USB til Steelseries Siberia v2
Hallo! Bruker mitt Siberia v2 headset til pc, men vil bruke den også på ps3'n (kjøpte ikke den versionen for ps3) Finnes det en måte å koble den til ps3 så jeg kan bruke micen? (usb, ny ledning?)
Får lyd siden jeg har tatt den ene ledningen (jackkabel hvis det er det kalles) til tvn, men er to ledninger/jackkabler så må velge 1
http://faq.steelseri...laystation+3%3F
Can I connect my SteelSeries USB headset to a Playstation 3?
Yes but unfortunately the interface with the PS3 is a bit complicated for a standard headset. Plugging in the headset using the USB card into the PS3 will allow you to use your microphone, but the headset will not output sound. Because the PS3 does not output sound to the headset (outputs through the TV) the headset must be connected to a TV headphone jack in addition. Here's a breakdown of what the setups would look like:
To use your microphone only: Headset -&--#62; USB card -&--#62; PS3
To use your sound only: Headset -&--#62;3.5mm green cable (sound) -&--#62; headphone jack OR into RCA splitter -&--#62; RCA jacks
To use both microphone and sound:
3.5mm red (microphone) -&--#62; USB card -&--#62; PS3
3.5mm green (sound) -&--#62; 3.5mm extension cable -&--#62; TV headphone jack
This setup will have the two separate plugs from the headset itself going to separate inputs.
Endret av nipton
