E-post - Mail Delivery System (Hva betyr dette?)
Av en eller annen grunn mottar jeg et utallig antall e-poster, med følgende beskjed:
Emne: Mail Delivery System <[email protected]>
This is the mail system at host smtp157.uni5.net.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<[email protected]>: host mx.cm.hc.ru[89.111.177.200] said: 550 Unknown user
<[email protected]> (in reply to RCPT TO command)
<[email protected]>: host mail.muh.ru[77.74.185.16] said: 550 5.0.0 The message
has been rejected by spam filtering engine. See
http://sky.muh.ru/spam/nospam.html (in reply to end of DATA command)
<[email protected]>: host MX01.NICMAIL.ru[194.85.88.242] said: 550 Your
message was identified as SPAM
http://hosting.nic.r...rors.shtml#p550 (in reply to end of
DATA command)
Reporting-MTA: dns; smtp157.uni5.net
X-Postfix-Queue-ID: 746E4A5154
X-Postfix-Sender: rfc822; [email protected]
Arrival-Date: Mon, 26 Nov 2012 18:16:31 -0200 (BRST)
Final-Recipient: rfc822; [email protected]
Original-Recipient: rfc822;[email protected]
Action: failed
Status: 5.0.0
Remote-MTA: dns; mx.cm.hc.ru
Diagnostic-Code: smtp; 550 Unknown user <[email protected]>
Action: failed
Status: 5.0.0
Remote-MTA: dns; mail.muh.ru
Diagnostic-Code: smtp; 550 5.0.0 The message has been rejected by spam
filtering engine. See http://sky.muh.ru/spam/nospam.html
Action: failed
Status: 5.0.0
Remote-MTA: dns; MX01.NICMAIL.ru
Diagnostic-Code: smtp; 550 Your message was identified as SPAM
Return-Path: <[email protected]>
Received: from smtp-gw-02.uni5.net (smtp-gw-02 [127.0.0.1])
by smtp157.uni5.net (Postfix) with ESMTP id 746E4A5154;
Received: from Unknown (unknown [187.185.16.221])
by smtp-gw-02.uni5.net (Postfix) with ESMTPA id 4C1D581790DF6;
Mon, 26 Nov 2012 18:16:06 -0200 (BRST)
Message-ID: <1D786A4A73B54FB69B0E60EED30FB204@rrjgg>
Reply-To: =?windows-1251?B?ysvTwSDQwMk=?= <[email protected]>
From: =?windows-1251?B?ysvTwSDQwMk=?= <[email protected]>
To: =?windows-1251?B?yu7t8fLg7fLo7Q==?= <[email protected]>
Subject: =?windows-1251?B?z9DIw8vA2MXNyMUgwiDKy9PBINDAySB3d3cu?=
=?windows-1251?B?IPDg6err8+Eu8PQ=?=
Date: Tue, 27 Nov 2012 02:15:46 +0600
MIME-Version: 1.0
Content-Type: multipart/related;
type="multipart/alternative";
boundary="----=_NextPart_000_1D86_01CDCC45.1C37EF90"
X-Priority: 1
X-MSMail-Priority: High
X-Mailer: Microsoft Windows Mail 6.0.6001.18416
X-MimeOLE: Produced By Microsoft MimeOLE V6.0.6001.18645
Denne kan jeg få opptill ti ganger om dagen.
Hva betyr dette? Selv forstår jeg ingenting, med unntak at jeg ser den inneholder e-post andressen min på enkelte plasser.
Endret av frecjoha
Fra deg til [email protected] og med "svar til" [email protected]. Kan kanskje hende at det er [email protected] som har sendt det, men sansynligvis er ikke det riktig heller.
Det er vel ikke så mye man kan gjøre med det hvis spammerene har fått tak i din mailadresse....
Hmmm! Aldri hørt om.
Hva mener du egentlig med fått tak i?
Det er vel ikke mulig å sende fra andres e-post adresser?
Joda, veldig enkelt hvis man bruker et vanlig e-postprogram. Og e-postadresser finner spammerene på nett eller i mailinglister.
Trengs ikke passord?
Hjelper ikke å skifte passord heller da? og jeg vil i all fremtid bli spammet med slike tilbakemeldinger?
Endret av frecjoha
Nei, passordet trengs for å motta e-post og å logge på webmail.
Nei, bortsett fra hvis noen har hacket mailkoontoen din.
Kanskje... Kanskje mer eller kanskje mindre. Eneste permanente løsning er å bytte mailadresse, men det blir ofte mye jobb - og sansynligvis dukker det opp noe slikt på den nye etter en stund også. Endret av Mr D
