Fått en HP Compaq 6910p av jobb - brukende til mediasenterPC?
andas
Hei har fått en slik på jobb. tenkte å legge inn Ubuntu og kjøre den opp mot tven-Den har følgende specs
Kan jeg kjøre HD på denne? Det er bare VGA ut, men kjører lyd og bilde seperat uansett. Hva trenger jeg av utstyr for å koble til HDMI på TVen?
General
Packaged Quantity 1.0 .System Type Notebook .OS Provided Microsoft Windows XP Professional .Service & Support 3 years warranty .Notebook type Thin-and-light (4-6 lbs.) .Screen type Widescreen .Wireless capabilities Bluetooth,
IEEE 802.11b,
IEEE 802.11g .Processor / Chipset
CPU Intel Core 2 Duo T7300 / 2.0 GHz .Number of Cores Dual-Core .Cache L2 cache - 4.0 MB .64-bit Computing Yes .Front Side Bus 800.0 MHz .Chipset Mobile Intel PM965 Express .Platform Technology Intel Centrino Pro .Memory
RAM 2.0 GB ( 2 x 1 GB ) .Max RAM Supported 4.0 GB .Technology DDR2 SDRAM .Speed 667.0 MHz .Form Factor SO DIMM 200-pin .Slots Qty 2 .Empty Slots 0.0 .Storage
Floppy Drive None .Hard Drive 160.0 GB HDD / 5400.0 rpm .Interface Serial ATA-150 .Optical Drive DVD±RW (+R DL) / DVD-RAM .Read Speed 24x (CD) / 8x (DVD) .Write Speed 24x (CD) / 4x (DVD±R) .Rewrite Speed 10x (CD) / 2x (DVD-RW) / 2.4x (DVD+RW) / 2x (DVD-RAM) .Optical Drive (2nd) None .Hard drive type Portable .Environmental Parameters
Environmental standards EPEAT Silver,
EPA Energy Star .Min Operating Temperature 32.0 °F .Max Operating Temperature 95.0 °F .Humidity Range Operating 10 - 90% .Shock Tolerance 125.0 g @ 2ms half-sine pulse (operating) / 200.0 g @ 2ms half-sine pulse (non-operating) .Vibration Tolerance 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating) .Display
Type 14.1 in .Max Resolution 1280 x 800 ( WXGA ) .Widescreen Yes .Features Anti-glare .Audio & Video
Graphics Processor ATI Mobility Radeon X2300 - 128.0 MB .Sound Microphone .Codec AD1981HD .Compliant Standards Sound Blaster Pro,
High Definition Audio .Input
Type Keyboard,
Touchpad .Communications
Wireless Bluetooth 2.0 EDR,
802.11a/b/g .Wireless Controller Intel Wireless WiFi Link 4965AG .Network Interface Gigabit Ethernet .Remote Management Protocol SNMP .Compliant Standards IEEE 802.3x,
IEEE 802.3z,
IEEE 802.1p,
IEEE 802.3u,
Wi-Fi CERTIFIED,
IEEE 802.3,
IEEE 802.3i .Modem
Protocols & Specifications ITU V.29,
ITU V.22,
ITU V.250,
ITU V.27ter,
Bell 103J,
ITU V.34,
ITU V.32bis,
ITU V.22bis,
ITU V.17,
Bell 212A,
ITU V.251,
ITU V.32,
ITU V.8bis,
ITU V.80,
ITU T.30,
ITU V.21,
ITU V.92,
ITU V.23 .Fax Compatibility G3 .Max Transfer Rate 56.0 Kbps .Battery
Technology 6-cell Lithium ion .Capacity 55.0 Wh .AC Adapter
Voltage Required AC 120/230 V ( 50/60 Hz ) .Connections & Expansion
Slots 1.0 x Smart Card ( 0.0 free ),
1.0 x CardBus ( 1.0 free ),
2.0 x Memory ( 1.0 free ) .Interfaces 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm,
1.0 x IEEE 1394 (FireWire) - VGA - 15 pin HD D-Sub (HD-15),
1.0 x Battery - Input - RJ-45,
1.0 x Hi-Speed USB - Line-out/headphones - IrDA,
1.0 x Docking / port replicator - Phone line - RJ-11,
1.0 x Display / video - Ethernet 10Base-T/100Base-TX/1000Base-T - 7 pin mini-DIN,
1.0 x Modem - Mini-phone stereo 3.5 mm,
1.0 x Infrared - 4 pin USB Type A,
3.0 x Network,
1.0 x Microphone,
1.0 x Audio
  • 5 måneder senere...
Oi, velkommen til 2001! :p Digger tastaturet.
Neida, fungerer helt greit som server eller avspiller (skjønt det gjør en middels kjapp telefon også). Kommer til å slite med å kode høy oppløsning i real-time (om du prøver å streame et format tv-en ikke støtter). Men er helt kurant til å sette ved siden av routeren, mens du kobler tv-en til nettverket, for eksempel.
