erik456 Skrevet 17. mars 2013 Forfatter Del Skrevet 17. mars 2013 Bruker 12.10 x64 Slik ha jeg gjort : sudo add-apt-repository ppa:bumblebee/stable sudo add-apt-repository ppa:ubuntu-x-swat/x-updates sudo apt-get update sudo apt-get install bumblebee bumblebee-nvidia linux-headers-generic Drivere vil ikke vises under Software Sources->Additional Drivers Men som sagt, jeg har jo en helt annen maskin. Den siste linken til Del sier jo at det er noe trøblete å få installert bumblebee på din pc Prøvde det som du fåreslo, som du ser i terminialen, så får jeg en feilmelding: kamikaze1993@kamikaze1993-UX32VD:~$ sudo add-apt-repository ppa:bumblebee/stable[sudo] password for kamikaze1993: Sorry, try again. [sudo] password for kamikaze1993: You are about to add the following PPA to your system: Bumblebee Stable PPA To report issues, please read http://wiki.Bumblebee-Project.org/Reporting-Issues You may also want to use newer drivers (particularly if having recent hardware), then run this before installing Bumblebee (do not if you are on 12.04.2): sudo add-apt-repository ppa:ubuntu-x-swat/x-updates sudo apt-get update You may also use different nvidia driver flavor, like -updates, -experimental or -nnn ones starting with Bumblebee 3.1. If you want to use primus, you need to install it and set Bridge=primus in bumblebee.conf or use optirun -b primus. You also need to install primus-libs-ia32 if you want to run 32-bit apps. After installation, reboot to let changes apply. To see if it works, run during around 30s: glxspheres Then, run it with optirun, and compare: optirun glxspheres Be aware that as Bumblebee is using low-level hardware informations, it is impossible to run it in a VM. More info: https://launchpad.net/~bumblebee/+archive/stable Press [ENTER] to continue or ctrl-c to cancel adding it gpg: keyring `/tmp/tmp2ftRm6/secring.gpg' created gpg: keyring `/tmp/tmp2ftRm6/pubring.gpg' created gpg: requesting key 8110A93A from hkp server keyserver.ubuntu.com gpg: /tmp/tmp2ftRm6/trustdb.gpg: trustdb created gpg: key 8110A93A: public key "Launchpad PPA for Bumlebee Project" imported gpg: Total number processed: 1 gpg: imported: 1 (RSA: 1) OK kamikaze1993@kamikaze1993-UX32VD:~$ sudo add-apt-repository ppa:ubuntu-x-swat/x-updates You are about to add the following PPA to your system: Updated versions of X.org drivers, libraries, etc. for Ubuntu. This PPA is for stable upstream releases of X.org components. If you're looking for something even more bleeding-edge, please see the xorg-edgers PPA. While Ubuntu does not "officially/formally" support these packages, if you discover problems when installing these debs please feel free to report bugs to launchpad. However, please make sure to clearly state that you are running packages from this PPA so we know the fixes need to come here. If you are upgrading from one release to another with this PPA activated, please install the ppa-purge package and use it to downgrade everything in here beforehand. sudo ppa-purge ppa:ubuntu-x-swat/x-updates will do it. [Directions for packaging drivers can be seen at https://wiki.ubuntu.com/X/DriverBuilding] More info: https://launchpad.net/~ubuntu-x-swat/+archive/x-updates Press [ENTER] to continue or ctrl-c to cancel adding it gpg: keyring `/tmp/tmpaUgnVn/secring.gpg' created gpg: keyring `/tmp/tmpaUgnVn/pubring.gpg' created gpg: requesting key AF1CDFA9 from hkp server keyserver.ubuntu.com gpg: /tmp/tmpaUgnVn/trustdb.gpg: trustdb created gpg: key AF1CDFA9: public key "Launchpad PPA for Ubuntu-X" imported gpg: no ultimately trusted keys found gpg: Total number processed: 1 gpg: imported: 1 (RSA: 1) OK kamikaze1993@kamikaze1993-UX32VD:~$ sudo apt-get update Get:1 http://security.ubuntu.com precise-security Release.gpg [198 B] Get:2 http://repository.spotify.com stable Release.gpg [489 B] Hit http://ppa.launchpad.net precise Release.gpg Hit http://ppa.launchpad.net precise Release.gpg Get:3 http://ppa.launchpad.net precise Release.gpg [316 B] Hit http://no.archive.ubuntu.com precise Release.gpg Get:4 http://extras.ubuntu.com precise Release.gpg [72 B] Get:5 http://security.ubuntu.com precise-security Release [49.6 kB] Hit http://repository.spotify.com stable Release Get:6 http://no.archive.ubuntu.com precise-updates Release.gpg [198 B] Get:7 http://no.archive.ubuntu.com precise-backports Release.gpg [198 B] Ign http://repository.spotify.com stable Release Hit http://ppa.launchpad.net precise Release.gpg Hit http://ppa.launchpad.net precise Release.gpg Hit http://ppa.launchpad.net precise Release.gpg Hit http://ppa.launchpad.net precise Release.gpg Hit http://ppa.launchpad.net precise Release.gpg Hit http://ppa.launchpad.net precise Release Hit http://extras.ubuntu.com precise Release Hit http://no.archive.ubuntu.com precise Release Get:8 http://no.archive.ubuntu.com precise-updates Release [49.6 kB] Ign http://repository.spotify.com stable/non-free amd64 Packages/DiffIndex Hit http://ppa.launchpad.net precise Release Get:9 http://ppa.launchpad.net precise Release [11.9 kB] Hit http://extras.ubuntu.com precise/main Sources Ign http://repository.spotify.com stable/non-free i386 Packages/DiffIndex Ign http://repository.spotify.com stable/non-free TranslationIndex Get:10 http://no.archive.ubuntu.com precise-backports Release [49.6 kB] Hit http://ppa.launchpad.net precise Release Hit http://ppa.launchpad.net precise Release Hit http://ppa.launchpad.net precise Release Hit http://ppa.launchpad.net precise Release Hit http://ppa.launchpad.net precise Release Hit http://extras.ubuntu.com precise/main amd64 Packages Hit http://extras.ubuntu.com precise/main i386 Packages Get:11 http://security.ubuntu.com precise-security/main Sources [64.3 kB] Hit http://ppa.launchpad.net precise/main Sources Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://no.archive.ubuntu.com precise/main Sources Hit http://no.archive.ubuntu.com precise/restricted Sources Hit http://no.archive.ubuntu.com precise/universe Sources Ign http://extras.ubuntu.com precise/main TranslationIndex Hit http://no.archive.ubuntu.com precise/multiverse Sources Hit http://no.archive.ubuntu.com precise/main amd64 Packages Hit http://no.archive.ubuntu.com precise/restricted amd64 Packages Hit http://no.archive.ubuntu.com precise/universe amd64 Packages Hit http://no.archive.ubuntu.com precise/multiverse amd64 Packages Hit http://no.archive.ubuntu.com precise/main i386 Packages Hit http://no.archive.ubuntu.com precise/restricted i386 Packages Hit http://ppa.launchpad.net precise/main Sources Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://no.archive.ubuntu.com precise/universe i386 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Ign http://ppa.launchpad.net precise/main TranslationIndex Get:12 http://ppa.launchpad.net precise/main Sources [1,565 B] Hit http://no.archive.ubuntu.com precise/multiverse i386 Packages Get:13 http://ppa.launchpad.net precise/main amd64 Packages [1,839 B] Hit http://no.archive.ubuntu.com precise/main TranslationIndex Hit http://no.archive.ubuntu.com precise/multiverse TranslationIndex Hit http://no.archive.ubuntu.com precise/restricted TranslationIndex Hit http://no.archive.ubuntu.com precise/universe TranslationIndex Get:14 http://no.archive.ubuntu.com precise-updates/main Sources [369 kB] Hit http://repo.steampowered.com precise Release.gpg Get:15 http://ppa.launchpad.net precise/main i386 Packages [2,630 B] Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://ppa.launchpad.net precise/main Sources Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://ppa.launchpad.net precise/main Sources Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Get:16 http://security.ubuntu.com precise-security/restricted Sources [1,950 B] Get:17 http://security.ubuntu.com precise-security/universe Sources [22.6 kB] Get:18 http://security.ubuntu.com precise-security/multiverse Sources [1,380 B] Get:19 http://security.ubuntu.com precise-security/main amd64 Packages [229 kB] Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://ppa.launchpad.net precise/main Sources Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://ppa.launchpad.net precise/main Sources Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://ppa.launchpad.net precise/main Sources Hit http://repository.spotify.com stable/non-free amd64 Packages Hit http://ppa.launchpad.net precise/main amd64 Packages Hit http://ppa.launchpad.net precise/main i386 Packages Ign http://ppa.launchpad.net precise/main TranslationIndex Hit http://repo.steampowered.com precise Release Hit http://repository.spotify.com stable/non-free i386 Packages Get:20 http://no.archive.ubuntu.com precise-updates/restricted Sources [5,120 B] Get:21 http://no.archive.ubuntu.com precise-updates/universe Sources [81.6 kB] Get:22 http://security.ubuntu.com precise-security/restricted amd64 Packages [3,969 B] Get:23 http://security.ubuntu.com precise-security/universe amd64 Packages [68.4 kB] Get:24 http://no.archive.ubuntu.com precise-updates/multiverse Sources [4,746 B] Get:25 http://no.archive.ubuntu.com precise-updates/main amd64 Packages [586 kB] Get:26 http://security.ubuntu.com precise-security/multiverse amd64 Packages [2,186 B] Get:27 http://security.ubuntu.com precise-security/main i386 Packages [239 kB] Ign http://repository.spotify.com stable/non-free Translation-en_US Ign http://repository.spotify.com stable/non-free Translation-en Get:28 http://security.ubuntu.com precise-security/restricted i386 Packages [3,968 B] Get:29 http://security.ubuntu.com precise-security/universe i386 Packages [70.1 kB] Ign http://extras.ubuntu.com precise/main Translation-en_US Hit http://repo.steampowered.com precise/steam Sources Get:30 http://security.ubuntu.com precise-security/multiverse i386 Packages [2,369 B] Hit http://security.ubuntu.com precise-security/main TranslationIndex Hit http://security.ubuntu.com precise-security/multiverse TranslationIndex Hit http://security.ubuntu.com precise-security/restricted TranslationIndex Hit http://security.ubuntu.com precise-security/universe TranslationIndex Ign http://extras.ubuntu.com precise/main Translation-en Hit http://security.ubuntu.com precise-security/main Translation-en Hit http://security.ubuntu.com precise-security/multiverse Translation-en Hit http://security.ubuntu.com precise-security/restricted Translation-en Hit http://security.ubuntu.com precise-security/universe Translation-en Get:31 http://no.archive.ubuntu.com precise-updates/restricted amd64 Packages [9,579 B] Get:32 http://no.archive.ubuntu.com precise-updates/universe amd64 Packages [187 kB] Get:33 http://no.archive.ubuntu.com precise-updates/multiverse amd64 Packages [9,418 B] Get:34 http://no.archive.ubuntu.com precise-updates/main i386 Packages [595 kB] Hit http://repo.steampowered.com precise/steam amd64 Packages Get:35 http://no.archive.ubuntu.com precise-updates/restricted i386 Packages [9,505 B] Get:36 http://no.archive.ubuntu.com precise-updates/universe i386 Packages [189 kB] Get:37 http://no.archive.ubuntu.com precise-updates/multiverse i386 Packages [10.4 kB] Hit http://no.archive.ubuntu.com precise-updates/main TranslationIndex Hit http://no.archive.ubuntu.com precise-updates/multiverse TranslationIndex Hit http://no.archive.ubuntu.com precise-updates/restricted TranslationIndex Hit http://no.archive.ubuntu.com precise-updates/universe TranslationIndex Get:38 http://no.archive.ubuntu.com precise-backports/main Sources [2,422 B] Get:39 http://no.archive.ubuntu.com precise-backports/restricted Sources [14 B] Get:40 http://no.archive.ubuntu.com precise-backports/universe Sources [23.4 kB] Get:41 http://no.archive.ubuntu.com precise-backports/multiverse Sources [2,669 B] Get:42 http://no.archive.ubuntu.com precise-backports/main amd64 Packages [1,945 B] Get:43 http://no.archive.ubuntu.com precise-backports/restricted amd64 Packages [14 B] Get:44 http://no.archive.ubuntu.com precise-backports/universe amd64 Packages [23.2 kB] Get:45 http://no.archive.ubuntu.com precise-backports/multiverse amd64 Packages [2,489 B] Get:46 http://no.archive.ubuntu.com precise-backports/main i386 Packages [1,941 B] Get:47 http://no.archive.ubuntu.com precise-backports/restricted i386 Packages [14 B] Get:48 http://no.archive.ubuntu.com precise-backports/universe i386 Packages [23.2 kB] Get:49 http://no.archive.ubuntu.com precise-backports/multiverse i386 Packages [2,504 B] Hit http://no.archive.ubuntu.com precise-backports/main TranslationIndex Hit http://no.archive.ubuntu.com precise-backports/multiverse TranslationIndex Hit http://no.archive.ubuntu.com precise-backports/restricted TranslationIndex Hit http://no.archive.ubuntu.com precise-backports/universe TranslationIndex Hit http://no.archive.ubuntu.com precise/main Translation-en Hit http://no.archive.ubuntu.com precise/multiverse Translation-en Hit http://no.archive.ubuntu.com precise/restricted Translation-en Hit http://no.archive.ubuntu.com precise/universe Translation-en Hit http://no.archive.ubuntu.com precise-updates/main Translation-en Hit http://no.archive.ubuntu.com precise-updates/multiverse Translation-en Hit http://no.archive.ubuntu.com precise-updates/restricted Translation-en Hit http://no.archive.ubuntu.com precise-updates/universe Translation-en Hit http://no.archive.ubuntu.com precise-backports/main Translation-en Hit http://no.archive.ubuntu.com precise-backports/multiverse Translation-en Hit http://no.archive.ubuntu.com precise-backports/restricted Translation-en Hit http://no.archive.ubuntu.com precise-backports/universe Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Ign http://ppa.launchpad.net precise/main Translation-en_US Ign http://ppa.launchpad.net precise/main Translation-en Hit http://repo.steampowered.com precise/steam i386 Packages Ign http://repo.steampowered.com precise/steam TranslationIndex Ign http://repo.steampowered.com precise/steam Translation-en_US Ign http://repo.steampowered.com precise/steam Translation-en Fetched 3,019 kB in 5s (562 kB/s) Reading package lists... Done W: GPG error: http://repository.spotify.com stable Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 082CCEDF94558F59 kamikaze1993@kamikaze1993-UX32VD:~$ sudo apt-get install bumblebee bumblebee-nvidia linux-headers-generic Reading package lists... Done Building dependency tree Reading state information... Done linux-headers-generic is already the newest version. The following packages were automatically installed and are no longer required: realpath libftgl2 Use 'apt-get autoremove' to remove them. The following extra packages will be installed: bbswitch-dkms libturbojpeg libturbojpeg:i386 libxv1:i386 nvidia-current virtualgl virtualgl-libs virtualgl-libs:i386 virtualgl-libs-ia32:i386 Suggested packages: primus Recommended packages: virtualgl-libs-ia32 The following NEW packages will be installed: bbswitch-dkms bumblebee bumblebee-nvidia libturbojpeg libturbojpeg:i386 libxv1:i386 nvidia-current virtualgl virtualgl-libs virtualgl-libs:i386 virtualgl-libs-ia32:i386 0 upgraded, 11 newly installed, 0 to remove and 22 not upgraded. Need to get 69.7 MB of archives. After this operation, 209 MB of additional disk space will be used. Do you want to continue [Y/n]? y Get:1 http://no.archive.ubuntu.com/ubuntu/ precise-updates/universe libturbojpeg amd64 1.1.90+svn733-0ubuntu4.1 [121 kB] Get:2 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main virtualgl-libs amd64 2.3.2-1~preciseppa1 [206 kB] Get:3 http://no.archive.ubuntu.com/ubuntu/ precise-updates/universe libturbojpeg i386 1.1.90+svn733-0ubuntu4.1 [127 kB] Get:4 http://no.archive.ubuntu.com/ubuntu/ precise/main libxv1 i386 2:1.0.6-2build1 [12.1 kB] Get:5 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main virtualgl amd64 2.3.2-1~preciseppa1 [848 kB] Get:6 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main bbswitch-dkms all 0.5-1~preciseppa1 [10.5 kB] Get:7 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main bumblebee amd64 3.1-1~preciseppa1 [57.7 kB] Get:8 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main virtualgl-libs i386 2.3.2-1~preciseppa1 [198 kB] Get:9 http://ppa.launchpad.net/ubuntu-x-swat/x-updates/ubuntu/ precise/main nvidia-current amd64 304.84-0ubuntu1~precise~xup2 [68.1 MB] Get:10 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main bumblebee-nvidia amd64 3.1-1~preciseppa1 [4,522 B] Get:11 http://ppa.launchpad.net/bumblebee/stable/ubuntu/ precise/main virtualgl-libs-ia32 i386 2.3.2-1~preciseppa1 [2,666 B] Fetched 69.7 MB in 17s (3,915 kB/s) Selecting previously unselected package libturbojpeg. (Reading database ... 213591 files and directories currently installed.) Unpacking libturbojpeg (from .../libturbojpeg_1.1.90+svn733-0ubuntu4.1_amd64.deb) ... Selecting previously unselected package virtualgl-libs. Unpacking virtualgl-libs (from .../virtualgl-libs_2.3.2-1~preciseppa1_amd64.deb) ... Selecting previously unselected package virtualgl. Unpacking virtualgl (from .../virtualgl_2.3.2-1~preciseppa1_amd64.deb) ... Selecting previously unselected package bbswitch-dkms. Unpacking bbswitch-dkms (from .../bbswitch-dkms_0.5-1~preciseppa1_all.deb) ... Selecting previously unselected package bumblebee. Unpacking bumblebee (from .../bumblebee_3.1-1~preciseppa1_amd64.deb) ... Selecting previously unselected package libturbojpeg:i386. Unpacking libturbojpeg:i386 (from .../libturbojpeg_1.1.90+svn733-0ubuntu4.1_i386.deb) ... Selecting previously unselected package libxv1:i386. Unpacking libxv1:i386 (from .../libxv1_2%3a1.0.6-2build1_i386.deb) ... Selecting previously unselected package virtualgl-libs:i386. Unpacking virtualgl-libs:i386 (from .../virtualgl-libs_2.3.2-1~preciseppa1_i386.deb) ... Selecting previously unselected package nvidia-current. Unpacking nvidia-current (from .../nvidia-current_304.84-0ubuntu1~precise~xup2_amd64.deb) ... Selecting previously unselected package bumblebee-nvidia. Unpacking bumblebee-nvidia (from .../bumblebee-nvidia_3.1-1~preciseppa1_amd64.deb) ... Selecting previously unselected package virtualgl-libs-ia32:i386. Unpacking virtualgl-libs-ia32:i386 (from .../virtualgl-libs-ia32_2.3.2-1~preciseppa1_i386.deb) ... Processing triggers for ureadahead ... ureadahead will be reprofiled on next reboot Processing triggers for man-db ... Setting up libturbojpeg (1.1.90+svn733-0ubuntu4.1) ... Setting up libturbojpeg:i386 (1.1.90+svn733-0ubuntu4.1) ... Setting up virtualgl-libs (2.3.2-1~preciseppa1) ... Setting up libxv1:i386 (2:1.0.6-2build1) ... Setting up virtualgl-libs:i386 (2.3.2-1~preciseppa1) ... Setting up virtualgl (2.3.2-1~preciseppa1) ... Setting up bbswitch-dkms (0.5-1~preciseppa1) ... Loading new bbswitch-0.5 DKMS files... First Installation: checking all kernels... Building only for 3.2.0-38-generic Building initial module for 3.2.0-38-generic Done. bbswitch: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/3.2.0-38-generic/updates/dkms/ depmod.... DKMS: install completed. Setting up bumblebee (3.1-1~preciseppa1) ... Adding members from group(s) 'adm sudo admin' to 'bumblebee': kamikaze1993 Adding user kamikaze1993 to group bumblebee update-initramfs: deferring update (trigger activated) bumblebeed start/running, process 4715 Setting up nvidia-current (304.84-0ubuntu1~precise~xup2) ... update-alternatives: using /usr/lib/nvidia-current/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in auto mode. update-alternatives: using /usr/lib/nvidia-current/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in auto mode. update-initramfs: deferring update (trigger activated) INFO:Enable nvidia-current DEBUG:Parsing /usr/share/nvidia-common/quirks/put_your_quirks_here DEBUG:Parsing /usr/share/nvidia-common/quirks/lenovo_thinkpad DEBUG:Parsing /usr/share/nvidia-common/quirks/dell_latitude DEBUG:Processing quirk ThinkPad T420s DEBUG:Failure to match ASUSTeK COMPUTER INC. with LENOVO DEBUG:Quirk doesn't match DEBUG:Processing quirk Latitude E6530 DEBUG:Failure to match ASUSTeK COMPUTER INC. with Dell Inc. DEBUG:Quirk doesn't match Loading new nvidia-current-304.84 DKMS files... First Installation: checking all kernels... Building only for 3.2.0-38-generic Building for architecture x86_64 Building initial module for 3.2.0-38-generic Done. nvidia_current: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/3.2.0-38-generic/updates/dkms/ depmod.... DKMS: install completed. Setting up virtualgl-libs-ia32:i386 (2.3.2-1~preciseppa1) ... Processing triggers for bamfdaemon ... Rebuilding /usr/share/applications/bamf.index... Setting up bumblebee-nvidia (3.1-1~preciseppa1) ... update-alternatives: using /usr/lib/x86_64-linux-gnu/mesa/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in manual mode. update-alternatives: using /usr/lib/i386-linux-gnu/mesa/ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in manual mode. bumblebeed stop/waiting bumblebeed start/running, process 6144 Processing triggers for libc-bin ... ldconfig deferred processing now taking place Processing triggers for initramfs-tools ... update-initramfs: Generating /boot/initrd.img-3.2.0-38-generic kamikaze1993@kamikaze1993-UX32VD:~$ ^C kamikaze1993@kamikaze1993-UX32VD:~$ Det virker som jeg ikke har fått installert det skikkelig, siden når jeg skulle prøve å åpne firefox med bumblebee,noe som ikke fungerte. Lenke til kommentar
JAH Skrevet 17. mars 2013 Del Skrevet 17. mars 2013 Har du prøvd med glxspheres for å teste interne grafikken og optirun glxspheres for å teste nvidia? Regner med at du starta på nytt etter å ha installert bumblebee Lenke til kommentar
erik456 Skrevet 18. mars 2013 Forfatter Del Skrevet 18. mars 2013 Har du prøvd med glxspheres for å teste interne grafikken og optirun glxspheres for å teste nvidia? Regner med at du starta på nytt etter å ha installert bumblebee Begge to kommondoene fungere, men jeg lurer på hvordan jeg kan skru av nvida kortet? Jeg har prøvd å søkt etter bumblee og nvida kontrollpanel,men finner ingen av delene. Lenke til kommentar
JAH Skrevet 18. mars 2013 Del Skrevet 18. mars 2013 Begge to kommondoene fungere, men jeg lurer på hvordan jeg kan skru av nvida kortet? Jeg har prøvd å søkt etter bumblee og nvida kontrollpanel,men finner ingen av delene. Nvidia kortet er deaktivert inntil du bruker optirun kommandoen Lenke til kommentar
Del Skrevet 18. mars 2013 Del Skrevet 18. mars 2013 Så du forskjell på ytelsen med og uten optirun foran? Lenke til kommentar
erik456 Skrevet 18. mars 2013 Forfatter Del Skrevet 18. mars 2013 Nei, jeg merket ikke noe forskjell egentidlig, men varmen minket betraktilig. Uansett så har jeg forsatt problemer med at pcen fryser, jeg satt og såg på en film, der jeg plutselig merket at lyden hang seg opp og at hele systemet "frøs". Noen andre forslag på hva som kan være årsaken? Lenke til kommentar
Del Skrevet 19. mars 2013 Del Skrevet 19. mars 2013 Hvis varmen minket er det et godt steg i riktig retning. Glxspheres rapporterer vel fps? Da bare ser du hvilke tall du får med og uten optirun. Når det gjelder frys, så tror jeg fortsatt det er grafikkdriver, men det kan jo være mer uvanlige ting også. Det er to grep vi kan gjøre, det ene er å teste med ny kjerne, det andre er å teste med nyere nvidia driver. Jeg er usikker på hvor mye knot det blir med bumblebee, kanskje noen andre kan tipse oss om det? Ellers får vi bare prøve oss frem. Lenke til kommentar
erik456 Skrevet 19. mars 2013 Forfatter Del Skrevet 19. mars 2013 Hvis varmen minket er det et godt steg i riktig retning. Glxspheres rapporterer vel fps? Da bare ser du hvilke tall du får med og uten optirun. Når det gjelder frys, så tror jeg fortsatt det er grafikkdriver, men det kan jo være mer uvanlige ting også. Det er to grep vi kan gjøre, det ene er å teste med ny kjerne, det andre er å teste med nyere nvidia driver. Jeg er usikker på hvor mye knot det blir med bumblebee, kanskje noen andre kan tipse oss om det? Ellers får vi bare prøve oss frem. Det glemmte jeg å skrive å det er var 110 fps ca og 60 fps. Det beste blir vel sikkert å prøve med nvidia, først siden jeg har hørt at det kan skje mye gale med kjernel oppdatering,stemmer dette utsagnet? Lenke til kommentar
Del Skrevet 19. mars 2013 Del Skrevet 19. mars 2013 Helt korrekt, å bytte nvidiadriver er nok enklest. Ligger flere versjoner i pakkesystemet, vet du hvordan du bytter? Lenke til kommentar
erik456 Skrevet 20. mars 2013 Forfatter Del Skrevet 20. mars 2013 Helt korrekt, å bytte nvidiadriver er nok enklest. Ligger flere versjoner i pakkesystemet, vet du hvordan du bytter? Jeg har ikke ide på hvordan jeg kan gjennomføre den prossesen? Lenke til kommentar
Del Skrevet 20. mars 2013 Del Skrevet 20. mars 2013 Jeg har blitt så vant til brukervennlig installasjon gjennom Additional hardware drivers, at jeg ikke har oversikt over hvordan kommandolinja går på dette heller. La oss først se hvilke pakker du har. Aptitude er fin til det, om den ikke ligger der kan vi installere denne først: sudo apt-get install aptitude så tar vi ut en liste: aptitude search nvidia sjekk med det samme hvilken driver du har nå: glxinfo|grep NVIDIA Lenke til kommentar
erik456 Skrevet 20. mars 2013 Forfatter Del Skrevet 20. mars 2013 Denne informasjonen får jeg når jeg skriver inn de kommondonene du skrev. kamikaze1993@kamikaze1993-UX32VD:~$ sudo apt-get install aptitude [sudo] password for kamikaze1993: Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: realpath libftgl2 libdrm-nouveau1a:i386 libllvm3.0:i386 Use 'apt-get autoremove' to remove them. The following extra packages will be installed: libboost-iostreams1.46.1 libclass-accessor-perl libcwidget3 libept1.4.12 libio-string-perl libparse-debianchangelog-perl libsub-name-perl Suggested packages: aptitude-doc-en aptitude-doc tasksel debtags libcwidget-dev libhtml-template-perl libxml-simple-perl The following NEW packages will be installed: aptitude libboost-iostreams1.46.1 libclass-accessor-perl libcwidget3 libept1.4.12 libio-string-perl libparse-debianchangelog-perl libsub-name-perl 0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded. Need to get 3,050 kB of archives. After this operation, 9,359 kB of additional disk space will be used. Do you want to continue [Y/n]? y Get:1 http://no.archive.ubuntu.com/ubuntu/ precise/main libboost-iostreams1.46.1 amd64 1.46.1-7ubuntu3 [39.2 kB] Get:2 http://no.archive.ubuntu.com/ubuntu/ precise/main libcwidget3 amd64 0.5.16-3.1ubuntu1 [406 kB] Get:3 http://no.archive.ubuntu.com/ubuntu/ precise/main libept1.4.12 amd64 1.0.6~exp1ubuntu1 [129 kB] Get:4 http://no.archive.ubuntu.com/ubuntu/ precise-updates/main aptitude amd64 0.6.6-1ubuntu1.1 [2,373 kB] Get:5 http://no.archive.ubuntu.com/ubuntu/ precise/main libsub-name-perl amd64 0.05-1build2 [9,656 B] Get:6 http://no.archive.ubuntu.com/ubuntu/ precise/main libclass-accessor-perl all 0.34-1 [26.0 kB] Get:7 http://no.archive.ubuntu.com/ubuntu/ precise/main libio-string-perl all 1.08-2 [12.0 kB] Get:8 http://no.archive.ubuntu.com/ubuntu/ precise/main libparse-debianchangelog-perl all 1.2.0-1ubuntu1 [54.0 kB] Fetched 3,050 kB in 1s (1,867 kB/s) Selecting previously unselected package libboost-iostreams1.46.1. (Reading database ... 240973 files and directories currently installed.) Unpacking libboost-iostreams1.46.1 (from .../libboost-iostreams1.46.1_1.46.1-7ubuntu3_amd64.deb) ... Selecting previously unselected package libcwidget3. Unpacking libcwidget3 (from .../libcwidget3_0.5.16-3.1ubuntu1_amd64.deb) ... Selecting previously unselected package libept1.4.12. Unpacking libept1.4.12 (from .../libept1.4.12_1.0.6~exp1ubuntu1_amd64.deb) ... Selecting previously unselected package aptitude. Unpacking aptitude (from .../aptitude_0.6.6-1ubuntu1.1_amd64.deb) ... Selecting previously unselected package libsub-name-perl. Unpacking libsub-name-perl (from .../libsub-name-perl_0.05-1build2_amd64.deb) ... Selecting previously unselected package libclass-accessor-perl. Unpacking libclass-accessor-perl (from .../libclass-accessor-perl_0.34-1_all.deb) ... Selecting previously unselected package libio-string-perl. Unpacking libio-string-perl (from .../libio-string-perl_1.08-2_all.deb) ... Selecting previously unselected package libparse-debianchangelog-perl. Unpacking libparse-debianchangelog-perl (from .../libparse-debianchangelog-perl_1.2.0-1ubuntu1_all.deb) ... Processing triggers for man-db ... Setting up libboost-iostreams1.46.1 (1.46.1-7ubuntu3) ... Setting up libcwidget3 (0.5.16-3.1ubuntu1) ... Setting up libept1.4.12 (1.0.6~exp1ubuntu1) ... Setting up aptitude (0.6.6-1ubuntu1.1) ... update-alternatives: using /usr/bin/aptitude-curses to provide /usr/bin/aptitude (aptitude) in auto mode. Setting up libsub-name-perl (0.05-1build2) ... Setting up libclass-accessor-perl (0.34-1) ... Setting up libio-string-perl (1.08-2) ... Setting up libparse-debianchangelog-perl (1.2.0-1ubuntu1) ... Processing triggers for libc-bin ... ldconfig deferred processing now taking place kamikaze1993@kamikaze1993-UX32VD:~$ apitude search nvidia No command 'apitude' found, did you mean: Command 'aptitude' from package 'aptitude' (main) apitude: command not found kamikaze1993@kamikaze1993-UX32VD:~$ aptitude search nvidia p boinc-nvidia-cuda - metapackage for CUDA-savvy BOINC client an p boinc-nvidia-cuda:i386 - metapackage for CUDA-savvy BOINC client an i bumblebee-nvidia - nVidia Optimus support using the proprieta p bumblebee-nvidia:i386 - nVidia Optimus support using the proprieta p libkwinactivenvidiahack4 - library used by nvidia cards for the KDE w p libkwinactivenvidiahack4:i386 - library used by nvidia cards for the KDE w i A libkwinnvidiahack4 - library used by nvidia cards for the KDE w p libkwinnvidiahack4:i386 - library used by nvidia cards for the KDE w p nvidia-173 - NVIDIA binary Xorg driver, kernel module a p nvidia-173:i386 - NVIDIA binary Xorg driver, kernel module a p nvidia-173-dev - NVIDIA binary Xorg driver development file p nvidia-173-dev:i386 - NVIDIA binary Xorg driver development file p nvidia-173-updates - NVIDIA binary Xorg driver, kernel module a p nvidia-173-updates:i386 - NVIDIA binary Xorg driver, kernel module a p nvidia-173-updates-dev - NVIDIA binary Xorg driver development file p nvidia-173-updates-dev:i386 - NVIDIA binary Xorg driver development file p nvidia-96 - NVIDIA binary Xorg driver, kernel module a p nvidia-96:i386 - NVIDIA binary Xorg driver, kernel module a p nvidia-96-dev - NVIDIA binary Xorg driver development file p nvidia-96-dev:i386 - NVIDIA binary Xorg driver development file p nvidia-96-updates - NVIDIA binary Xorg driver, kernel module a p nvidia-96-updates:i386 - NVIDIA binary Xorg driver, kernel module a p nvidia-96-updates-dev - NVIDIA binary Xorg driver development file p nvidia-96-updates-dev:i386 - NVIDIA binary Xorg driver development file p nvidia-cg-toolkit - Cg Toolkit - GPU Shader Authoring Language p nvidia-cg-toolkit:i386 - Cg Toolkit - GPU Shader Authoring Language i nvidia-common - Find obsolete NVIDIA drivers p nvidia-common:i386 - Find obsolete NVIDIA drivers i A nvidia-current - NVIDIA binary Xorg driver, kernel module a p nvidia-current:i386 - NVIDIA binary Xorg driver, kernel module a p nvidia-current-dev - NVIDIA binary Xorg driver development file p nvidia-current-dev:i386 - NVIDIA binary Xorg driver development file p nvidia-current-updates - NVIDIA binary Xorg driver, kernel module a p nvidia-current-updates:i386 - NVIDIA binary Xorg driver, kernel module a p nvidia-current-updates-dev - NVIDIA binary Xorg driver development file p nvidia-current-updates-dev:i386 - NVIDIA binary Xorg driver development file p nvidia-experimental-304 - Experimental NVIDIA binary Xorg driver, ke p nvidia-experimental-304:i386 - Experimental NVIDIA binary Xorg driver, ke p nvidia-experimental-304-dev - NVIDIA binary Xorg driver development file p nvidia-experimental-304-dev:i38 - NVIDIA binary Xorg driver development file p nvidia-experimental-310 - Experimental NVIDIA binary Xorg driver, ke p nvidia-experimental-310:i386 - Experimental NVIDIA binary Xorg driver, ke p nvidia-experimental-310-dev - NVIDIA binary Xorg driver development file p nvidia-experimental-310-dev:i38 - NVIDIA binary Xorg driver development file i A nvidia-settings - Tool of configuring the NVIDIA graphics dr p nvidia-settings:i386 - Tool of configuring the NVIDIA graphics dr p nvidia-settings-experimental-30 - Tool of configuring the NVIDIA graphics dr p nvidia-settings-experimental-30 - Tool of configuring the NVIDIA graphics dr p nvidia-settings-experimental-31 - Tool for configuring the NVIDIA graphics d p nvidia-settings-experimental-31 - Tool for configuring the NVIDIA graphics d p nvidia-settings-updates - Tool of configuring the NVIDIA graphics dr p nvidia-settings-updates:i386 - Tool of configuring the NVIDIA graphics dr v nvidia-texture-tools - v nvidia-texture-tools:i386 - v nvidia-va-driver - v nvidia-va-driver:i386 - kamikaze1993@kamikaze1993-UX32VD:~$ ^C kamikaze1993@kamikaze1993-UX32VD:~$ glxinfo|grep NVIDIA kamikaze1993@kamikaze1993-UX32VD:~$ glxinfo|grep NVIDIA kamikaze1993@kamikaze1993-UX32VD:~$ Men det som er problemet er at ingenting skjer, når jeg skriver inn den siste kommandoen. Lenke til kommentar
JAH Skrevet 22. mars 2013 Del Skrevet 22. mars 2013 (endret) Men det som er problemet er at ingenting skjer, når jeg skriver inn den siste kommandoen. Pga bumblebee... Når pc'en fryser, kjører du mediaspilleren med eller uten optirun? Skal du opgradere til litt mer "bleeding edge" nvidia drivere, kan du bytte til ppa:xorg-edgers/ppa men da må ppa:ubuntu-x-swat/x-updates fjernes først Ser ut som bumblebee 3.1 fungerer litt annerledes You may also use different nvidia driver flavor, like -updates, -experimental or -nnn ones starting with Bumblebee 3.1. https://launchpad.ne...+archive/stable En guide: http://www.webupd8.o...rivers-310.html Endret 22. mars 2013 av janaha Lenke til kommentar
erik456 Skrevet 23. mars 2013 Forfatter Del Skrevet 23. mars 2013 Pcen har ikke fryst etter jeg endret driver, men jeg har ikke brukt pcen så aktivt etter dette, så er ikke sikker på at jeg har løst problemet.Hva skriver jeg i terminal når jeg skal bruke nvida kortet til programet playonlinux ? Jeg har lenge prøvd å finne en nintendo emultator som fungere til ubuntu? Jeg har prøvd mupen64, siden jeg har lest rundt om at den skal fungere. Jeg gjorde følgende sudo apt-get install mupen64plus Jeg prøvde å letter etter programmet, men jeg fant ikke det, noen som har en ide på hvordan jeg kan fikse dette problemet? Lenke til kommentar
JAH Skrevet 23. mars 2013 Del Skrevet 23. mars 2013 Hva skriver jeg i terminal når jeg skal bruke nvida kortet til programet playonlinux ? optirun playonlinux Lenke til kommentar
erik456 Skrevet 23. mars 2013 Forfatter Del Skrevet 23. mars 2013 optirun playonlinux Okei, tusen takk. Har du noe kjennskap til hvordan jeg kan få nintendo emulatorer i Ubuntu 12.04 til å fungere? Lenke til kommentar
Occi Skrevet 23. mars 2013 Del Skrevet 23. mars 2013 (endret) mupen64plus later å være ganske populær. Har ikke testet den selv tho. M64Py - Graphical frontend for mupen64plus. Et par tips ang. installasjon på Ubuntu. Ser ut til å være i software center i alle fall. Endret 23. mars 2013 av Occi Lenke til kommentar
erik456 Skrevet 31. mars 2013 Forfatter Del Skrevet 31. mars 2013 Jeg gjennomførte de forskjellige trinnene på guidene over. Det som er rart er at jeg får lyd på spillet, men jeg har helt svart skjerm når jeg prøver å laste inn "rommene" i emulatoren. Jeg har prøvd forskjellige rom. Noen av dere som har støtt på samme problemet som meg? Lenke til kommentar
Del Skrevet 31. mars 2013 Del Skrevet 31. mars 2013 Hvordan går det med stabiliteten, ble bytte av nvidiadriver en god løsning på det problemet? Lenke til kommentar
erik456 Skrevet 31. mars 2013 Forfatter Del Skrevet 31. mars 2013 Hvordan går det med stabiliteten, ble bytte av nvidiadriver en god løsning på det problemet? Det virker faktisk som det fungere no Tusen takk for all hjelpen ! Eneste som irritere meg er at jeg ikke får til n64 emulator Lenke til kommentar
