C#: While loop & Button IsPressed C# & WPF
Hei
Hvordan kan jeg kjøre While Loop mens Button Ispressed?
Her vil jeg sette en bit når knapp er trykket og så skrive 0 når knapp blir sluppet.
Men (IsPressed) ser ikke ut til å funke.
private void Command_Drain01(object sender, RoutedEventArgs e)
	    if (1 == initSuccess)
		    while (Drain01.IsPressed)
			    dc.writeBits(libnodave.daveDB, 60, 2356, 1,     (BitConverter.GetBytes(1)));
			    Drain01.Background = Brushes.Green;
			    dc.writeBits(libnodave.daveDB, 60, 2356, 1, (BitConverter.GetBytes(0)));
Noen tips?
Hei,
Jeg har ikke noe erfaring med WPF fra tidligere av, men googlet meg frem til at man kan bruke MouseLeftButtonUp og MouseLeftButtonDown eventene hvis man setter ClickMode til Hover.
using System;
using System.Threading;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Input;
namespace WpfApplication1
/// <summary>
/// Interaction logic for MainWindow.xaml
/// </summary>
public partial class MainWindow : Window
	private bool _buttonPressed;
	public MainWindow()
		InitializeComponent();
		Button1.ClickMode = ClickMode.Hover;
		Button1.MouseLeftButtonUp += Button1OnMouseLeftButtonUp;
		Button1.MouseLeftButtonDown += Button1OnMouseLeftButtonDown;
	private async void Button1OnMouseLeftButtonDown(object sender, MouseButtonEventArgs e)
		Tbox.Text += string.Format("{0}{1}{2}", "Clicked at: ", DateTime.UtcNow, Environment.NewLine);
		_buttonPressed = true;
		var asyncRes = await DoWorkAsync();
		Tbox.Text += asyncRes;
	private void Button1OnMouseLeftButtonUp(object sender, MouseButtonEventArgs e)
		_buttonPressed = false;
	private async Task<string> DoWorkAsync()
		var slowTask = Task.Factory.StartNew(
				  var s = string.Empty;
				  while (_buttonPressed)
					  s += string.Format("{0}{1}{2}", "Doing work: ", DateTime.UtcNow, Environment.NewLine);
					  Thread.Sleep(1000); //To prevent too many rows during testing
				  s += string.Format("{0}{1}{2}", "Finished doing work at: ", DateTime.UtcNow, Environment.NewLine);
				  return s;
		return await slowTask;
Clicked at: 25.11.2012 11:29:44
Doing work: 25.11.2012 11:29:44
Doing work: 25.11.2012 11:29:45
Doing work: 25.11.2012 11:29:46
Doing work: 25.11.2012 11:29:47
Finished doing work at: 25.11.2012 11:29:48
Håper du kan få noe nyttig ut av dette :).
Mvh
Francis
EDIT: Jeg leste ikke tittelen godt nok når jeg svarte første gang, og trodde det dreide seg om SilverLight (som jeg heller aldri har brukt før), men det samme fungerer i WPF.
Endret av :Francis:
Hei
Noen tips?
Du må aldri ha en loop i en eventhandler. Dette vil føre til at programmet ditt slutter å svare, da programmet ikke får tid til å behandle hendelser fordi programmet ditt bruker den tråden til å ikke gjøre noe som helst..
Hei
Det funker bra og bruke PreviewMouseButtonUp
 private void MouseDrainDown01(object sender, RoutedEventArgs e)
    private void MouseDrainUp01(object sender, RoutedEventArgs e)
		    //Drain01.Background = Brushes.Green;
Er det noe i veien for å bruke dette oppsettet?
  • 5 måneder senere...
Bare et sidespørsmål; Hva om eventhandler kjører i en annen tråd? Da vil det jo selvsagt ikke henge, men man vil få cross-thread operations som må behandles med omhu når man setter verdier på formen igjen.
Så dette gjort på en applikasjon, klarer ikke helt skjønne hvorfor. Noen spesielle scenarioer dette er ønskelig/en god løsning?
Det er selvsagt mulig å starte en ny tråd i en eventhandler for å sikre at det ikke blir noe heng, men det er generelt brudd på adskillelse av logikk og presentasjon å gjøre noe slikt i en eventhandler.
En eventhandler må oppdatere state i et annet objekt. Dersom denne kosen skal skje asynkront så må objektet som skal oppdateres sørge for at dette blir gjort korrekt. En eventhandler bør sørge kun for at nødvendig data blir flyttet fra presentasjon til logikk og stoppe der, så skal logikken sørge for å oppdatere presentasjonen når operasjonen er ferdig, eller et eller annet kriterie sier at det er greit.
Kikk forøvrig på Reactive Extensions også.
