iPhone på RT-56U WiFi
Min iPhone (4s) finner ikke WiFI på Asus RT-56U. iPad-en, Apple TV, laptops etc. finner derimot fram.
Forslag til hva som kan være feil?
I had the same problem, in your wireless device you can select (airport utility) you can select the radio mode in order for your apple I phone to work try to set it to 802.11n and select the 802.11b/g compatible that should do the trick
  • 1 måned senere...
Where's the airport utility? How do I set 802.11n and 802.11b/g. I can only choose between, n, g, mixed etc.
Jan:
Kanal er Auto.
Endret av cs_
