Ekstrent Skrivebord
MorganW
Fra http://www.microsoft.com/windowsxp/remoted...desktop/faq.asp
Q. What port does Remote Desktop use? Does everything go over port 3389?
A. Port 3389 is the only port you need to open. Sound will attempt to be streamed through User Datagram Protocol (UDP) first. If no port is available for UDP, sound will stream through a virtual channel in Remote Desktop Protocol, which uses port 3389.
