Rider of Reason Skrevet 20. januar 2013 Rapporter Del Skrevet 20. januar 2013 The CPU that will find its home in the new PS4 is said to be sporting a new "Jaguar" technology from AMD, which features low-power processor cores that are designed for the entry-level laptop and tablet market. This is a perfect solution as console power consumption is a huge problem, and it looks like it'll be solved by the hardware in the PlayStation 4. The PC bound Jaguar technology from AMD is headed to the consumer market in a quad-core design, but consoles are looking to amp this up with some customizations to the overall design. The PlayStation 4, or 'Orbis', will aos feature a high-end Radeon GPU solution. We should be looking at the mobile side of AMD's GPU plans, with the "Pitcairn" design, or the Radeon 7970M design. The 7970M is clocked at 850MHz, and feature 20 "Graphics Core Next" compute units, but the Orbis will take 10% off those specs - reducing the GCN compute unit count to 18, and the clock speed down to 800MHz. Read more at http://www.tweaktown.com/news/27977/leakedtt_rumored_specs_on_the_playstation_4_set_to_impress/index.html#l1uwIV3CiQLzSHKx.99 http://www.tweaktown.com/news/27977/leakedtt_rumored_specs_on_the_playstation_4_set_to_impress/index.html Hva tenker dere, høres dette troverdig ut? Kan se for meg at den er behagelig. Hvordan klarer du det? Den ser fryktelig ubehagelig ut for meg. Grepene er altfor lange og vil bare være i veien, med mindre du er 2.30m meg gigant-hender. Knappene er ubehagelig plassert, og den typen runde bulende knapper av det materialet synes jeg er forferdelig. Er slike knapper man ser på billige imitasjonsspaker. Var ikke klar over at Sony vurderte en slik kontroller, men er kjempeglad for at de droppet den. Det er den styggeste kontrolleren jeg har sett. Lenke til kommentar
Allt í lagi Skrevet 20. januar 2013 Rapporter Del Skrevet 20. januar 2013 Det er der vel kopiert fra Eurogamers artikkel om PS4, det er ofte snakk om at det er 80-90% korrekt. Er en del snakk om en Steamroller CPU istedet for Jaguar, men det sies også at Steamroller ikke er ferdig designet før i slutten av 2013, og at det dermed blir vanskelig å bruke den i PS4. Men det er visstnok en hakket bedre CPU. Angående boomerangkontrolleren, ord blir fattige: Lenke til kommentar
Danek Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Apropos kontroller, håper for guds skyld sony designer en ny kontroller. sixaxis begynner å dra litt på årene. Lenke til kommentar
SD88 Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Apropos kontroller, håper for guds skyld sony designer en ny kontroller. sixaxis begynner å dra litt på årene. Det går rykter om at de skal designe en helt ny kontroll, noe alla kontrollen til WiiU, altså med skjerm etc. blir spennende å se hva de kommer med. Lenke til kommentar
SD88 Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 http://www.tweaktown...ress/index.html Hva tenker dere, høres dette troverdig ut? Tviler sterkt på at dette stemmer. Produksjonskostnadene vil være veldig høye. Hvis det stemmer, noe som selvsagt er fult mulig, så vil den iallefall ligge i en veldig høy prisklasse. Lenke til kommentar
Bytex Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Det bildet ser hvertfall ut som et metro-seksuellt apple-produkt..tviler på at det er noe annet enn en illustrasjon. Lenke til kommentar
Allt í lagi Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Tviler sterkt på at dette stemmer. Produksjonskostnadene vil være veldig høye. Hvis det stemmer, noe som selvsagt er fult mulig, så vil den iallefall ligge i en veldig høy prisklasse. Dette er nok omtrent 80-90% riktig, siden at Eurogamer ikke skriver en tech-artikkel om dette uten at de vet noe. Samme skjedde med Vita før offisielle specs, og det var tilnærmet spot on. Lanseringspris ryktes å legge seg mot $399, som med grådige norske forhandlere sikkert betyr 3500-4000 NOK. Lenke til kommentar
Allt í lagi Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Det bildet ser hvertfall ut som et metro-seksuellt apple-produkt..tviler på at det er noe annet enn en illustrasjon. Det er konseptkunst som har florert i mange år. Men hvem vet, å designe i samme tråd som Apple er nok lurt for tiden. Lenke til kommentar
SD88 Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Dette er nok omtrent 80-90% riktig, siden at Eurogamer ikke skriver en tech-artikkel om dette uten at de vet noe. Samme skjedde med Vita før offisielle specs, og det var tilnærmet spot on. Lanseringspris ryktes å legge seg mot $399, som med grådige norske forhandlere sikkert betyr 3500-4000 NOK. Med slike spec's blir jeg overrasket hvis den ligger på 3500-4000kr her i Norge. Synes det virker litt for billig. Selv en ps3 koster i dag alt fra 1500-2000kr+, men vi får se Lenke til kommentar
Allt í lagi Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 Med slike spec's blir jeg overrasket hvis den ligger på 3500-4000kr her i Norge. Synes det virker litt for billig. Selv en ps3 koster i dag alt fra 1500-2000kr+, men vi får se PS3 var dyr fra starten og har teknologi som ikke brukes andre steder(Cell). Dette vil ikke bli tilfellet med PS4. Lenke til kommentar
SD88 Skrevet 21. januar 2013 Rapporter Del Skrevet 21. januar 2013 PS3 var dyr fra starten og har teknologi som ikke brukes andre steder(Cell). Dette vil ikke bli tilfellet med PS4. Det er greit nok, men en slik prislapp tror jeg ikke på før jeg ser den Det hadde for all del ikke gjort noe, men vi får se hva det blir til Lenke til kommentar
Latias Skrevet 5. februar 2013 Forfatter Rapporter Del Skrevet 5. februar 2013 Her er de viktigste PlayStation 4-ryktene Sonys neste konsoll avsløres kanskje om få uker. Hva kan du forvente? PlayStation 3 debuterte på markedet i november 2006. I likhet med hovedkonkurrent Xbox 360 har den hatt et langt liv, rikt på gode spill, men nå er det snart på tide at systemet pensjoneres og erstattes med noe nytt. Vi vet at både Microsoft og Sony jobber med sine nestegenerasjonskonsoller, og at dette sannsynligvis er året begge blir annonsert. Ja, kanskje til og med lansert. Fremtiden introduseres 20. februar Sony har annonsert at vi vil få «se fremtiden» på et arrangement som finner sted allerede 20. februar. Selv om de ikke spesifikt har sagt at de vil annonsere sin neste PlayStation-konsoll, er det dette alle forventer. Vi regner imidlertid ikke med å få noen dyptgående presentasjon av konsollen og spillene til den; den japanske giganten vil nok spare mye av kruttet til sommeren og den amerikanske spillmessen E3. En annonsering så tidlig på året tyder uansett på at neste PlayStation, som har fått kodenavnet Orbis, vil lanseres i løpet av 2013. Om dette gjelder Europa er et annet spørsmål. PlayStation 3 debuterte som sagt i november 2006, men det var ikke før i mars året etter at systemet ble tilgjengelig i vår del av verden. Ifølge en rapport fra Edge vil PlayStation 4 bli lansert på samme måte. Amerikanerne og japanerne skal ifølge deres kilder få tilgang på neste generasjon før jul, mens vi må vente til våren 2014. Grunnen skal være at distribusjon i det europeiske markedet er mer komplisert. Så hva slags kreasjon er det egentlig ingeniørene har pønsket ut i Sonys laboratorier? All tilgjengelig informasjon om PlayStation 4 er basert på lekkasjer, rykter og spekulasjon, og må dermed tas med mer enn én klype salt. Men mye er likevel såpass troverdig at vi med all sannsynlighet kan trekke noen konklusjoner. Selv om Sony ikke har annonsert konsollen sin enda skal vi tross alt huske på at det i skrivende stund sitter hundrevis, om ikke tusenvis, av spillutviklere verden over, og jobber med spill til systemet. Hemmelighetskremmeriet er selvsagt stort, men det høye antallet involverte gjør det svært vanskelig å holde på hemmelighetene. Lavere strømforbruk, høyere stabilitet? Et siste element som er viktig å ta med, er strømforbruk. Dette har ikke bare med økonomi å gjøre, men påvirker også konsollens stabilitet. Jo mer strøm, jo mer varme, og jo større blir sjansene for maskinvareproblemer. Leadbetters analyse av informasjonen som har kommet frem indikerer at PlayStation 4 vil trekke cirka 150 watt, mens forgjengeren trakk omtrent 200 watt ved lansering. Dermed er sjansene langt mindre for den typen omfattende maskinvareproblemer vi så tidlig i dagens generasjon. På tross av at informasjonen nevnt over beskrives som nøyaktig av kilder med tilgang til systemet, skal vi huske at det er langt mer enn de individuelle komponentene en konsoll er satt sammen av som avgjør den faktiske ytelsen, og Sony har nok også visse hemmeligheter som ikke har blitt avslørt. Vi vil nok i tillegg oppleve at spill som kommer til flere plattformer holdes tilbake av den svakeste plattformens ytelse, slik vi ser i dag. At både Sony og Microsofts nye konsoller vil ta store steg fremover er imidlertid helt klart, selv om spranget neppe vil bli like stort som ved forrige generasjonsskifte. Lenke til kommentar
Konnis Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 Håper at PS4 blir litt mer lydløs ihvertfall, og forhåpentligvis vil den være bakoverkompatibel også. Sitter her med en gammal PS3 som bråker mer enn støvsugeren etter en drøy halvtime med spilling. Lenke til kommentar
KatrinaS Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 Håper at PS4 blir litt mer lydløs ihvertfall, og forhåpentligvis vil den være bakoverkompatibel også. Sitter her med en gammal PS3 som bråker mer enn støvsugeren etter en drøy halvtime med spilling. Den er mest sannsynlig ikke bakoverkompatibel. I hvertfall i følge pachter. Lenke til kommentar
Chocolate-Monster Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 Du har sikkert en gammel PS3 da. De nyere bråker ganske mye mindre. Man hører dem bare litt om man spiller på lydløst Ihvertfall min er sånn. Lenke til kommentar
JoseCuervo Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 Håper at PS4 blir litt mer lydløs ihvertfall, og forhåpentligvis vil den være bakoverkompatibel også. Sitter her med en gammal PS3 som bråker mer enn støvsugeren etter en drøy halvtime med spilling. Ps4 blir så powerfull at dem kommer til å bli solgt med hørselsvern. Lenke til kommentar
IcedInsanity Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 ...and the journey continues.. Lenke til kommentar
Okapi Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 PS3 var dyr fra starten og har teknologi som ikke brukes andre steder(Cell). Dette vil ikke bli tilfellet med PS4. Det er jo nettopp det som gjør det lettere å spekulere på prisen på denne saken. Hvor mye må du ut med for en PC med slike specs? Lenke til kommentar
LarZen Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 Håper at PS4 blir litt mer lydløs ihvertfall, og forhåpentligvis vil den være bakoverkompatibel også. Sitter her med en gammal PS3 som bråker mer enn støvsugeren etter en drøy halvtime med spilling. Om det er den feite PS3 du har så er det nok ikke så rart den bråker i dag, er vel et under at den fortsatt virker. Den var stille når den kom i salg men etter som kjølepastaen i den blir dårligere (noe som er et kjent problem) så øker temperaturen og viftene må jobbe mer. Det kombinert med kulelagrene i viftene blir dårligere over tid gjør at du sitter igjen med en PS3 som bråker voldsomt. Dem nye PS3 maskinene er så si lydløse om en ser bort ifra bluray drevet. Når en maskin enten det er PS3 eller what ever, starter å jobbe så mye så burde det gå noen varsel lamper og en må sende maskinen til service eller kaste den på dynga å kjøpe en ny. 1 Lenke til kommentar
Okapi Skrevet 15. februar 2013 Rapporter Del Skrevet 15. februar 2013 Her har vi en laptop med skjermkortet som omtales i ryktene, 8 GB RAM, Blu-ray, og en high end laptop-prosessor fra AMD; med andre ord nesten samme innhold. Den koster drøye 10k. Mulig man kan krympe disken litt, og skjermen trenger man selvsagt ikke, ei heller Windows, så der får man vel barbert av et par tusenlapper. Likevel, får man dette ned til 3-4k? Må isåfall subsidieres relativt heftig. Lenke til kommentar
