Den store SimCity-tråden! [Stabile servere][Fortsatt kraftig bugget]
EA sin kundeservice og info er jo hinsides dårlig. G2Play , hvor jeg har forhåndsbestilt, er bedre i så måte:
Dear Customers,
We are terribly sorry to inform you that due to official publisher issues with the "SimCity EA Origin Key" product activation and its versions not all languages are still currently available for it in the fully functional multilingual version as earlier described in a product at this point.
Since we do not want to mislead you and send you a version without all mentioned languages included while EA Origin is sorting that problem out, we would like to offer you 3 possibilities until the problem is figured out and solved on their part:
waiting for EA Origin solution
getting reward points for the same value (+ addition 500 reward points for the inconvenience)
getting the full refund
Please, contact G2PLAY 24/7 support for any questions. Thank you for your patience and understanding!
"Hi Mayors --If you get stuck on "CHECKING FOR UPDATES" you should delete all files in your User Data.
If you have a desktop shortcut you can right click the icon and select PROPERTIES then delete all files in the User Data folder.
If you launch through Origin go to C:\Program Files (x86)\Origin Games\SimCity\SimCityUserData and delete all files in the User Data folder.
Then run the game again and you should get past that screen.
Note: The recovery tool will not resolve this issue, so please use the directions above."
Skal man slette alt ?
