[Løst] Exitcode 128 (sftp/ssh)
Hei og god dag.
Jeg har et lite problem med at jeg ikke greier og logge inn på sftp med root brukeren, jeg greier fint og logge inn via ssh men med sftp så får jeg bare "
Status: Kobler til x.x.x.x...
Respons: fzSftp started
Kommando: open "[email protected]" 22
Kommando:
Status: Connected to  x.x.x.x
Feil: Connection closed by server with exitcode 128
Feil: Kunne ikke koble til serveren
root@Debian-60-squeeze-64-minimal ~ # /usr/sbin/sshd -d -p 1234
debug1: sshd version OpenSSH_5.5p1 Debian-6+squeeze2
debug1: read PEM private key done: type RSA
debug1: Checking blacklist file /usr/share/ssh/blacklist.RSA-2048
debug1: Checking blacklist file /etc/ssh/blacklist.RSA-2048
debug1: private host key: #0 type 1 RSA
debug1: read PEM private key done: type DSA
debug1: Checking blacklist file /usr/share/ssh/blacklist.DSA-1024
debug1: Checking blacklist file /etc/ssh/blacklist.DSA-1024
debug1: private host key: #1 type 2 DSA
debug1: rexec_argv[0]='/usr/sbin/sshd'
debug1: rexec_argv[1]='-d'
debug1: rexec_argv[2]='-p'
debug1: rexec_argv[3]='1234'
Set /proc/self/oom_adj from 0 to -17
debug1: Bind to port 1234 on 0.0.0.0.
Server listening on 0.0.0.0 port 1234.
debug1: Bind to port 1234 on ::.
Server listening on :: port 1234.
debug1: Server will not fork when running in debugging mode.
debug1: rexec start in 5 out 5 newsock 5 pipe -1 sock 8
debug1: inetd sockets after dupping: 3, 3
Connection from xxxxxx port 62454
debug1: Client protocol version 2.0; client software version PuTTY_Local:_Jan__8_2012_14:40:35
debug1: no match: PuTTY_Local:_Jan__8_2012_14:40:35
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.5p1 Debian-6+squeeze2
debug1: permanently_set_uid: 103/65534
debug1: list_hostkey_types: ssh-rsa,ssh-dss
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: client->server aes256-ctr hmac-sha1 none
debug1: kex: server->client aes256-ctr hmac-sha1 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST_OLD received
debug1: SSH2_MSG_KEX_DH_GEX_GROUP sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_INIT
debug1: SSH2_MSG_KEX_DH_GEX_REPLY sent
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: KEX done
debug1: userauth-request for user root service ssh-connection method none
debug1: attempt 0 failures 0
debug1: PAM: initializing for "root"
debug1: PAM: setting PAM_RHOST to "xxxxxx.customer.lyse.net"
debug1: PAM: setting PAM_TTY to "ssh"
Failed none for root from xxxxxx port 62454 ssh2
debug1: userauth-request for user root service ssh-connection method password
debug1: attempt 1 failures 0
debug1: PAM: password authentication accepted for root
debug1: do_pam_account: called
Accepted password for root from xxxxxx port 62454 ssh2
debug1: monitor_child_preauth: root has been authenticated by privileged process
debug1: PAM: establishing credentials
debug1: Entering interactive session for SSH2.
debug1: server_init_dispatch_20
debug1: server_input_channel_open: ctype session rchan 256 win 2147483647 max 16384
debug1: input_session_request
debug1: channel 0: new [server-session]
debug1: session_new: session 0
debug1: session_open: channel 0
debug1: session_open: session 0: link with channel 0
debug1: server_input_channel_open: confirm session
debug1: server_input_channel_req: channel 0 request [email protected] reply 0
debug1: session_by_channel: session 0 channel 0
debug1: session_input_channel_req: session 0 req [email protected]
debug1: server_input_channel_req: channel 0 request subsystem reply 1
debug1: session_input_channel_req: session 0 req subsystem
subsystem request for sftp
debug1: subsystem: exec() /usr/lib/openssh/sftp-server
debug1: Received SIGCHLD.
debug1: session_by_pid: pid 18732
debug1: session_exit_message: session 0 channel 0 pid 18732
debug1: session_exit_message: release channel 0
debug1: session_close_by_channel: channel 0 child 0
debug1: session_close: session 0 pid 0
debug1: channel 0: free: server-session, nchannels 1
Connection closed by xxxxxxx
debug1: do_cleanup
debug1: PAM: cleanup
debug1: PAM: closing session
debug1: PAM: deleting credentials
Transferred: sent 2680, received 1776 bytes
Closing connection to xxxxxxxx port 62454
Det fungerer fint med andre brukere men ikke root brukeren.
Endret av wtf1337
sjekke sshd_conf om rootlogin er disabled? Tror de fleste distroer kjører det som standard.
Her er configen:
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
Endret av wtf1337
Enkelte nedstrippede distribusjoner bruker dropbear til ssh, den støtter ikke sftp. Mener du at det funket før en reboot, men ikke etter? Det er vanskelig å tro.
Det fungererte helt fint, Har faktisk en helt lik instalasjon som det fungerer på.
Som jeg har skrevet i førstepost: "Det fungerer fint med andre brukere men ikke root brukeren."
Høres veldig merkelig ut. Så dette er en standard debian-installasjon, og du har flere av dem. På denne funker ssh login både med rot og med vanlig bruker, men sftp funker kun med vanlig bruker, mens annen identisk debian installasjon du har tillater sftp med både vanlig bruker og rot. Ikke bare det men problemet oppstod etter en reboot, og har vedvart siden. Har jeg forstått deg riktig?
Helt korrekt :)
Hm, kan du poste /root/.bashrc ?
# ~/.bashrc: executed by bash(1) for non-login shells.
# Note: PS1 and umask are already set in /etc/profile. You should not
# need this unless you want different defaults for root.
# PS1='${debian_chroot:+($debian_chroot)}\h:\w\$ '
# umask 022
# You may uncomment the following lines if you want `ls' to be colorized:
export LS_OPTIONS='--human --color=always'
# eval "`dircolors`"
alias ls='ls $LS_OPTIONS'
alias ll='ls $LS_OPTIONS -l'
alias l='ls $LS_OPTIONS -lA'
# Some more alias to avoid making mistakes:
# alias rm='rm -i'
# alias cp='cp -i'
# alias mv='mv -i'
export LC_ALL="nb_NO.utf8"
export LANG="nb_NO.utf8"
Prøv å kommentere bort linjene som begynner med export, og se om det hjelper.
Tusen takk, Jeg hadde faktisk glemt helt ut at jeg hadde på norsk tegnsett. Det var bare ment som en test (irssi). Som jeg glemte på over natten.
Uansett takk.
Endret av wtf1337
