Hvordan gjøre input 1i lydkort stereo?
Gjest medlem-82119
http://forum.cockos.com/archive/index.php/t-78727.html
check your headphone, monitor and mix settings and make sure you are recording in stereo or linking mono tracks to both sides.
If you only have signal on one side a quick dirty fix is to open the mixer matrix setting in reaper and add the signal you want in both sides to the second output by hand.
The "playback output to one channel problem" is only solvable by setting Audio to "Wave" for some reason.
