Hva kommer Apple til å lansere på mandag?
Mange som misforstår hva Retina Display er. En relativ god forklaring finnes i wikipedia.
The screen is marketed by Apple as the "Retina Display", based on the assertion that a display of approximately 300 ppi at a distance of 12 inches (305 mm) from one's eye, or 57 arcseconds per pixel[42] is the maximum amount of detail that the human retina can perceive.[43] With the iPhone expected to be used at a distance of about 12 inches from the eyes, a higher resolution would allegedly have no effect on the image's apparent quality as the maximum potential of the human eye has already been met.
This claim has been disputed. Raymond Soneira, president of DisplayMate Technologies, said in an interview with Wired magazine, that the claims by Jobs are something of an exaggeration: "It is reasonably close to being a perfect display, but Steve pushed it a little too far". Soneira stated that the resolution of the human retina is higher than claimed by Apple, working out to 477 ppi at 12 inches (305 mm) from the eyes, or 36 arcseconds per pixel.[44]
However, Phil Plait, author of Bad Astronomy, whose career includes a collaboration with NASA regarding the camera on the Hubble Space Telescope, responded to the criticism by stating that "if you have [better than 20/20] eyesight, then at one foot away the iPhone 4's pixels are resolved. The picture will look pixellated. If you have average eyesight, the picture will look just fine".
Dvs at en bærbar på 14'' hvor den normale synsavstanden er 610 mm (61 cm) har samme "arcsekund" verdi når skjermen har en horisontal oppløsning på 1920 piksler og etter Apple sin definisjon er det et "Retina Display". Derfor vil spørsmålet om en skjerm er "Retina Display" være bestemt av Apple sin definisjon av typisk avstand mellom øye og skjerm. Sier Apple at det er 610 mm for en MacBook 13,3'', så holder det med 1920 oppløsning. Definere de typisk avstand til 450 mm, så må man ha 2560 horisontal oppløsning.
Så derfor trenger man ikke nødvendigvis 4 dobling av oppløsningen på paneler for å kunne lansere "Retina Display".
  • Liker 3
Gleder meg til mandagen, håper at det blir lansert "retina" macbooks.
Er lei lav oppløste skjermer. Hvis Apple starter med dette vil flere følge samme trend.
Hadde også vært fint med en ny iPhone lansering, ikke at dette skjer denne gangen men. Akkurat nå leverer HTC og Samsung bedre telefoner. (IMO). Trenger en iPhone med gjerne 4.7" og quadcore, mer ram og nytt tynnere og lettere design. Glass er fint, men det veier for mye.
og hvis Apple faktisk våger å åpne opp API-en for tredjepartsutviklere kan vi forvente mye moro fra den lille boksen i en nær framtid.
Noe annet vil være som å kjøre bil med håndbrekk på.
Man kan være enslig og innovativ for alle andre, eller man kan sørge for at alle andre kan være innovativ for en selv. :)
  • Liker 3
"Hva kommer Apple til å lansere på mandag"
Akkurat det driter jeg i....
Begynner å bli rimelig lei av slike artikkler..
Men allikevel tar du deg tid til å klikke inn i denne tråden for å trolle.
  • Liker 9
Gjest Slettet-qfohT7
Er spent på MacBook Pro. Hvis denne blir lansert med høyoppløst skjerm blir det kjøp umiddelbart. Den gamle laptopen trenger sårt utbytting snarest..
