[LØST]Ingen av WM-ene mine virker!
zZzZz
Fikk litt sjokk nå...
Hadde nettopp installert fluxbox 0.9.3, og lagt den inn i /opt/kde/share/config/kdm/Xsession (bruker KDM). Hadde tenkt å prøve vidunderet, men det var ikke kdm'en min enig i...
Ingen av vindusbehandlerne mine virker...
Xsession-fila mi ser slik ut:
#/bin/sh
# $XConsortium: Xsession /main/10 1995/12/18 18:21:28 gildea $
# $XFree86: xc/programs/xdm/config/Xsession,v 1.2 1998/01/11 03:48:32 dawes Exp $
# Modified for Slackware-3.5, 28-Mar-98 volkerdi
# Extensively rewritten for Slackware 7.0, 03-Oct-1999 volkerdi
# Patched to give priority to $HOME/.xsession, 10-Oct-1999 volkerdi
# Merged changes into upstream (XFree86-4.0.2) version, 17-Feb-2001 volkerdi
# Fixes for $PATH (from Jim Diamond), GDM/KDM/XDM, 2003-02-07 volkerdi
# redirect errors to a file in user's home directory if we can
for errfile in "$HOME/.xsession-errors" "${TMPDIR-/tmp}/xses-$USER" "/tmp/xses-$USER"
do
if ( cp /dev/null "$errfile" 2> /dev/null )
then
 chmod 600 "$errfile"
 exec > "$errfile" 2>&1
 break
fi
done
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/usr/X11R6/lib/X11/xinit/.Xresources
sysmodmap=/usr/X11R6/lib/X11/xinit/.Xmodmap
# merge in defaults and keymaps
if [ -r $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -r $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -r $userresources ]; then
xrdb -merge $userresources
fi
if [ -r $usermodmap ]; then
xmodmap $usermodmap
fi
# Since xdm doesn't run a bash -login shell (or any other login shell)
# we should source these files to set up the user's environment.
profile=/etc/profile
userprofile=~/.profile
if [ -r $profile ]; then
       source $profile 1> /dev/null 2> /dev/null
fi
if [ -r $userprofile ]; then
       source $userprofile 1> /dev/null 2> /dev/null
fi
# Set the $PATH through the user's preferred shell.
case `basename "$SHELL"` in
bash|sh|ash)
PATH="`( echo 'echo $PATH' | bash --login ) | tail -1`"
csh|tcsh)
PATH="`( echo 'echo $PATH' | tcsh -l ) | tail -1`"
ksh)
PATH="`( cat /etc/profile; echo 'echo $PATH' ) | ksh | tail -1`"
zsh)
PATH="`( echo 'echo $PATH' | zsh -l ) | tail -1`"
# We don't know your shell, so we'll set up reasonable defaults.
     if [ "`whoami`" = "root" ]; then
 PATH=$PATH:/usr/local/sbin:/sbin:/usr/sbin:/usr/local/bin:/bin:/usr/bin
     else
 PATH=$PATH:/usr/local/bin:/bin:/usr/bin
       fi
esac
# These files (if they exist) are used to set up the X related environment.  We used to
# exec .xsession at this location, but that can interfere with choosing a session type
# through XDM/KDM/GDM so it was moved to after a requested session is started.  Since
# that means that .xsession might never be run at all when using XDM/KDM/GDM, support
# for the xprofile was added to allow a way for the user to customize the X environment.
if [ -r /etc/xprofile ]; then
source /etc/xprofile
fi
if [ -r ~/.xprofile ]; then
source ~/.xprofile
fi
# Some people say that an .xsession file should always be given priority, even if a
# different window manager was requested in $1.  If you want that behavior, uncomment
# the lines below.  This is not recommended (nor, in general, is the use of an
# .xsession file as a default... it should be left for the advanced users).
#if [ -x $HOME/.xsession ]; then
#        exec $HOME/.xsession $@
#fi
# If a particular session type was requested in $1, start that session:
case "$1" in
failsafe)
xsetroot -solid SteelBlue
exec xterm -geometry 80x24-0-0
KDE)
exec /opt/kde/bin/startkde
gnome)
exec gnome-session
openwin)
exec olvwm
fvwm2)
exec fvwm2
fvwm95)
exec fvwm95
Fluxbox 0.9.3)
exec gkrellm &
exec /usr/torbjorn/flux/nyflux/bin/fluxbox
blackbox)
exec blackbox
xfce)
exec /etc/X11/xinit/xinitrc.xfce
windowmaker)
exec /etc/X11/xinit/xinitrc.wmaker
afterstep)
exec afterstep
enlightenment)
exec /usr/torbjorn/enlightenment/enlightenment-0.16.5/src/enlightenment
fluxbox)
exec gkrellm &
exec /usr/local/bin/fluxbox
#XPde)
#	exec /usr/torbjorn/xpde-0.3.5/XPde
twm)
#xclock -geometry 50x50-1+1 &
#xterm -geometry 80x50+494+51 &
#xterm -geometry 80x20+494-0 &
#xterm -geometry 80x66+0+0 -name login &
exec twm
esac
# If we aren't running from XDM/KDM/GDM and no window manager was
# specified, then we'll run the user's $HOME/.xsession if it's
# executable.  This must be set up to run the user's window manager.
fi
# If the user doesn't have their own xsession and none was specified in
# $1, then run the system default session type:
if [ -r /etc/X11/xinit/xinitrc ]; then
fi
# If a $startup variable is set to define the window or session manager,
# then run that:
if [ -s "$startup" -a -x "$startup" ]; then
exec "$startup"
else
if [ -r "$resources" ]; then
 xrdb -load "$resources"
fi
# Run xsm as a failsafe.
exec xsm
fi
Noen som finner no'n feil?
Kan vel legge til at den flux 0.9.3 er konfigurert med prefix, i motsetning til den gamle.
fluxbox)
exec gkrellm &
#XPde)
twm)
exec twm
esac
Mulig "#" kommentarene etter ";;" og før twm) forvirrer /bin/sh ...
fluxbox)
exec gkrellm &
#XPde)
twm)
exec twm
esac
Tvilsomt, for dette skjedde før jeg satte den XPde-dingsen til kommentar.
