Problemer oppdatering Intel nettverkskort
http://www.asus.com/Motherboard/P8Z77V_PROTHUNDERBOLT/#support_Download_36
Intel LAN Driver V17.3.0.0 for Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit & Win8 32bit & Win8 64bit.(WHQL)
*Note: Please install NVM Update Utility for Intel 82579V Gigabit Ethernet PHY Network Connection first before you update this driver.
The URL of the Utility: http://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22026
82579VSKU.exe Version 1.2.2
Tool to update the NVRAM for the Intel® 82579V Gigabit Ethernet PHY
Copyright © 2012 Intel Corporation
Three tools are included, to support three different operation systems (Windows 32 bit; Windows 64 bit; DOS).
Steps to run the update tool:
1. Download the utility from the Intel download center
2. Select the correct tool file name based on the operating system installed
3. Open a command prompt window with administrator privileges
4. Run the executable file from the common prompt
5. The NVM image will be updated. Reboot the computer for best results.
Usage: [Tool_file_name] [options]
-log [filename] - generate log info
-report [filename] - generate report file
-nosilent - display the user interface
Example command line using the Windows* 64 bit operating system:
82579VSKUW64e -nosilent
Når jeg gjør det får jeg bare beskjeden at cannot copy driver file: aborting. Couldn't install driver
Du gjør dette punktet først?:
The URL of the Utility: http://downloadcente...x?DwnldID=22026
Og du åpner Command Prompt (Ledetekst på norsk) som Administrator (høyreklikk) når du kjører kommandoen:
Hva med versjon 17.2 av driveren, fungerer ikke den?
  • 1 måned senere...
