Grafikkort/driver klikker ofte
Hei,
har problemer med at grafikkortet/driver klikker ofte på min stasjonære, slik at jeg ikke får noe bilde (intet signal) og må derfor gjøre en hard-reset :( Jeg oppdaterte nylig grafikkort driveren til siste versjon, men feilen er der enda.
Hva kan jeg gjøre? Er det software eller hardware problem? Takker for hjelp =)
Specs:
Windows 7 HP x64
AMD HD4870 512mb
AMD Catalyst 13.1
Info ifra minidump (WinDgb):
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa800ae264e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88003abde6c, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc0000001, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000003, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
atikmpag+8e6c
fffff880`03abde6c 4055 push rbp
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`05d60a18 fffff880`0569b000 : 00000000`00000116 fffffa80`0ae264e0 fffff880`03abde6c ffffffff`c0000001 : nt!KeBugCheckEx
fffff880`05d60a20 fffff880`0566e569 : fffff880`03abde6c fffffa80`08dc2000 00000000`00000000 fffffa80`0825a010 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`05d60a60 fffff880`0569adad : fffffa80`0ae264e0 fffffa80`0ae264e0 fffffa80`0ae264e0 fffffa80`0825a010 : dxgkrnl!DXGADAPTER::PrepareToReset+0x109
fffff880`05d60aa0 fffff880`05741f07 : fffffa80`0ae264e0 00000000`00000000 fffffa80`09f36af0 fffffa80`0825a010 : dxgkrnl!TdrIsRecoveryRequired+0x245
fffff880`05d60ad0 fffff880`0576fd5a : fffffa80`ffffffff 00000000`00a8af5e fffff880`05d60c30 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`05d60bb0 fffff880`0573d29e : fffffa80`0825a010 ffffffff`feced300 fffffa80`07321010 00000000`00000000 : dxgmms1!VidSchWaitForCompletionEvent+0x196
fffff880`05d60bf0 fffff880`05769e7a : 00000000`00000000 fffffa80`07321010 00000000`00000080 fffffa80`0825a010 : dxgmms1!VidSchiScheduleCommandToRun+0x1b2
fffff880`05d60d00 fffff800`0317a34a : 00000000`05650233 fffffa80`08caeb50 fffffa80`069a5840 fffffa80`08caeb50 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`05d60d40 fffff800`02eca946 : fffff880`009e9180 fffffa80`08caeb50 fffff880`009f3fc0 fffff880`05d60e40 : nt!PspSystemThreadStartup+0x5a
fffff880`05d60d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+8e6c
SYMBOL_NAME: atikmpag+8e6c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 50a69661
FAILURE_BUCKET_ID: X64_0x116_IMAGE_atikmpag.sys
Followup: MachineOwner
Tilleggsopplysning:
Det skjedde akkurat igjen, så måtte reboote og rett før jeg kom til innloggingsskjermen så klikket det igjen! Neste reboot var vellykket. Vet ikke om dette er til noen hjelp, men det er ihvertfall ikke sammenheng med at jeg gjør noe spesifikt på pc'n.
Har desverre litt vanskelig for å svare på hvor ofte det skjer, siden jeg kun skrev opp dato de to siste gangene. Det har skjedd meg kanskje 4-6 ganger totalt, og virker som om det har blitt verre i det siste...spesielt som jeg nevnte nå at det skjedde igjen etter reboot pga samme feil.
PC'en er selvbygd og har en del år på nakken, med unntak av hovedkort og RAM som er under et år gammelt.
Hvor kjøpte du komponentene fra?
Søskenbarnet mitt fikk med defekt RAM da han bygde sin egen PC. Delene var fra Komplett (ikke at det er noe negativt - de RULER! :w00t: ), men da reboota PC-en heeele tiden.
Gjest Slettet-hCbNt6w4Pq
Holder strømforsyninga mål da? Det er etter min mening alfa omega for en stabil og god maskin. Er det en ting jeg legger mange kroner i så er det strømforsyning. Etter det du sier så virker det som PCen har funka fint før, men det er jo elektronikk vi snakker om. Strømforsyninga kan jo ha blitt dårligere ettersom åra har gått.
Skjer dette når som helst, eller i spill?
Neste gang det skjer, ta også åpne maskina, og se på skjermkortet, lyser det ett, lys en rød liten LED pære eller ett eller anna på skjermkortet, gjerne mot fronten(bakenden av kortet) av kabinettet.
Åpne CCC også går du på performance, amd overdrive, unlocker den om den er locked, så klokker du kortet NED, med en 100-200MHz, hjelper det?
Har du mulighet for å prøve ett anna skjermkort?
Endret av meg0709
Det ser ut som at DirectX går igjen i den dumpen din, så du kan prøve noe så enkelt som å slå av Aero i WIndows 7 og kun kjøre med basiske WIndows farger ala Win XP. Aero bruker DirectX, og er det krøll med DirectX installasjonen din, kan AMD driveren få hikke.
Vær også obs på at jo nyere driver du bruker, jo verre kan ting bli da nyere drivere er optimisert for HD 6xxxx og HD 7xxx serien, og ikke så mye for HD5xxx og HD 4xxx serien. I mange tilfeller kan det hjelpe å bruke en eldre driver, f. eks. 12.8 og ikke siste som finnest.
Hei!
Ser jeg har fått mange gode tips nå, vært borte i helga, så har ikke fått kikket på det. For sikkerhetsskyld så satte jeg maskinen til å kjøre Mem86 og etter 20 timer så var det ingen feil funnet (som jeg regnet med, men skadet ikke å teste).
Strømforsyningen er en corsair Corsair 450watt, kjøpt januar 2009.
Ja, jeg glemte tydligvis å skrive dette, men når driveren klikker så settes vifta til 100% og den røde LED lampen på baksiden av PCB lyser opp. Problemet er det klikker såpass uregelmessig at det vil være svært vanskelig å se om det fungerer å klokke det ned, noe jeg helst også vill unngå. Har annet skjermkort også, men av samme årsak så er dette en problematisk måte å feilsøke på. Kræsj forekommer tilsynelatende helt tilfeldig og har ikke oppstått i sammenheng med spilling eller noen andre grafisk tunge aktiviteter.
Takk for tipset, greit å ha som alternativ. Slik jeg har sett på det så er mitt første, og beste alternativ å avinstallere og så manuellt slette alle restene av AMD driverne, for å så gjøre en clean install. Hvis dette ikke virker så vil jeg bli nødt til å se på alternativene. Hvordan kan jeg eventuellt fikse en korrupt directx installasjon?
Takker for all hjelp så langt, har nok tips nå til at jeg har litt å prøve på! =)
Da har jeg avinstallert, og så manuellt fjernet både filer ifra utforsker og register. Så installerte jeg nyeste driver igjen, MEN akkurat som tidligere ganger får jeg denne feilen i installasjonsloggen:
AMD APP SDK RuntimeFinal Status: Fail
Version of Item: 10.0.937.2
Noen som har noe tanker rundt dette? Lurer også på hvordan jeg går frem for å sjekke/"reparere" directx hvis denne er skyldig ifølge loggen.
Når du fjernet manuelt AMD driverne, slettet du alle mapper og slikt eller brukte du Driver Sweeper? Det beste er å bruke Driver Sweeper da den fjerner alle register innføringer pluss andre spor.
Hvis du tar sjansen på rote litt i registeret til WIndows, er det lett å reinstallere DirectX. Dette skal virke i Windows Vista, Windows 7 og Windows 8. Trykk Win tasten + R, skriv regedit og trykke Enter. Hvis UAC hopper opp, klikk Ja til å kjøre regedit.
Finn så nøkkelen HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectX og dobbelklikk på Version og forander nunmner fra 4.09.00.0904 til 4.08.00.0904. Steng regedit og last ned DirectX installer og kjør det. DirectX vil nå bli reinstallert.
Endret av Chavalito
Når den røde LEDen lyser, så skal det stå ett lite nummer i nærheten av den røde LED, er vel 4stk tror jeg, 3 av de inneholder en bokstav og 3 siffer, mens det siste har 4 siffer?
Angående det å klokke ned, så er ikke det noe dilemma, du skal gjøre det, det vil ikke funke 100% hele tiden, vil fortsatt få litt små krasj, men jeg kan jo med en gang si at du kan, med stor sannsynlighet forberede deg på å enten sende kortet tilbake eller kjøpe ett nytt ett, det synger på siste verset og eneste måten å få det stabilt på er å klokke det ned, jeg var igjennom samme greia med mitt 4870 kort.
På mitt 4870 så lyste LEDen som indikator på en feil kode kalt D601, alt jeg klarte å finne ut var at det var noe feil med spenningsregulator eller noe i den duren, kortet ditt vil aldri bli bedre om det er den feilen, heller motsatt.
Hvis du spiller så gjør det ingenting å klokke det litt ned og du kan prøve å tvangs kjøre spillet på dx9.
Muligens altfor varm vrm, ser noen har løst det med ekstra kjøling på vrm med en ekstra vifte.
Endret av meg0709
Det er tydligvis uenighet ang. Driver Sweeper, men jeg valgt nå å følge denne guiden (som også gjerner register innføringer) -> http://www.overclock.net/t/988215/how-to-properly-uninstall-ati-amd-software-drivers-for-graphics-cards
Genialt tips for å få installert DirectX forøvrig, tusen takk! =)
meg0709:
Nå vil jeg vente litt med å klokke ned til jeg sikkert vet hva som årsaken er og om det er noe vits i. Men det du sier er meget intressant, neste gang skal jeg sjekke hvilken LED som lyser, det hadde jeg faktisk ikke tenkt på å sjekke. HVIS det skulle være samme feil som du opplevde, så burde denne la seg fremprovosere med noen type torturetest. Skal prøve ut med engang og se hva som skjer.
Da har jeg testet med FurMark, kjørte første standard 15 minutterstesten uten problem (99% GPU load, max temp 89 grader). Så kjørte jeg samme test igjen, men med manuell viftekontroll satt til 28%. Testen gikk helt fint og ble gjennomført med max temp på 102 grader (kortet skrur automatisk opp viften ved 101 grader for å unngå skade).
Noen som vet noe mer om den loggede feilen ved installasjon, og om den eventuellt kan ha sammenheng med DirectX?
Prøvde å skifte version nr til 4.08.00.0904, men installasjonsprogrammet sier fortsatt at jeg har samme eller nyere versjon installert og vil derfor ikke kjøre, så dette virket desverre ikke.
Edit:
Har nå kjørt DxDiag programmet (som skal diagnostisere DirectX?) som ikke rapporterte noen problemer.
Endret av quadra
Den kan ha med Microsoft.NET Framework å gjøre eller Visual C++. Det du kan prøve å gjøre er å kjøre CCleaner som vil rense alle Temp mappene dine fordi det kan ligge igjen rester av tidligere installasjoner som funker opp den AMD driver installasjonen som du får feil med. Mulig du kan prøve å installere NET Framework igjen, men det er ikke sikkert.
Etter å ha lastet ned .NET framework 4 og kjørt repair, lastet ned og oppdatert til .NET framework 4.5 og så kjørt automatisk oppdatering, så restartet jeg maskinen. Hadde fått opp skype og skulle koble inn webcamen, men så klikket maskinen igjen. Etter restart så gikk jeg inn på skype og startet en samtale, som etter ca 5 minutter ble avbrutt av at maskinen fikk bluescreen og restartet. Første kræsjen så lyste den røde lampen på grafikkortet og jeg har nå koden som tilhører denne: D1C03. Fantes ikke, må være -> D1603 (Se edit nederst).
Kræsjdump 1:
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa8009455010, fffff88004506e6c, ffffffffc0000001, 3}
Unable to load image \SystemRoot\system32\DRIVERS\atikmpag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+8e6c )
1: kd> !analyze -v
Arguments:
Arg1: fffffa8009455010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88004506e6c, The pointer into responsible device driver module (e.g. owner tag).
Debugging Details:
FAULTING_IP:
atikmpag+8e6c
fffff880`04506e6c 4055 push rbp
BUGCHECK_STR: 0x116
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`065f1718 fffff880`042e1000 : 00000000`00000116 fffffa80`09455010 fffff880`04506e6c ffffffff`c0000001 : nt!KeBugCheckEx
fffff880`065f1720 fffff880`042b4569 : fffff880`04506e6c fffffa80`08e35000 00000000`00000000 fffffa80`07efa410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`065f1760 fffff880`042e0dad : fffffa80`09455010 fffffa80`09455010 fffffa80`09455010 fffffa80`07efa410 : dxgkrnl!DXGADAPTER::PrepareToReset+0x109
fffff880`065f17a0 fffff880`04387f07 : fffffa80`09455010 00000000`00000000 fffffa80`08a14930 fffffa80`07efa410 : dxgkrnl!TdrIsRecoveryRequired+0x245
fffff880`065f17d0 fffff880`043b5d5a : 00000000`ffffffff 00000000`00002289 fffff880`065f1930 fffffa80`07efa410 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`065f18b0 fffff880`043b1ca5 : fffffa80`08d8f000 ffffffff`feced300 fffffa80`09356580 fffff880`043968af : dxgmms1!VidSchWaitForCompletionEvent+0x196
fffff880`065f18f0 fffff880`043b1e5d : fffffa80`08d8f000 fffffa80`07efa410 fffffa80`08d90400 00000000`00000000 : dxgmms1!VidSchiWaitForCompletePreemption+0x7d
fffff880`065f19e0 fffff880`043b0d3c : 00000000`00000101 00000000`00000912 fffffa80`09356580 fffffa80`07efa410 : dxgmms1!VidSchiSendToExecutionQueueWithWait+0x171
fffff880`065f1ae0 fffff880`043b0398 : fffff800`00b96000 fffff880`043afd00 fffffa80`00000000 fffffa80`00009040 : dxgmms1!VidSchiSubmitRenderCommand+0x920
fffff880`065f1cd0 fffff880`043afe96 : 00000000`00000000 fffffa80`093566d0 00000000`00000080 fffffa80`07efa410 : dxgmms1!VidSchiSubmitQueueCommand+0x50
fffff880`065f1d00 fffff800`0313234a : 00000000`027a5499 fffffa80`07e8bb50 fffffa80`069a5840 fffffa80`07e8bb50 : dxgmms1!VidSchiWorkerThread+0xd6
fffff880`065f1d40 fffff800`02e82946 : fffff800`0300de80 fffffa80`07e8bb50 fffff800`0301bcc0 00000000`de731000 : nt!PspSystemThreadStartup+0x5a
fffff880`065f1d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
FOLLOWUP_IP:
atikmpag+8e6c
Kræsjdump 2:
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff88002398f8a, The address that the exception occurred at
Arg3: fffff88005e66898, Exception Record Address
Arg4: fffff88005e660f0, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
lvrs64+2f8a
fffff880`02398f8a 45396924 cmp dword ptr [r9+24h],r13d
EXCEPTION_RECORD: fffff88005e66898 -- (.exr 0xfffff88005e66898)
ExceptionAddress: fffff88002398f8a (lvrs64+0x0000000000002f8a)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 000000000003ef44
Attempt to read from address 000000000003ef44
CONTEXT: fffff88005e660f0 -- (.cxr 0xfffff88005e660f0)
rax=0000000000000000 rbx=fffffa8008490f60 rcx=0000000000000001
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88002398f8a rsp=fffff88005e66ad0 rbp=000000000003ef20
r8=0000000000000000 r9=000000000003ef20 r10=0000000000000002
r11=000000000003ef20 r12=fffffa80084b5900 r13=0000000000000000
r14=000000000003ef20 r15=000000000003ef20
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
lvrs64+0x2f8a:
fffff880`02398f8a 45396924 cmp dword ptr [r9+24h],r13d ds:002b:00000000`0003ef44=????????
Resetting default scope
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 000000000003ef44
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003109100
GetUlongFromAddress: unable to read from fffff800031091c0
000000000003ef44 Nonpaged pool
FOLLOWUP_IP:
lvrs64+2f8a
BUGCHECK_STR: 0x7E
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff88002398f8a
STACK_TEXT:
fffff880`05e66ad0 00000000`00000000 : fffffa80`0a8ff088 00000000`00000000 00000000`00000000 fffffa80`0a8ff0d0 : lvrs64+0x2f8a
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: lvrs64+2f8a
MODULE_NAME: lvrs64
IMAGE_NAME: lvrs64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4f166964
STACK_COMMAND: .cxr 0xfffff88005e660f0 ; kb
FAILURE_BUCKET_ID: X64_0x7E_lvrs64+2f8a
Edit:
Søkte på feilkoder for HD4870 og fant følgende:
HD 4870 LEDs
D1601 - Red LED On, shows critical temperature fault
D1602 - Red LED On, shows External power connector A was removed
D1603 - Red LED On, shows External power connector B was removed
D601 - Red LED On, shows critical Core power fault
Ser ut til at det kan være noe problemer med strømkoblingen altså! Den ene eksterne strømkoblingen går via et skjøtestykke, kanskje denne gir dårlig kontakt? =/ Skal åpne opp pc'en igjen etterpå og se om jeg får koblet det om, slik at det ikke er noe skjøtestykke i mellom. Når jeg tenker meg om, så har jeg en følelse at en god del av tilfellene det har skjedd så har jeg beveget meg i nærheten av toweret, noe som skulle sannsynligjøre at en dårlig kobling er skyldig her. Kommer tilbake med mer info senere, må ut en tur nå, så får kikket på det senere ikveld. Tusen takk for all hjelp så langt :)
Edit 2:
Kunne ikke motstå å ta en kjapp kikk nå. Den ene av de to eksterne strømkoblingene til grafikkortet har et skjøtestykke til en vifte koblet innimellom. MEN alle koblingene satt godt sammen og selv om jeg prøvde å bevege på de/dytte og dra så fikk jeg ikke pc'n til å kræsje. Begynner derfor å tvile på at det faktisk er en dårlig kobling her, noen forslag? ...trodde jeg hadde funnet feilen =/
Endret av quadra
