For de som heller vil ha listet i skriftelig fremvisning.
ASSAULT
Assault Riffles:
  • AK-12
  • SCAR-H
  • M416
  • SAR-21
  • AEK-971
  • FAMAS
  • AUG A3
  • M16A3
  • CZ-805
  • QBZ-95-1
  • ACE 23
Gadgets:
  • M320 HE
  • M320 DART
  • M320 SMK
  • M320 FB
  • M320 LVG
  • M26 MASS
  • M26 DART
  • M26 FRAG
  • M26 SLUG
  • First Aid Pack
  • Medic Bag
ENGINEER
PDW:
  • MX4
  • PP-2000
  • UMP-45
  • CBJ-MS
  • PDW-R
  • CZ-3A1
  • JS2
  • P90
  • UMP-9
Gadget:
  • RPG-7V2
  • FGM-172 SRAW
  • MBT LAW
  • MK153 SMAW
  • FGM-148 JAVELIN
  • FIM-92 STINGER
  • SA-18 IGLA
  • Repair Tool
  • EOD BOT
  • M15 AT MINE
  • M2 SLAM
SUPPORT
LMG:
  • U-100 MK5
  • TYPE 88 LMG
  • LSAT
  • PKP PECHENEG
  • QBB-95-1
  • M240B
  • MG4
  • M249
  • RPK-12
RECON
Bolt-Action Rifles:
  • CS-LR4
  • M40A5
  • SCOUT ELITE
  • SC-98
  • JNG-90
  • 338-RECON
  • M98B
  • SRR-61
  • FY-JS
Accessories:
  • PLD
  • SOFLAM
  • Motion Sensor
  • T-UGS
  • MAV
  • Radio Beacon
  • C4 Explosives
  • M18 Claymore
ALL CLASSES:
Carbine:
  • AK 5C
  • ACW-R
  • SG553
  • AKU-12
  • A-91
  • ACE 52 CQB
  • G36C
  • M4A1
  • ACE 21 CBQ
  • TYPE-95B-1
DMR:
  • RFB
  • MK11 MOD 0
  • SKS
  • SVD-12
  • QBU-88
  • M39 EMR
  • ACE 53 SC
  • SCARH-H SV
Shotguns:
  • QBS-09
  • 870 MCS
  • M1014
  • HAWK 12G
  • Saiga 12k
  • SPAS-12
  • UTS-15
  • DBV-12
Pistols:
  • P226
  • M9
  • QSZ-92
  • MP443
  • SHORY 12G
  • G18
  • FN57
  • 93R
  • CZ-75
  • .44 Magnum
  • Compact 45
  • M412 REX
Knives:
  • Bayonette
  • ACB-90
  • Shank
  • Machete
  • Bowie
  • Carbon Fibre
  • Improvised
  • Scout
  • Survival
  • Trench
Weapon Accessories:
  • Canted Ironsights: An alternate set of ironsights to switch to when engaging close range targets.
  • Magnifier (2X): Adds a toggle-able 2x zoom to any red dot and 1x sights, makes acquiring and taking out long range targets easier.
  • Flash Light: Primarily used to light up dark environments but also blinds enemies if you shine it right at them.
  • Tactical Light: A flashlight that lights up automatically when you aim down your sights. Lights up areas and blind enemies.
  • Laser Sight: Increases accuracy when firing from the hip. The bright light makes you highly visible but can blind enemies.
  • Tri Beam Laser: A laser with three points to make aiming from the hip easier and temporarily blind enemies.
  • Green Laser Sight: Can blind enemies if shined directly in their eyes and increases hip-fire accuracy.
  • Laser/Light Combo: Toggle between a blinding flashlight or accuracy increasing laserpointer depending on your situation.
  • Variable Zoom (14X) [bolt Action Riffles]: Adds another toggleable 14x magnification mode to any high powered scope.
  • Range Finder [bolt Action Riffles]: Displays the distance to the target and the current zeroing distance on your weapon.
Barel:
  • Muzzle Brake: The muzzle brake makes it easier to control the kick of the weapon at expense of accuracy.
  • Compensator: Decreases recoil but at the expense of decreased accuracy.
  • Flash Hider: The Flash Hider hides the muzzle flash. You will still be heard but harder to see.
  • Heavy Barrel: Gives you a tighter dispersion pattern but the increased weight makes recoil harder to control.
  • Suppressor: Equipping your gun with a sound suppressor makes it so that your position is not revealed when you shoot it.
  • LS06: This Chinese silencer gives increased stealth at the expense of decreased bullet velocity.
  • PBS-4 Suppressor: your position will stay hidden to enemies if you equip this Russian silencer while shooting.
  • R2 Suppressor: Silences your weapon by slowing down the bullet and capturing the sound waves.
Underbarrel:
  • Bi-pod: Aim down the sights near any surface to deploy the bi-pod on it for high accurate supported shooting.
  • Ergo Grip: Reduces the accuracy penalty when shooting while moving.
  • Angled Grip: Reduces the first shot recoil making bursts and single shots easier to handle.
  • Stubby Grip: Makes recovering to normal accuracy faster when coming out of a sprint.
  • Vertical Grip: Reduces the accuracy penalty when shooting while moving.
  • Folding Grip: Reduces the first shot recoil making bursts and single shots easier to handle.
  • Potato Grip: Makes recovering to normal accuracy faster when coming out of a sprint.
Edit: Puttet det i spoiler istedenfor jeg :p
Endret av Nerowulf
Først aid pack og medic bag? Hvorfor skal man velge first aid pack egentlig? Er ikke det sånn at den kun healer en mann?
Hæ? First aid og ammo pack kan benyttes av hele laget ditt... Regner med det blir det samme i BF4?
EDIT: Tror jeg blingsa litt, trøtt i øya... Er det 2 typer medic pack i BF4?
Endret av iNtensimilla
Ser sånn ut. Derfor jeg lurte på hvorfor man skule velge first aid over medic bag.
Nå har jeg ikke tilgang til å se videoen, men kanskje First Aid Pack er en Instant-Self-Heal? Hvilket BF-spill hadde dette? Sprøyte med morfin eller noe. Bad Company 1?
Mener å huske det fra en av streamene ja. Instant heal, men ikke bare seg selv. Også andre spillere.
Yes! C4 tilbake på Recon! Endelig har jeg en grunn til å spille Recon igjen :)
UMP + C4. Sweet.
Ulempen blir at det blir tryggere å kjøre tanks. Recon ligger som regel uti hutiheita og kan da ikke C4 tanksen.
Nooooooooooo UMP er på Engineer og ikke all classes :(
Endret av Argoniel
Håper de går tilbake til syv classes: Anti-Tank som har bazooka, miner og lignenede, Assault som nettopp er det; fot-soldat uten spesial-spesialutstyr, Engineer, Medic, Sniper, Spec-Ops med C4 og Support med ammo og LMG. Istedet for å komprimere de til fire. Det gir et mer taktisk preg på gameplayet.
Håper også at de lager litt større oversiktlige kart uten "tunnelpreg" i utformingen". Slik at det åpner mer opp for å legge taktikker osv.
For guds skyld fjern 90% av alle lys og flare effektene...
Endret av kmatis
Det skal være en slags ordning på det, feks rank prioritet. Det har også vært en del kritikk fordi, om man sitter på bussen og er commander og går afk, hva skjer da. Feks om bestemor ringer, skal da laget ha en afk commander. Så siste jeg hørte vurderer de forskjellige måter. Det blir nok en slags vote ordning samtidig, men med commander kan brukes så lenge man har Battlelog, du trenger ikke en pad for å bruke commander. Mulig det kommer mer info om det via livestream
