Snapchat problem, andorid 2.2
Fik problem med at jeg kan godt motta bilder, men ikke ta selv og sende ut:
Søkte lit på nett å kom over dette:
http://community.giffgaff.com/t5/Help-Ask-the-community-got-stuck/Snapchat-problems/td-p/6606158
This will fix errors on apps and sites with iPhones (including ios6)
( note if you don't have any profile installed go straight to reset network settings)
REMOVE ANY PROFILE FIRST
Go to
Settings
General
Profiles ( near the bottom)
Click profiles and remove any that are there
NOW RESET NETWORK SETTINGS
go to
Settings
General
Reset ( at the bottom of the page)
And click reset network settings
Once the phone restarts go to
Settings
General
Mobile data ( or celular or celular data )
Mobile(or celular) data network ( scroll down if not visible)
And change the mobile data and mms apn 's
From idata.o2.co.uk
To giffgaff.com
dont click reset
ADDED FIX IF THE ABOVE DOSNT WORK
install the
onavo extend app or
Snappli app
from the Apple Store and install the giffgaff profile via the apps
IMPORTANT... Skygo and tvcatchup won't work with the onavo profile installed
Skygo won't work but tvcatchup will with the snappli profile installed
Men det der er til iphone 4 og det fungerte hos han, men noen som vet hva jeg må gjøre på min tlf?
Er en LG optimus one P500
