Bose AE2i på PC
asle12
And they're designed with extra functionality that makes them more versatile than ever. An inline microphone and remote enable hands-free talking on your iPhone and control over various music functions on iPhone, iPod and other Apple products.
only idevices? vet ikke. kanskje derfor.
Edit: Leste litt mer
Can the The Bose® AE2i mobile headset be used with a PC Computer (i.e. are there issues with the jack)?
Answer 1:
The Bose AE2i is a special version of these headphones designed specifically for use with the iPhone. The microphone onboard will not work with most PC’s which utilize a separate jack for microphone-in and Headphone-out. The volume controls are also meant for the iPhone and will not work with any functions on your computer. For the best experience listening on a PC we strongly recommend the standard AE2 headphones instead.
Thank you for the question!
Thank you Apple! xD
Endret av nipton
