting it down. /t:xx: Use this switch to specify the time (in seconds) after which the computer is shut down. The default is 20 seconds. "msg": Use this switch to specify a message during the shutdown process. The maximum number of characters that the message can contain is 127. /y: Use this switch to force a "yes" answer to all queries from the computer. /c: Use this switch quit all running programs. If you use this switch, Windows forces all programs that are running to quit. The option to save any data that may have changed is ignored. This can result in data loss in any programs for which data is not previously saved. Example: To schedule the local computer to shutdown and restart at 10:00 P.M., type the following line at a command prompt, and then press ENTER: at 22:00 shutdown /l /r /y /c Lenke til kommentar
