TV 2 Sumo på iMac. Alle andre PCer lagger når man streamer/folk ser på TV.
Så har hatt et problem, med at nettet generelt lagger når folk ser på TV2 Sumo på iMacen. Vi pusser opp osv, har ikke TV annet enn TV2 Sumo som vi har betalt for midlertidig. Tinger er at det er helt umulig å spille spill når folk ser på iMacen, noe som skjer ekstremt ofte.
Basically så er problemet det at iMacen (TV2 Sumo) tar hele båndbredden og gjør det til et reint helvete for andre....
Er er infoen jeg har anngående dette, altså prossessen (mulig det er til hjelp, tar det med), står på Engelsk da dette ble postet på et annet forum.
So I've been having this problem since end-January, I guess it started when we payed to watch TV on the iMac (we stream net-tv on it). NOTE, I've send countless tickets, had a long discussion with 2 different Riot employees since February, and we're still trying to find the cause. I'm beyond frustrated, this creates aggression problems, literally drives me crazy.
Ok, this is what happens ingame whenever someone watches TV on the iMac:
I get 200-500 ms lagspikes, uncontrollable lag. I can walk fine for a sec, then suddenly stand still for 1-5 seconds, then "magically" appear where I pressed. So whenever some fights breaks out, I often engage, it "freezes", basically lagging extremely then I...am dead.
It's beyond retarded to last hit. I think you get the idea.
Specs:
Inter® Core™ i7 - 2630QM CPU @2.00 Ghz (Turbo boost to 2.9 Ghz).
Windows 7
GeForce GT 540M
8GB ram
64 bit Operation System
Information:
1. This TV thingy is something you stream via the internet. You login on their website and stream it from there.
2. That means, I can do it on my PC as well. I use a ASUS N53SN (I think it was), a laptop. I tried to run the TV, (stream) on my PC while playing as well. I got a no lag, just a small increase from time to time because it used my ram. I usually have 45-50 ms. With it I had 49-60 ms. No biggie.
So basically it only lags IF I run it on the iMac. We got two different switches. Our internet is connected to the router, which is connected to a switch. The iMac is connected to a different switch because it's in a different room. I've tried to change the switches, but it's all the same.
I've tried:
1. Disable Windows Defender and Windows Firewall.
2. Disabled my Antivirus.
3. Changing DNS server to a public one.
4. Downloaded the IPv6 Fix: http://support.microsoft.com/kb/929852
5. Disabled Peer to peer.
6. Remove Panda Media Booster.
7. Portforwarded every neccessary port.
Thats all I remember now.
TLDR; Read it, you cannot write anything without reading every single piece of information.
Please dont hestitate to ask if you got questions. If this gets fixed, I would be so happy that I cannot explain it. This have created so much frustration, hatred and so on, past the half year. You never know when you ****ing sister decides to watch some TV in the middle of your game, just screwing you up bigtime. Just, if you're confused. I run LoL on my own Laptop.
Again, if you do decide to answer, thank you, from the bottom of my heart.
Har prøvd alt mulig, vet at TV2 Sumo bruker Silverlight som flere har problemer med, men det lagger ikke selv på streamen, men hos alle andre (vi har 2 andre pcer, min brors og min). Dette merkes spesielt når vi spiller, og i dette tilfelle League of Legends.
Forhåpentligvis finnes det en løsning. Føler meg helt hjelpesløs etter å ha prøvd å fikse dette problemet gjennom countless med tickets fra support systemet til LoL gjennom året.
Takk =)
Hva slags båndbredde har du med internetlevrandøren din?
Er det slik at Macen bruker TP kabel mens resten av pcene bruker trådløs?
Om det er snakk om flere pcer dette, så høres heller det ut som det er hastigheten som er problemet mot internett.
Vi har Ventelo og har 10-12 Mbps ned, og 600 kbps opp.
Vi har ikke trådløs, og alle bruker kabel.
Når man ser på nett-tv (TV2 sumo) på iMacen, lagger alle andre. Merkes spesielt når vi spiller og har 200-500ms/ping lagspikes.
Endret av jallan
