Playstation 4 - Generell diskusjon
Latias
1 268 stemmer
  1. 1. Blir Playstation 4 en større suksess enn sin forgjenger?
Gjest Slettet+130498
Er vel en av tingene som blir fikset når d1 patchen blir sluppet på torsdag. Men, hvordan føles spillet? Og ikke minst kontrollen, eller bruker du ratt og pedaler?
Vurderer seriøst Project cars, kom gjerne med tilbakemeldinger på både spill og evt forslag/erfaringer på ratt. Jeg sliter med plass der jeg spiller, så skal jeg ha ratt må jeg ha et sete/rattstand siden jeg sitter i Saccosekker/FatBoys uten tilgjengelig bord. Min samboer karnøfler meg dersom noe slikt som dette dukker opp:
så da gjenstår enten Playseat Challenge:
eller en modifisert Ottoman:
. Anyone?
Jeg har et G27 som får holde en liten stund til. Er veldig keen på et fult fanatec sett, men bare rattet alene koster jo i nærheten av 1000€ :huh:
http://www.reddit.com/r/pcars/comments/34xb40/im_afraid_ps4_version_will_give_me_migraines_ps4/
The Project Cars developers have responded on the ghosting issue on PS4:
"It's not a bug. It's a side effect of the way we do AA on PS4, and is arguably a good thing (hear me out!). It's there, and very noticeable from static images of non-direct feed footage especially, but also undeniably in the game itself (mainly when paused). I spotted it and reported it as soon as it got checked in long ago (so we didn't "miss it" as many would have you believe).
However, I also "spotted" that the PS4 version has really lovely image quality, a very smooth and slightly soft (not low res!), "non-gamey" look, which is very natural, and (imo!) rather fantastic, due to this very clever AA approach. It also greatly minimises the distant "shimmer" you often see in console racing games, which is a side effect of low quality AA on thin vertical objects such as fences.
So yes, the ghosting effect is there, if you look hard enough. The advantages far outweigh this small disadvantage however. Notwithstanding that, if customer feedback demands it, we have a plan to add a UI slider in a future update, which will enable you to tune out the ghosting, at the expense of more aliasing and distant shimmer."
Hmm...det var ei løysing eg ikkje hadde rekna med. Hadde forventa at Project Cars skulle bli knall på PS4. Får sjå spillet ann. Er jo forsatt håp om at det vil levere.
Witcher 3 blir nok heller på PC og kjøpt via GoG.
