[Løst] Problem med programintaller i Ubuntu 12.04
andas
programinstaller not able to start
Hi,
I'm new to linux.
I have an issue with the program-installer.
Its not able to start.
I get the following error message when opening:
"Could not determine the package or source package name"
Executable path;:
/usr/share/software-center/update-software-server-agent
Try the following two commands in a terminal:
sudo rm /var/lib/apt/lists/*
sudo apt-get update
After this your program-installer should work again.
Takk for kjapt svar. Det funket desverre ikke.
Se fra terminal
administrator@ubuntu:~$ sudo rm /var/lib/apt/lists/*
[sudo] password for administrator:
rm: cannot remove `/var/lib/apt/lists/partial': Is a directory
administrator@ubuntu:~$ suro apt-get update
No command 'suro' found, did you mean:
Command 'sur' from package 'subtle' (universe)
Command 'sudo' from package 'sudo' (main)
Command 'sudo' from package 'sudo-ldap' (universe)
Command 'surf' from package 'surf' (universe)
suro: command not found
administrator@ubuntu:~$ sudo apt-get update
E: Feil på 5 i kildelista /etc/apt/sources.list (fortolkning av nettadressen)
E: Kan ikke lese kildlista.
Du kan prøve å fjerne software-center, for så å installere på nytt:
sudo apt-get purge software-center
sudo apt-get install software-center
sudo apt-get update && sudo apt-get upgrade
Edit:
Du kan eventuelt installere Synaptic Package Manager og se om denne fungerer:
sudo apt-get install synaptic
Endret av Omnithunder
Edit:
Nå er det i orden
