Bebeluv Skrevet 7. august 2010 Rapporter Del Skrevet 7. august 2010 Om jeg ikke husker helt feil, er det vel snakk om at en skredder skal ta mål fra kroppen din også? Lenke til kommentar
Deneb Skrevet 7. august 2010 Rapporter Del Skrevet 7. august 2010 Ser ikke store forskjellen på at en måler seg selv eller om skredderen gjør det. Klart det ikke er helt det samme, men når det er snakk om litt for lange armer så. Han sa jo ikke at det var skreddersydd. Lenke til kommentar
fkm Skrevet 7. august 2010 Rapporter Del Skrevet 7. august 2010 (endret) Bespoke er jo bare et finere ord for at du får velge passform, størrelse/lengde og stoff selv, og det får du jo vitterlig på tailorstore. Feil. Jeg quoter wikipedia: Bespoke versus made-to-measure Between the extremes of bespoke and ready-to-wear has existed, since the end of the 19th century,[n 4] a "grey area of garments for which the customer was measured, but that were then made up to the closest standard size, often, but by no means always, in a factory."[6] The distinction made here is between bespoke, created without use of a pre-existing pattern, and made to measure, which alters a standard-sized pattern to fit the customer.[7] Technological change makes this distinction more subtle, since "fittings are increasingly required for both bespoke and made-to-measure; a bespoke service may require an individually-cut pattern, which is then kept should further suits be required, and now made-to-measure measurements are often stored too, on a computer. Even hand-work, often cited as a benchmark of bespoke, is now increasingly found in made-to-measure garments, while machine-making plays some part in the creation of most bespoke suits".[5] For å gjøre det klart, Tailorstore er made to measure, og på ingen måte bespoke. Han sa jo ikke at det var skreddersydd. Skreddersydd er det norske begrepet for bespoke, kløne. Endret 7. august 2010 av fkm Lenke til kommentar
ertestuing Skrevet 7. august 2010 Rapporter Del Skrevet 7. august 2010 Da hadde man fått pakke fra RL. Ble under 1000 kr for to piqueer, og tok under 2 uker. Og hvis noen lurte så er størrelsene nøyaktig lik det som selges i Norge Lenke til kommentar
Babyloner Skrevet 7. august 2010 Rapporter Del Skrevet 7. august 2010 Så et par sko hos Tommy Hilfiger på Eger i Oslo idag. Desverre hadde de ikke str...noen som vet hvor jeg kan få kjøpt hilfiger sko, butikk eller på nett? Lenke til kommentar
Paisley Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Skulle gjerne hatt en link til en nettside som selger denne type sko eller navnet på denne typen. Utifra bildet ser det ut som en brun dress-sko uten noe særlig hel og jeg kunne godt tenke meg slike. Noen? Lenke til kommentar
EirikBrand Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Da kan vel jeg også spørre om hvor den jakken er å få kjøpt? Lenke til kommentar
thrice Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Skoene ser ut til å være normale brune oxfords med cap-toe. Du finner et godt utvalg på www.herringshoes.co.uk Jakken er en vanlig navy losjakke/peacoat og kan kjøpes de fleste steder når vinterklær kommer inn. Hvis du ønsker den lille detaljen med brun knapp er det ikke værre enn å sy på en når du kjøper jakken. Må også gi skryt til countryattire.com Jeg bestilte en jakke i large, og jeg var medium fant jeg ut i går. De har real-time kundeservice i chatform, og de forandret bestillingen min for et par minutter siden. Fantastisk. Lenke til kommentar
fkm Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Country attire er en utrolig bra butikk ja! Har bare hatt gode erfaringer med å bestille derfra, og det har etterhvert blitt en del bestillinger. Lenke til kommentar
thrice Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Tror nok det blir flere jakker derfra ja. For meg betyr god servie alt. 1 Lenke til kommentar
Henrik C Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Jeg har ikke bestilt enda, men det skal jeg gjøre etter at jeg blir ferdig med å flytte. Sendte dog en mail om størrelser, hadde prøvd en annen Barbour-jakke og lurte på hvordan det ville passe med en annen modell, og da fikk jeg svaret som jeg postet her i tråden. Det tok under 24 timer på mail, og når jeg la noe i handlekurven som jeg aldri bestilte kom det en hyggelig mail som lurte på om noe var galt, siden jeg ikke bestilte. Det virker som de bryr seg veldig om kundene sine, og selv om jeg kan spare en hundrelapp på å bestille fra eBay så er den servicen verdt så mye mer. Lenke til kommentar
thrice Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Country attire er en utrolig bra butikk ja! Har bare hatt gode erfaringer med å bestille derfra, og det har etterhvert blitt en del bestillinger. Hvilken størrelse i dressjakke bruker du til vanlig? 52? Lenke til kommentar
Kavinsky Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Jeg lurer på å bestille Liddesdale i XS fordi jeg vil ha den litt slim, for jeg er ikke interessert i kragen på Preppy Liddesdale. Men må få prøvd både S og XS før jeg tar sjansen. Waka Waka ey ey Lenke til kommentar
fkm Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Country attire er en utrolig bra butikk ja! Har bare hatt gode erfaringer med å bestille derfra, og det har etterhvert blitt en del bestillinger. Hvilken størrelse i dressjakke bruker du til vanlig? 52? 50 Jeg lurer på å bestille Liddesdale i XS fordi jeg vil ha den litt slim, for jeg er ikke interessert i kragen på Preppy Liddesdale. Men må få prøvd både S og XS før jeg tar sjansen. Waka Waka ey ey Jeg har Liddesdale i Small, bare husk på å si fra når vi skal ha tartardate, så kan du prøve den. Lenke til kommentar
Kavinsky Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Jepp, jeg tenker meg slutten av aug./starten av sep. Lenke til kommentar
Gjest Slettet-oVjeg2q2Tk Skrevet 8. august 2010 Rapporter Del Skrevet 8. august 2010 Jeg er på utkikk etter en allværsjakke til vinteren, gjerne parkas. Stilmessig er jeg nok et stykke fra dere mer stilfullt kledde, og jeg går gjerne i fargede bukser osv. så trenchcoat og andre mer elegante plagg er nok ute av bildet. Stilmessig ligger jeg nærme denne lille luringen: http://thegiant.blogg.no/ Noen som har noen forslag til jakker og farger som kan passe til en slik stil? Har sett litt på noen Woolrich jakker, men de er ganske dyre. Vil helst ikke betale mer enn 3500 kr, med mindre det er noe veldig spesielt! Takker for hjelp! Lenke til kommentar
Noburu Skrevet 9. august 2010 Rapporter Del Skrevet 9. august 2010 (endret) Noen som vet omtrent hva Timberland-boots (type dette eller dette) koster? Vil ha et par brune til høst/vinteren :| Tenker jeg får lagt opp sommerens handleturer til bildetråden i morgen Endret 9. august 2010 av Noburu Lenke til kommentar
PatSharpX Skrevet 9. august 2010 Rapporter Del Skrevet 9. august 2010 Tipper koster mellom 1200-1700,- Det er jo Timberland butikk i Bogstadveien så du kan jo høre innom der når de får det inn. Lenke til kommentar
Noburu Skrevet 9. august 2010 Rapporter Del Skrevet 9. august 2010 Takk Blir nok en tur dit når høst/vinterkolleksjonene har kommet til butikker, then Lenke til kommentar
Nash Skrevet 9. august 2010 Rapporter Del Skrevet 9. august 2010 Chelsea Booten ser fin ut, trenger også et par høstsko. Lenke til kommentar
