Her har du ubb coden eg lagte til eit newsscript. Håper du kan bruke dei.
Vist du vil legge til meir koder er det bare å bruke eregi_replace (den er best siden den ikkje bryr seg om det er store eller små bokstaver)
<?php
//ubb tags (used in news/comments to stop exploits)
//Make the txt bold
$news = eregi_replace("[b]","<b>",$news);
$news = eregi_replace("[/b]","</b>",$news);
//Make the txt italic
$news = eregi_replace("[i]","<i>",$news);
$news = eregi_replace("[/i]","</i>",$news);
//Make the txt undelined
$news = eregi_replace("[u]","<u>",$news);
$news = eregi_replace("[/u]","</u>",$news);
//Lists
$news = eregi_replace("[list]","<ul>",$news);
$news = eregi_replace("[/list]","</ul>",$news);
//Lists with nr
$news = eregi_replace("[list=1]","<ol>",$news);
$news = eregi_replace("[/list=1]","</ol>",$news);
//Lists with letter
$news = eregi_replace("[list=A]","<ol type="a">",$news);
$news = eregi_replace("[/list=A]","</ol>",$news);
//Bullets
$news = str_replace("[*]","<li>",$news);
//Center the text
$news = eregi_replace("[center]","<center>",$news);
$news = eregi_replace("[/center]","</center>",$news);
//Font Size
$news = eregi_replace("[size=([^[]*)]","<font size="+1">",$news);
$news = eregi_replace("[/size]","</font>",$news);
//Font Type
$news = eregi_replace("[font=([^[]*)]","<font face="1">",$news);
$news = eregi_replace("[/font]","</font>",$news);
//Color tag
$news = eregi_replace("[color=([^[]*)]","<font color="1">",$news);
$news = eregi_replace("[/color]","</font>",$news);
//Color tag shorted down to c
$news = eregi_replace("[c=([^[]*)]","<font color="1">",$news);
$news = eregi_replace("[/c]","</font>",$news);
//Url tag, with url as txt
$news = preg_replace("/[url]([a-z]+?://)(.*?)[/url]/", "<a href="12" target="_blank">12</a>", $news);
$news = preg_replace("/[url]([a-z]+.)(.*?)[/url]/", "<a href="http://12" target="_blank">12</a>", $news);
//Url tag, with user defined txt
$news = preg_replace("/[url=([a-z]+?://)(.*?)](.*?)[/url]/", "<a href="12" target="_blank">3</a>", $news);
$news = preg_replace("/[url=([a-z]+.)(.*?)](.*?)[/url]/", "<a href="http://12" target="_blank">3</a>", $news);
//Url tag, with image as link
$news = preg_replace("/[url=([a-z]+?://)(.*?)][img=([^[]*)][/url]/", "<a href="12" target="_blank"><img src="3" border="0"></a>", $news);
$news = preg_replace("/[url=([a-z]+.)(.*?)][img=([^[]*)][/url]/", "<a href="http://12" target="_blank"><img src="3" border="0"></a>", $news);
//Email tag
$news = eregi_replace("[email]([^[]*)[/email]", "<a href="mailto:1">1</a>", $news);
//Email tag with user defined txt
$news = eregi_replace("[email=([^[]*)]([^[]*)[/email]", "<a href="mailto:1">2</a>", $news);
//Image tag
$news = eregi_replace("[img=([^[]*)]", "<img src="1" border="0">", $news);
return $news;
Men husk å først gjøre slik at html commandoer ikkje fungerer, derretter includerer du ubb code fila, slik at coden blir parsa og forandra.
$news = htmlspecialchars($news = $news2["news"];);
include("ubb.php");
$text = "[b]Hei på deg[/b]";
$text = replace($text,"[b]","<b>");
$text = replace($text,"[/b]","</b>");
//$text er nå lik "<b>Hei på deg</b>"
Tror jeg går ut i fra den jeg.
Nei nei nei! Dette blir feil. :grumpy:
Hva om en bbcode ikke blir avsluttet da? Kan gå hardt utover layouten på siden din.
Har svart på noe liknende her:
http://forum.hardware.no/viewtopic.php?p=9...ghlight=#954106
*Sukk* Nå må vi prøve å skape litt robust funksjonalitet da gutter...
sven-o:
Eg hadde det slik som det før med start/close tags i ein setning. Men vist du skal ha mulighet til å bruke fleire koder samtideg så går ikkje det.
Og vist du bruker ereg_replace så virker den uansett om det står
 noko som den ikkje vil med preg_replace.
Ein siste ting, det er bare farleg vist du lager visse coder som legger til tables slik som i den andre posten. Om nokon ikkje stenger ein bold tag så betyr ikkje det noko for resten av sida...
sven-o:
Ja vel? Hørtes rart ut. :-?
Kan fint omgås, med fiffige kompinasjoner av eregi_replace() og str_tolower().
Ja ja. Det er din side, altså ditt problem.
Uansett, det blir mindre robust. Det er ikke noe vits å diskutere engang.
