Win 8 ikke OEM verson
Hei.
Jeg vurderer å kjøpe win 8. Men jeg er ute etter en ikke oem eller oppgraderings verson. Jeg formaterer pc'n ca 1 gang i året så en OEM verson vil ikke være spesielt praktisk ettersom jeg da må kontakte microsoft for hver gang jeg skal formatere pc'n. Og jeg skal installere det på en ny pc så funker dårlig å oppgradere noe du ikke har....
Såvidt jeg har lest så er OEM endret på WIn 8, det selges ikke lenger noe fullversjon, men de har visst endret på lisensen på OEM så den kan nå brukes på samme måte som fullversjon tidligere.
http://superuser.com/questions/494782/does-a-full-retail-license-of-windows-8-exist-not-oem-not-upgrade
k, let's clarify things. Hopefully for the last time.
There are two licences:
Upgrade
You must have a preexisting XP/Vista/7 licence/installation.
System Builder
Can be installed on a clean computer. Split into OEM and Personal Use.
Traditionally, there was a System Builder licence used by OEMs (typically smaller shops, since large manufacturers tend to have their own contracts). And then there was a full retail licence used by home users. What has been reported is that the removal of the retail licence, 'forcing' users to use the OEM licence with all its restrictions. This is incorrect.
Yes, the traditional 'retail licence' has been removed. Yes, home users must now buy a System Builder licence. No, that is not an OEM licence (practically speaking). Home users fall under the Personal Use section of the System Builder licence, which is more or less the same as the traditional 'retail' licence. It just got renamed and consolidated with the OEM licence into one package/price. You still have the same right to support from Microsoft and right to transfer the licence you would have had on the traditional retail licence.
Now, to address the misconception that the System Builder licence is an OEM licence. For all intents and purposes, it is not. For previous versions of Windows, yes, but not for Windows 8.
Now, firstly, if you were to look at the System Builder licence you would find it here. That is the OEM licensing page. Disconcerting, yes?
However, if you actually read the licence, it states:
If you are not a system builder and are installing this product for personal use, refer to www.windows.com/personaluselicense for terms that apply to you
So, the OEM part of the licence only applies to OEMs! What a surprise!
Now, on to the personal use licence. This is the equivalent of the traditional retail licence, both in terms and in spirit. There are several parts that were part of Windows 7's retail licence, but not OEM, that are in here:
You can install it in a virtual machine
Under our license, we grant you the right to install and run that one copy on one computer (the licensed computer) as the operating system on a computer that you build for your personal use, or as an additional operating system running on a local virtual machine or a separate partition, subject to the restrictions outlined under “Are there things I’m not allowed to do with the software?”
You can transfer the licence to another machine
Can I transfer the software to another computer or user?
You may transfer the software to another computer that belongs to you. You may also transfer the software (together with the license) to a computer owned by someone else if a) you are the first licensed user of the software and b) the new user agrees to the terms of this agreement. To make that transfer, you must transfer the original media, the certificate of authenticity, the product key and the proof of purchase directly to that other person, without retaining any copies of the software. You may use the backup copy we allow you to make or the media that the software came on to transfer the software. Anytime you transfer the software to a new computer, you must remove the software from the prior computer. You may not transfer the software to share licenses between computers. You may transfer Get Genuine Windows software, Pro Pack or Media Center Pack software only together with the licensed computer.
Microsoft will provide support
Microsoft provides limited support services for properly licensed software as described at support.microsoft.com/common/international.aspx.
This is in contrast to the OEM licence, which states that the builder must support the end user.
Let me reiterate. The Personal Use licence is practically the same as the traditional retail licence. It is not an OEM licence.
Endret av Actibus
Du kan ta "Clean" install med upgrade ;)
Hvordan får man til det?
Det står forklart i tråden til mykhen: Hvordan bruke oppgraderingsnøkkelen til Windows 8?
Det stemmer også at OEM-lisensen er endret, det har vi diskutert i denne tråden: Retail-priser? Finner kun oppgradering og OEM
Kort fortalt: System Builder er en lisens som tillater flytting mellom dine egne maskiner (kun aktivert på én om gangen), men hvis du selger maskinen må lisensen følge med. Denne kalles fortsatt OEM av norske nettbutikker.
Ville vel byttet hovedkort og så installert Windows 8 fra bunn av (clean install). Å oppgradere direkte fra Windows 7 kan skape en masse problemer senere, og ved å så bytte hovedkort etter at Win8 er installert uten å gjøre noe med win8 kan bli en skikkelig hodepine.
Så bytt hovedkort, formater OS disken (husk backup) og legg inn Windows 8 på nytt.
Kan jeg da benytte meg av oppgraderingsversionen eller må jeg kjøpe OEM?
Vet ikke hvor mange ganger jeg og andre må skrive det (samt det finnes en egen Sticky post på dette forumet ang temaet), ja ALLE kan bruke en oppgraderingslisens. Last ned .iso filen, brenn den på en DVD eller legg den på en minnepenn, og så kan du gjøre en clean install.
Får du ikke aktivert etter installasjonen tar du bare registertrikset (les i sticky tråden ang det) og så får du garantert aktivert.
