[Løst] Xorg: Failed to become DRM master. UnloadModule: "intel"
Oki, da aner ikke jeg hva jeg skal gjøre mer med dette.
Kjører CPU-GPU ut fra hovedkortet men ender hver eneste reboot med sort skjerm:
[ 110.215]
X.Org X Server 1.13.0
Release Date: 2012-09-05
[ 110.220] X Protocol Version 11, Revision 0
[ 110.222] Build Operating System: Linux 3.2.0-26-generic i686 Ubuntu
[ 110.224] Current Operating System: Linux brealorg 3.5.0-26-generic #40-Ubuntu SMP Tue Feb 26 19:59:36 UTC 2013 i686
[ 110.224] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.5.0-26-generic root=UUID=655b0c8e-8839-4624-928c-4e10d66b8106 ro quiet splash vt.handoff=7
[ 110.228] Build Date: 27 November 2012 07:44:37AM
[ 110.228] xorg-server 2:1.13.0-0ubuntu6.1 (For technical support please see http://www.ubuntu.com/support)
[ 110.229] Current version of pixman: 0.26.0
[ 110.231] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 110.231] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 110.234] (==) Log file: "/var/log/Xorg.1.log", Time: Wed Mar 6 21:27:03 2013
[ 110.235] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 110.235] (==) No Layout section. Using the first Screen section.
[ 110.235] (==) No screen section available. Using defaults.
[ 110.235] (**) |-->Screen "Default Screen Section" (0)
[ 110.235] (**) | |-->Monitor "<default monitor>"
[ 110.235] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 110.235] (==) Automatically adding devices
[ 110.235] (==) Automatically enabling devices
[ 110.235] (==) Automatically adding GPU devices
[ 110.235] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 110.235] Entry deleted from font path.
[ 110.235] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 110.235] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 110.235] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 110.235] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 110.235] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 110.235] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 110.235] (==) ModulePath set to "/usr/lib/i386-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 110.235] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 110.235] (II) Loader magic: 0xb7779640
[ 110.235] (II) Module ABI versions:
[ 110.235] X.Org ANSI C Emulation: 0.4
[ 110.235] X.Org Video Driver: 13.0
[ 110.235] X.Org XInput driver : 18.0
[ 110.235] X.Org Server Extension : 7.0
[ 110.235] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 110.236] setversion 1.4 failed
[ 110.237] (--) PCI:*(0:0:2:0) 8086:0162:1043:84ca rev 9, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64
[ 110.237] (II) Open ACPI successful (/var/run/acpid.socket)
[ 110.238] Initializing built-in extension Generic Event Extension
[ 110.238] Initializing built-in extension SHAPE
[ 110.239] Initializing built-in extension MIT-SHM
[ 110.240] Initializing built-in extension XInputExtension
[ 110.241] Initializing built-in extension XTEST
[ 110.241] Initializing built-in extension BIG-REQUESTS
[ 110.242] Initializing built-in extension SYNC
[ 110.243] Initializing built-in extension XKEYBOARD
[ 110.244] Initializing built-in extension XC-MISC
[ 110.245] Initializing built-in extension SECURITY
[ 110.245] Initializing built-in extension XINERAMA
[ 110.246] Initializing built-in extension XFIXES
[ 110.247] Initializing built-in extension RENDER
[ 110.248] Initializing built-in extension RANDR
[ 110.248] Initializing built-in extension COMPOSITE
[ 110.249] Initializing built-in extension DAMAGE
[ 110.250] Initializing built-in extension MIT-SCREEN-SAVER
[ 110.251] Initializing built-in extension DOUBLE-BUFFER
[ 110.251] Initializing built-in extension RECORD
[ 110.252] Initializing built-in extension DPMS
[ 110.253] Initializing built-in extension X-Resource
[ 110.253] Initializing built-in extension XVideo
[ 110.254] Initializing built-in extension XVideo-MotionCompensation
[ 110.255] Initializing built-in extension XFree86-VidModeExtension
[ 110.256] Initializing built-in extension XFree86-DGA
[ 110.256] Initializing built-in extension XFree86-DRI
[ 110.257] Initializing built-in extension DRI2
[ 110.257] (II) LoadModule: "glx"
[ 110.257] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 110.257] (II) Module glx: vendor="X.Org Foundation"
[ 110.257] compiled for 1.13.0, module version = 1.0.0
[ 110.257] ABI class: X.Org Server Extension, version 7.0
[ 110.257] (==) AIGLX enabled
[ 110.258] Loading extension GLX
[ 110.258] (==) Matched intel as autoconfigured driver 0
[ 110.258] (==) Matched vesa as autoconfigured driver 1
[ 110.258] (==) Matched modesetting as autoconfigured driver 2
[ 110.258] (==) Matched fbdev as autoconfigured driver 3
[ 110.258] (==) Assigned the driver to the xf86ConfigLayout
[ 110.258] (II) LoadModule: "intel"
[ 110.258] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 110.258] (II) Module intel: vendor="X.Org Foundation"
[ 110.258] compiled for 1.13.0, module version = 2.20.9
[ 110.258] Module class: X.Org Video Driver
[ 110.258] ABI class: X.Org Video Driver, version 13.0
[ 110.258] (II) LoadModule: "vesa"
[ 110.258] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 110.258] (II) Module vesa: vendor="X.Org Foundation"
[ 110.258] compiled for 1.12.99.902, module version = 2.3.2
[ 110.258] (II) LoadModule: "modesetting"
[ 110.258] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 110.258] (II) Module modesetting: vendor="X.Org Foundation"
[ 110.258] compiled for 1.13.0, module version = 0.5.0
[ 110.258] (II) LoadModule: "fbdev"
[ 110.258] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 110.258] (II) Module fbdev: vendor="X.Org Foundation"
[ 110.258] compiled for 1.12.99.902, module version = 0.4.3
[ 110.258] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
Ivybridge Server (GT2), Haswell Desktop (GT1), Haswell Desktop (GT2),
Haswell Desktop (GT2+), Haswell Mobile (GT1), Haswell Mobile (GT2),
Haswell Mobile (GT2+), Haswell Server (GT1), Haswell Server (GT2),
Haswell Server (GT2+), Haswell SDV Desktop (GT1),
Haswell SDV Desktop (GT2), Haswell SDV Desktop (GT2+),
Haswell SDV Mobile (GT1), Haswell SDV Mobile (GT2),
Haswell SDV Mobile (GT2+), Haswell SDV Server (GT1),
Haswell SDV Server (GT2), Haswell SDV Server (GT2+),
Haswell ULT Desktop (GT1), Haswell ULT Desktop (GT2),
Haswell ULT Desktop (GT2+), Haswell ULT Mobile (GT1),
Haswell ULT Mobile (GT2), Haswell ULT Mobile (GT2+),
Haswell ULT Server (GT1), Haswell ULT Server (GT2),
Haswell ULT Server (GT2+), Haswell CRW Desktop (GT1),
Haswell CRW Desktop (GT2), Haswell CRW Desktop (GT2+),
Haswell CRW Mobile (GT1), Haswell CRW Mobile (GT2),
Haswell CRW Mobile (GT2+), Haswell CRW Server (GT1),
Haswell CRW Server (GT2), Haswell CRW Server (GT2+),
ValleyView PO board
[ 110.259] (II) VESA: driver for VESA chipsets: vesa
[ 110.259] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 110.259] (II) FBDEV: driver for framebuffer: fbdev
[ 110.259] (--) using VT number 8
[ 110.262] (WW) Falling back to old probe method for vesa
[ 110.262] (WW) Falling back to old probe method for modesetting
[ 110.262] (WW) Falling back to old probe method for fbdev
[ 110.262] (II) Loading sub module "fbdevhw"
[ 110.262] (II) LoadModule: "fbdevhw"
[ 110.263] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 110.263] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 110.263] compiled for 1.13.0, module version = 0.0.2
[ 110.263] ABI class: X.Org Video Driver, version 13.0
[ 110.263] (EE) intel(0): [drm] failed to set drm interface version.
[ 110.263] (EE) intel(0): Failed to become DRM master.
[ 110.263] (II) UnloadModule: "intel"
[ 110.263] (EE) Screen(s) found, but none have a usable configuration.
[ 110.263]
Fatal server error:
[ 110.263] no screens found0,/
[ 110.263] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 110.263] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[ 110.263] (EE)
[ 110.280] Server terminated with error (1). Closing log file.
Kjører dette for å komme inn med GUI:
sudo service lightdm stop
sudo dpkg-reconfigure xorg xserver-xorg xserver-xorg-core
sudo service lightdm start
Google med issuet gir meg nada niks :(
[ 110.263]  Fatal server error:
[ 110.263] (EE)
Solution:
gksu gedit /etc/init/lightdm.conf
above “exec lightdm”, add the following line and then save the file:
sleep 2
“2″ is the number of seconds used to delay starting LightDM.
Startup is smooth as cake. Solution provided by webupd8.org
