[Løst] Problemer med fwrite
Warning: fopen(text.txt) [function.fopen]: failed to open stream: Permission denied in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 10
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 11
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 12
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 13
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 14
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 15
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 16
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 17
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 18
Warning: fclose() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/PhpProject1/skjema2.php on line 19
Får opp denne feimeldingen når jeg bruker fwrite.. er problemet at jeg ikke har root access?
$fp =fopen("text.txt","w");
fwrite($fp,$_SESSION["navn"]."\n");
fwrite($fp, $_SESSION["email"]."\n");
fwrite ($fp, $_SESSION["telefon"]."\n");
fwrite ($fp, $_SESSION["adresse"]."\n");
fwrite ($fp, $_SESSION["kommentar"]."\n");
fwrite ($fp, $_SESSION["dropdown"]."\n");
fwrite ($fp, $_SESSION["svar"]."\n");
fwrite($fp,"\r\n");
fclose($fp);
Hvis text.txt er en eksisterende fil, betyr det at du ikker har skrivetilgang til filen.
Hvis text.txt ikke eksisterer, betyr det at du ikke har skrivetilgang til mappen du prøver å opprette filen i.
Legg inn en kontroll på om $fp er en resource eller er false, det er de to verdiene fopen returnerer
if (false !== ($fp =fopen("text.txt","w"))) {
 fwrite($fp,"\r\n");
 fclose($fp);
else
 echo 'Klarte ikke åpne eller opprette fila, sjekk skriverettigheter';
// alternativt
if ($fp !== false) {
// fwrite osv her
// eller
if (is_resource($fs)) {
 // fwrite osv her
Løser ikke problemet med manglende skriverettigheter, men hindrer å kjøre unødvendig kode. Dermed ingen "Warning: fwrite() expects ...", men man bør da skrive sin egen feilmeldingen i en else.
Endret av Crowly
Problemet er løst! Endret litt på rettigheter, men den skriver ikke ut disse.
Merkelig, er jo helt lik kode?
<form action="skjema.php" method="POST">
	<p>Navn</p> <input type="text" name="navn">
	<p>Email</p> <input type="text" name="kundemail">
	<p>Telefon</p> <input type="text" name="telefon">
	<p>Adresse</p><input type="text" name="adresse">
<p>Hva lurer du på?<br/>
<select size="1" name="dropdown">
<option>Produkter</option>
<option>Frakt</option>
<option>Reklamasjon</option>
<option>Annet</option>
</select>
<br />
<br />
	<td>Er du kunde?<br />
		Ja <input type="radio" name="svar" value="Ja" />
		Nei<input type="radio" name="svar" value="Nei" />
	</td>
	<br />
	<br />
<p>Comment</p><textarea wrap="OFF" name="kommentar" rows="6" cols="25"></textarea><br />
<br />
<input type="submit" value="Send" />
</form>
Jeg henter de fra index filen min. Har et form, som leder til neste side hvor detaljene blir skrevet ut. Hvor koden min skriver ut det kunden fyllte inn i skjema. Videre derifra kommer man til side tre hvor jeg skal drive med dette. Det er en skoleoppgave så jeg prøver å skjønne litt.
Endret av nepz
$_SESSION henter ikke ting i fra ett form. Du må se hvilken metode du bruker for sending, i dette tilfellet så er det to alternativer POST og GET, du bruker POST: method="POST"
Bruk $_GET eller $_POST, avhengig av hvilken metode skjemaet bruker, til å hente ut verdiene til feltene.
fwrite($fp,$_POST["navn"]."\n");
fwrite($fp, $_POST["email"]."\n");
fwrite ($fp, $_POST["telefon"]."\n");
fwrite ($fp, $_POST["adresse"]."\n");
fwrite ($fp, $_POST["kommentar"]."\n");
fwrite ($fp, $_POST["dropdown"]."\n");
fwrite ($fp, $_POST["svar"]."\n");
For å få tilgang til $_SESSION, så må session_start() kalles før noe annen output. Jeg pleier alltid å ha den helt først i php skriptet
<?php session_start();
// mer kode
Men det er ikke noen grunn til å bruke session her.
// mer kode
Da blir ikke text.txt lagret med informasjon :)
// mer kode
Tror du jeg må endre på denne?
Prøvde med denne og da dukker gammel informasjon opp også.
$fp =fopen("text.txt","a+");
Endret av nepz
Har du lest hva forskjellen på w og a+ er? Hvis ikke så ta en titt på http://www.php.net/manual/en/function.fopen.php og sjekk mode under parameter, forklarer bra forskjellen. Hvilken mode du skal bruke avhenger av hvordan du ønsker å bruke/skrive til fila.
Ser ut til at du har løst problemet med å skrive til fila, hvis ikke så vis hele innholdet i skjema2.php, så det blir enklere å se alt du gjør (eller prøver å gjøre).
Har du lest hva forskjellen på w og a+ er? Hvis ikke så ta en titt på http://www.php.net/m...ction.fopen.php og sjekk mode under parameter, forklarer bra forskjellen. Hvilken mode du skal bruke avhenger av hvordan du ønsker å bruke/skrive til fila.
Hadde en skriveleif i koden!
Bruker "w" nå! Takker for hjelp
</select>
<br />
<br />
	</td>
	<br />
	<br />
<p>Kommentar</p><textarea wrap="OFF" name="kommentar" rows="6" cols="25"></textarea><br />
Dropdown menyen, radioknappene og kommentar feltet vil ikke vises i .txt dokumentet.
Dette får jeg skrevet ut
Her er 3. siden min hvor informasjonen som ble fyllt ut i skjema skal lagres i et .txt dokument.
<?php
session_start();
echo "<br/>";
echo "<h3>Din henvendelse er sendt!</h3>";
$fp =fopen("temp/text.txt","w");
fwrite($fp,$_SESSION["telefon"]."\n");
fwrite($fp,$_SESSION["adresse"]."\n");
fwrite($fp,$_SESSION["kundemail"]."\n");
fwrite($fp,$_SESSION["svar"]."\n");
fwrite($fp,$_SESSION["dropdown"]."\n");
fwrite($fp,$_SESSION["kommentar"]."\n");
fwrite($fp,"\r\n");
fclose($fp);
Dette skal jo være riktig? Nå står jeg helt fast. Fikk beskjed av foreleser om å bruke $_SESSION gjennom oppgaven.
Endret av nepz
Igjen, informasjon sendt fra ett html form havner ikke i $_SESSION (så fremt man ikke gjør $_SESSION=$_POST;). Du bruker post og informasjonen er da tilgjengelig i $_POST. Hvorfor har du fått beskjed om å bruke en session? Kan være oppgaven krever bruk av $_SESSION, men det må være til andre ting enn å behandle informasjonen fra form'et.
Kommenter ut alt nedenfor session_start(); i skjema.php og legg til dette i stedet for
echo 'Innhold i $_SESSION:<br/>';
echo '<pre>';
print_r($_SESSION);
echo '</pre>';
echo '<br/>Innhold i $_POST:<br/>';
echo '<pre>';
print_r($_POST);
echo '</pre>';
Da får du se alle felter i $_SESSION og $_POST, og hvilke verdier de har, hvis de har noen. print_r() og var_dump() er veldige kjekke til debugging, og det bør plasseres i <pre> tagger slik at det blir mest mulig lesbart (spesielt på større array's).
Når du vet hvilke felter/variabler du skal bruke så kan du fjerne denne debugging koden igjen, og sette den andre tilbake.
Endret av Crowly
$_SESSION["comment"];$_REQUEST["kommentar"];
$_SESSION["dropdown"];$_REQUEST["dropdown"];
Hadde for mange semikolon!
Endret av nepz
Ikke bruk $_REQUEST, avhengig av konfigurasjon og php versjon så inneholder $_REQUEST alt fra $_GET, $_POST og evt. $_COOKIE. Du vet ikke hvor informasjonen kommer i fra. Gjør det heller til en vane å bruke $_POST, $_GET og $_COOKIE etter hvilket behov du har/hva du jobber med. Det gjør det også lettere for andre som leser koden, og se hvor man forventer at informasjonen skal komme/bli hentet fra.
Endret av Crowly
