CosworthPower Skrevet 14. september 2003 Del Skrevet 14. september 2003 Hvordan gjorde man det 13sec trikset til SE T610? Må tømme tlf min heeelt.. Lenke til kommentar
bassmania Skrevet 14. september 2003 Del Skrevet 14. september 2003 Søk på forumet eller bruk google før du poster, jeg fant masse på google etter første søk og det samme på HW. Sitat Works on T300 (tested myself) And is claimed to work on the t68i dont quote me on anyother fones and dont hold me responsible if it goes wrong. The following may be dangerous for your phone im not sure, this technique work extremely well for me and allowed me approx 625kb of free space compared to the 275kb i had before. It removes the following features: Network customisations (for example on my phone it had a T-Zone icon instead of the normal wap icon and T mobile start up and shut down logos instead of sony ericson ones.) it also removes preinstalled themes and images and sounds which also take up a lot of space, but deleting them normally either doesnt free up space or takes too much time or just isnt possible. Heres how todo. 1) goto settings -> master reset -> reset all, it will then ask you to enter your security code. as you finish entering the code count 12 - 13 seconds (12.5 secs exact) for best effects. 2) when you get to 12 - 13 seconds remove the battery quickly and then wait 30 seconds. It is important the battery is removed on 13. When i tried this at first went to 13 seconds but it didnt remove the tmobile icons and one of the tmobile logos, however on a 2nd attemt i accidentally removed at approx 10seconds which removed all the tmobile stuff and all themes everything there was more free space. 3) replace battery and allow for reboot, may take upto 60seconds this time warning i dont kno if you can damage your phone doing this i suspect it may be possible to prevent the firmware from reloading if the is a bootsector which is not installed because the battery is removed to soon, this is a concern i had but im not sure how the T300 is built so i cant be sure if that idea is correct maybe someone else might kno Vis du vil høre komentarer, prøv denne linken... http://www.mobiledia.com/forum/topic271-0-asc-0.html Lenke til kommentar
CosworthPower Skrevet 15. september 2003 Forfatter Del Skrevet 15. september 2003 Ok.. Takker,søkte på forumet men fikk ikke frem noe :!: :bgrin: Lenke til kommentar
