Skyeila Skrevet 29. september 2012 Del Skrevet 29. september 2012 (endret) Hallo! Jeg er på utkikk etter Stasjonær Gaming PC. (Uten skjerm). Har en liste over oppsettet fra komplett. Prisen trengs ikke å diskuteres. Så her kan man gå med på alt. Så fyr løs hvis dere har noen forslag til et bedre setup. Kabinett kan kjøres med vankjøling / vifte. Takker på forhånd. Her er listen så langt : Gamingmatte, Hybratek overflate 1.00 575386 APC Back-UPS ES Power-Saving 700VA Data/DSL protection, 8 Outlet, 230V CEE 7/7 1.00 489882 Corsair Obsidian 800D Big Tower Sort Vifter: 1x 140mm Front, 1x 140mm Bunn, 1x 140mm Ba 1.00 657696 XFX ProSeries Black Edition 1250W PSU ATX 12V V2.31, 80 Plus Gold, Modular, 8x 6+2pin PC 1.00 648702 Intel® Core i7-3960X Extreme Socket-LGA2011, Six Core, 3.3Ghz, 15MB, Boxed, no 1.00 635806 Corsair H100 Hydro Series CPU Kjøler Socket 775/1155/1156/1366/2011, AM2/AM2+/AM3, 2600 1.00 745112 ASUS RAMPAGE IV EXTREME, Socket-2011 E-ATX, X79, 8xDDR3, 5xPCIe(3.0)x16, CFX&SLI, SATA6 1.00 745707 Corsair Dominator GT DDR3 1866MHz 32GB Kit w/4x 8GB XMS3 DHX+, CL9-10-9-27, for Core i7, 1.00 745707 Corsair Dominator GT DDR3 1866MHz 32GB Kit w/4x 8GB XMS3 DHX+, CL9-10-9-27, for Core i7, 1.00 751571 Gainward GeForce GTX 690 4GB PhysX CUDA PCI-Express 3.0, GDDR5, DVI-D+2xDVI-I, mini-Displa 1.00 751571 Gainward GeForce GTX 690 4GB PhysX CUDA PCI-Express 3.0, GDDR5, DVI-D+2xDVI-I, mini-Displa 1.00 649393 Kingston Card Reader USB 3.0 CF I/II,SD, SDHC, SDXC, UHS-I, MicroSDHC/SDXC m.m 1.00 742184 Plextor Blu-Ray Writer PX-B950SA SATA, BD-R:12x, DVD±R:16x, Cyberlink BD Suite, 3D 1.00 742184 Plextor Blu-Ray Writer PX-B950SA SATA, BD-R:12x, DVD±R:16x, Cyberlink BD Suite, 3D 1.00 750727 Kingston HyperX 3K SSD 480GB 2.5" SATA 6 Gb/s (SATA3.0), 540MB/450MB/s read/write, S 1.00 753050 OCZ SSD Agility 4 Series 2.5" 512GB SATA 6 Gb/s (SATA3.0), 400MB/400MB/s read/write, I 1.00 752850 OCZ SSD Vertex 4 Series 2.5" 512GB SATA 6 Gb/s (SATA3.0), 560MB/410MB/s read/write, I 1.00 653074 Seagate Barracuda® 3TB SATA 6Gb/s (SATA 3.0), 64MB Cache, 7200RPM, 3.5" 1.00 752266 ASUS Xonar Phoebus PCIe-x1, 118dB SNR, Headphone Amplifier, EMI Shiel 1.00 518762 Western Digital Elements Desktop 1TB Endret 29. september 2012 av Skyeila Lenke til kommentar
iHenrikH Skrevet 29. september 2012 Del Skrevet 29. september 2012 (endret) 64GB RAM? Schvett! Hadde ikke hatt noe i mot at du sendte den til meg Endret 29. september 2012 av iHenrikH 1 Lenke til kommentar
Simkin Skrevet 29. september 2012 Del Skrevet 29. september 2012 (endret) 2X GTX690 du skal kjøre det på hvor mange skjermer? 3960X, bortkasta penger, kjøp heller 3930K. også skal du ha 2 X 512Gb SSD? hahaha.. er du seriøs? Det er ingen vits å gå total amok med penger, når man kan spare en del tusen, å få samme ytelse. Det er nesten, så jeg tar innlegget ditt useriøst Endret 29. september 2012 av FiveInline 2 Lenke til kommentar
otl Skrevet 29. september 2012 Del Skrevet 29. september 2012 (endret) Men hva med å legge til en bluray brenner, ssd og litt ram kanskje? Hva i alle dager skal en komme med her da? Må jo være en spøk? Men ville hvertfall byttet ut den h100'en da Endret 29. september 2012 av otl 1 Lenke til kommentar
moby_duck Skrevet 29. september 2012 Del Skrevet 29. september 2012 Ja ja, har man penger så er det vel ikke noen grunn til å ikke bruke dem Anbefaler 3x 670 framfor 2x 690. Skal du ha høyeste kvalitets strømforsyning, så ville jeg heller ha valgt Corsair AX 1200i. 64GB RAM er unødvendig. Alt over 16GB er unødvendig med mindre du bygger en server-PC. 3930k er et billigere valg enn 3960X, men med samme ytelse. Lenke til kommentar
Skyeila Skrevet 29. september 2012 Forfatter Del Skrevet 29. september 2012 (endret) Mange bra tilbakemeldinger! Bluray blir byttet + kanskje h100. Flere tips? Endret 29. september 2012 av Skyeila Lenke til kommentar
Simkin Skrevet 29. september 2012 Del Skrevet 29. september 2012 Ja, er du i det hele tatt seriøs? Lenke til kommentar
Skyeila Skrevet 29. september 2012 Forfatter Del Skrevet 29. september 2012 Da har jeg byttet ut litt. Til bedre strømforsyning legger dette I listen snart. Jada Five, det er ett godt prosjekt. Men det skal settes sammen. :-) Lenke til kommentar
Simkin Skrevet 29. september 2012 Del Skrevet 29. september 2012 Ok, greit Hvor mange skjermer skal du ha? mtp 2 X GTX 690 1 Lenke til kommentar
iHenrikH Skrevet 29. september 2012 Del Skrevet 29. september 2012 Du kan sikkert klare deg "fint" med 32GB RAM, samt at du kan nok ta vekk noen SSD Disker, da du muligens ikke trenger så mye? :-) Villig til og forklare oss prosjektet, høres stort og interessant ut! 1 Lenke til kommentar
LMH1 Skrevet 29. september 2012 Del Skrevet 29. september 2012 Selv KINGSTON HyperX Blu/8GB 1600MHz DDR3 blir jo ennå rimeligere å kjøpe flere av. Så må man ha det nyeste er det nok mere lønnsomt. Ellers er jeg enig at mye her er temlig bortkastet penger. Noctua NH-D14 CPU Kjøler Socket 775/1155/1156/1366, AM2/AM2+/AM3, 1300 RPM, 110,3 m³/h, 19,8 dBA bør kjøpes i løp av søndag for å få denne til 399 kr. 1 Lenke til kommentar
Skyeila Skrevet 29. september 2012 Forfatter Del Skrevet 29. september 2012 (endret) Veldig bra. Er enig pga det er veldig stort kabinett. Så det er nødvendig med vankjøling helst for at det skal være best for komponenter. Skal skifte ut H100. Men til hva? PC skal kjøres opp mot en monitor. Men også opp til 3 skjermer. Som krever litt ekstra. Listen blir oppdatert snart når jeg får alt på plass. Dette er veldig bra oppsett, og blir enda bedre med gode forslag fra dere! Endret 29. september 2012 av Skyeila Lenke til kommentar
otl Skrevet 29. september 2012 Del Skrevet 29. september 2012 Nok vram? ville valgt 680 4gb eller 7970 1 Lenke til kommentar
Skyeila Skrevet 29. september 2012 Forfatter Del Skrevet 29. september 2012 (endret) Driver å setter sammen Alienware Aurora for å se likheten. Deres kabinetter er utrolig kult men får ikke gjort alle modifications. Endret 29. september 2012 av Skyeila Lenke til kommentar
PgUp Skrevet 29. september 2012 Del Skrevet 29. september 2012 Tror ikke dette er seriøst, med mindre det er 14åringen til røkke ellernoe. Lenke til kommentar
Skyeila Skrevet 29. september 2012 Forfatter Del Skrevet 29. september 2012 (endret) Her er en ferdig liste av Alienware FARGEVALG Alienware Aurora ALX Matte Black 875W-kabinett redigere PROSESSOR Intel® Core™ i7-3960X (Six Core Extreme, 15MB Cache Overclocked up to 4.2Ghz) OPERATIVSYSTEM Windows® 7 Professional, 64-biters, Norsk GRAFIKKORT 4GB NVIDIA GeForce GTX 690 Grafikkort MINNE 32 768 MB (4 x 8 GB) 1600 MHz Quad tokanals DDR3 HARDDISK 512GB SSD + 1TB SATA 6Gb/s (7200RPM) 32MB Cache EKSTRA HARDDISK 2 TB – SATA-III, 7200 o/min, 32 MB hurtigbuffer OPTISK(E) STASJON(ER) 8X Blu-Ray RW (Blu-Ray, DVD, CD read & write) LYDPROGRAMVARE Integrated HDA 7.1 Dolby Digital capability TRÅDLØS TILKOBLING Kombinasjonsadapter med 802.11n Wi-Fi og Bluetooth 2.1 EDR USB, Europa DISKETT- OG MEDIESTASJONER Alienware 19-i-1-mediekortleser Endret 29. september 2012 av Skyeila Lenke til kommentar
moby_duck Skrevet 29. september 2012 Del Skrevet 29. september 2012 (endret) Ikke glem operativsystem, da! Du trenger forresten Win7 Professional, Enterprise eller Ultimate når du har 64GB RAM. Forresten, er det mulig å ta screenshot av handlelisten i stedet for å kopiere og lime inn all teksten? Endret 29. september 2012 av moby_duck 1 Lenke til kommentar
Skyeila Skrevet 29. september 2012 Forfatter Del Skrevet 29. september 2012 Jepp det skal jeg ordne. Kjøre Pro/ultimate. Det blir den fra komplett, med litt endringer av specs. Pga tips fått av dere. Laster opp screenshot istedenfor. Lenke til kommentar
moby_duck Skrevet 29. september 2012 Del Skrevet 29. september 2012 Komplett er egentlig ganske dyr sammenlignet med andre nettbutikker. Når du skal bruke så mye på PC, så bør du sjekke prisguide.no først. Du kan sikkert spare noen tusener ved å velge riktig(e) nettbutikk(er). 1 Lenke til kommentar
