vebbiii Skrevet 8. august 2012 Skrevet 8. august 2012 (endret) Hei. Jeg skal lage et program med opplasting til en bildedatabase, der data er lagret som en longblob i databasen. Såvidt jeg kan se, fungerer det meste,utenom at $data = file_get_contents($_FILES['image']['name']) blir NULL, og jeg skjønner ikke helt hvorfor.. Ville satt pris på om noen kunne tatt en titt på programmet. Her er koden: DBConnect.php <?php $db_host = 'x'; $db_user = 'x'; $db_pwd = 'x'; $database = 'imagetest'; $mysqli = new mysqli($db_host, $db_user, $db_pwd, $database); if ($mysqli->connect_error){ die("Connection failed". $mysqli->connect_error); } ?> upload.php <html> <head> </head> <body> <h1>Last opp bilde</h1> <form action="process.php" method="POST" enctype="multipart/form-data"> <label>Title: </label> <input type="text" name="title" id="title"><br> <label>Photo</label> <input type="file" name="image" id="image"/><br><br> <input type="submit" value="upload"> </form> </body> </html> process.php <?php require_once("DBConnect.php"); require_once("DBQuery.php"); $db = new DBQuery(); if($_SERVER['REQUEST_METHOD'] == 'POST') { $title = $_POST['title']; if($title == '') { $msg = 'Error: No title name'; } else { if(isset($_FILES['image'])) { $ext = pathinfo($_FILES['image']['name'], PATHINFO_EXTENSION); $acceptedFiles = array("pdf", "jpeg", "jpg", "png", "gif"); $acceptMimeType = false; foreach($acceptedFiles as $i) { if($ext == $i) { $acceptMimeType = true; } } if(!$acceptMimeType){ $msg = 'Error: Unknown file format'; } if(!isset($msg)) { $data = file_get_contents($_FILES['image']['name']); $db->insertPicture($title, $data); $msg = 'Success: Image uploaded.'; } } } } echo $msg; echo '<br><br>'; ?> <a href="index.php">Tilbake</a> DBQuery.php <?php require_once ("DBConnect.php"); class DBQuery{ function __construct() { } public function insertPicture($title, $data) { $query = "INSERT INTO images(title, data) VALUES (?,?)"; if($stmt = $mysqli->prepare($query)) { $stmt -> bind_param(1, $title); $stmt -> bind_param(2, $data); //$stmt -> send_long_data(0, $data); $stmt -> execute(); } } function deletePicture($id){ } function viewPicture($id){ } function viewAllPictures(){ } } Ellers er jeg åpen for tips ellers, med tanke på at det kun er et par uker siden jeg begynte med php. Endret 8. august 2012 av vebbiii
BlueEAGLE Skrevet 8. august 2012 Skrevet 8. august 2012 Du vil ikke ha bildedata i databasen. Det kan være at du tror du vil ha det, men egentlig så vil du ikke det. Når det er sagt så er $_FILES['x']['name'] det originale filnavnet, men fildataene finner du med file_get_contents($_FILES['x']['tmp_name']); Dette er fordi at filen blir lagret med et midlertidig navn på serveren for å unngå at to filer med samme navn lastet opp "samtidig" overskriver hverandre. ...og du vil virkelig ikke ha fildata i en database. Se forøvrig resten av matrisen her: http://www.php.net/manual/en/features.file-upload.post-method.php
vebbiii Skrevet 10. august 2012 Forfatter Skrevet 10. august 2012 Takk, det funket Angående lagring av bilder som binær data direkte i databasen, så burde jo dette i utgangspunktet være det samme som å lagre URL-en til bildet i filsystemet. Jeg er klar over at det er visse andre forskjeller også, f.eks: - Det kan være noe mer ressurskrevende, og øke forsinkelsen til andre query's(ikke noe stort problem for min del) - Bildet vil i utgangspunktet ikke cache-s i browseren(men dette kan løses ved koding) - Enkelte webhoster tillater ikke bruk av binær data i DB(Ikke relevant for min del) Hovedgrunnen til at jeg gjør det på denne måten her er coherency og lettere backup. Ift backup vil alt ligge lagret i en enkelt fil osv, mens ved coherency vil jeg unngå at enkelte brukere sletter bilder direkte i filsystemet, mens linken fortsatt ligger i databasen, altså at datastrukturen blir korrupt. Dog, så er dette fortsatt den første bildedatabasen jeg lager, så det er selvsagt godt mulig jeg oppdager at det ikke er en god løsning likevel. Men jeg er veldig interessert i å høre andre argumenter for eller mot en bildedatabase
TheClown Skrevet 10. august 2012 Skrevet 10. august 2012 Se for deg at du lagrer 10 bilder på 10 Mb i databasen, er du klar over hvor mye informasjon det kommer til å tilsvare i tabellene dine og hvor tregt det kommer til å gjøre spørringene? Antar du kommer til å møte flaskehals ila få bilder. Det er INGEN som gjør dette på denne måten, og med god grunn!
TheClown Skrevet 10. august 2012 Skrevet 10. august 2012 Du sier det er mer eller mindre det samme, men dette stemmer ikke. Å sammenligne en relativ URL med tusen linjer binær data er så langt unna tilsvarende som det er mulig å komme. Det kan hende det finnes noen positive sider ved å gjøre det på denne måten, men de negative er store at det ikke utligner vekta overhode. Gjør som har blitt foreslått, eller utvikle ditt eget databasesystem, fordi dagens kommer neppe til å takle all lagringen etter en liten stund.
vebbiii Skrevet 11. august 2012 Forfatter Skrevet 11. august 2012 .. så burde jo dette i utgangspunktet være det samme.. Du sier det er mer eller mindre det samme, men dette stemmer ikke. Å sammenligne en relativ URL med tusen linjer binær data er så langt unna tilsvarende som det er mulig å komme. Det kan hende det finnes noen positive sider ved å gjøre det på denne måten, men de negative er store at det ikke utligner vekta overhode. Gjør som har blitt foreslått, eller utvikle ditt eget databasesystem, fordi dagens kommer neppe til å takle all lagringen etter en liten stund. Jeg sa ikke at det var det samme, men at det strengt tatt er samme dataen du henter frem, og at det derfor ikke burde være en betydelig forskjell. Uansett, det er mer eller mindre et prosjekt for å se hvordan ytelsen blir i praksis, egentlig mest for nysgjerrighetens del
BlueEAGLE Skrevet 12. august 2012 Skrevet 12. august 2012 Du sier det er mer eller mindre det samme, men dette stemmer ikke. Å sammenligne en relativ URL med tusen linjer binær data er så langt unna tilsvarende som det er mulig å komme. Dette er en sannhet med modifikasjoner. Hvis du har et filsystem som er optimalisert for store filer så vil du ikke ha en nevneverdig ytelsesdegradering for datatilgang så lenge tabellene er fornuftig formgitt. Den største grunnen til å ikke lagre fildata i en database er at man mister fleksibilitet til å gjøre operasjoner på dataene igjennom rutiner som forventer at bildene er lagret som en fil. Dette kan typisk være batch-verktøy. En annen grunn er at databasebackup ikke er differensiell og en fil som er lagret en gang vil bli tatt backup av gjentatte ganger. Hvis den ligger i et filsystem så vil den bli tatt backup av en gang. 1
