Ravniboy Skrevet 16. september 2012 Del Skrevet 16. september 2012 Hvorfor blir snørr grønt når man er syk? Og hvorfor er det så mye av det? 1 Lenke til kommentar
Mannen med ljåen Skrevet 16. september 2012 Del Skrevet 16. september 2012 Have you ever blown your nose and found that your snot was a really bright, gross, green-yellow color? Most of the time snot is just clear, but sometimes it will be green or yellow, particularly if you’ve been sick. (YUCK!) The green or yellow color of snot is usually caused by certain helpers that your body uses to fight off viruses or bacteria. The name for these infection-fighting helpers is “neutrophils,” and it’s the iron in a special enzyme used by the neutrophils to fight off your germs that is usually the source of your snot’s weird, gross color! The color of your snot does not necessarily indicate how sick you are – really green snot doesn’t necessarily mean you’re really sick, and clear snot doesn’t necessarily mean you aren’t sick. If your snot is a color that worries you or if you’re just not feeling well, the best thing to do is ask your doctor about it. And remember: It might SNOT be pretty, but your green or yellow snot is probably just a sign that your body is helping you get better quickly! http://www.whyzz.com/why-is-snot-green Lenke til kommentar
