Hvilket prog. bruker den fila?
TBJ
Some of the spyware detection softwares (like Ad-aware and SpyBot) detects a component (IADhide.dll or IADhide3.dll) of F-Secure BackWeb as a suspicious file. F-Secure BackWeb uses technology licensed from BackWeb Technologies. The component named IADhide.dll or IADhide3.dll is used to suppress certain operations of BackWeb client (such as playing flash messages or connecting the server) when such operations are not desirable. BackWeb Client copies the file to one of several possible directories (temp or tmp directories, 'c:temp' or the client's version directory).
According to BackWeb Technologies the component contains no reporting capabilities of any kind and should not be considered spyware. Spyware detection companies have been contacted to remove this component from suspected files.
F-Secure Corporation considers this as a false alarm by spy ware detection software.
  • 2 uker senere...
