Polere vannblokker
Det gjør han ihvertfall ikke da klarlakk ville ha redusert kjøleevnen betraktelig.
Man lakker jo ikke undersiden av blokken (den som er i kontakt med CPU/VPU) og kjøleevnen blir ikke reduser betraktelig fordi det er vannet som flytter varmen. Det hadde vært anderledes hvis det hadde vært en kjøleribbe..
Hei
På denne siden: http://www.zerofanzone.co.uk/projects.asp?...iquidgf3&page=3 er det forklart hvordan det gjøres.
Her er et utdrag
Once this test had been passed the block was filed clean, and finished as outlined below.
1. I use Wet & Dry, (wet), starting at about 180 grade and going down to 1200 grade with various grades in between as required. I do this with the Wet & Dry sheet on a flat surface, (glass is good), and move the block on the Wet & Dry, similar to lapping.
2. When it is smooth with the final wet & dry grade, I use T-Cut colour restorer, (designed for use on car paint that has gone dull or tarnished). Once happy all scratches are removed it’s finished with car polish, (Auto Glym Silicon Resin polish), for that deep shine. Both of these are also done with a cloth flat on the glass and moving the block back and fourth.
3. Once I'm happy with the finish and it is ready to install, (wont be handled any more), I use white spirit or brake cleaner to remove any polish residue so it can be sprayed with clear cellulose lacquer to prevent the shiny metal tarnishing, This needs to built up in very thin coats initially or it will "ball", "fish eye", or "run" on shiny metal. When hard this can be polished up carefully and as long as it is not scratched off the copper will look good and shiny for ages.
Mvh
Slinky
Trodde det var det duden sa jeg...
vannen flytter varme, det er riktig, men varmen må komme til vannet også!! Varmen går opp i kobberet og så til vannet!
Emm, tror du de har tenkt å lakkere inne i vannblokka kanskje? tenk logisk!
Har lite å si ettersom om vannet flytter varmen! (som mange andre har sagt)
