Hva skiller lag på tabellen i Spania?
Ducki
Hva er rekkefølgen for hva som skiller lagene med lik poengsum på tabellen i Spansk fotball? Er det eksempelvis;
1. Poengforskjell
2. Innbyrdes oppgjør
3. Målforskjell i innbyrdes oppgjør
4. Total målforskjell i liga
Eller?
http://en.wikipedia....petition_format
Teams are ranked by total points, with the highest-ranked club at the end of the season crowned champion. If points are equal between two or more clubs, the rules are:
If all clubs involved have played each other twice:
If the tie is between two clubs, then the tie is broken using the head-to-head goal difference (without away goals rule)
If the tie is between more than two clubs, then the tie is broken, using the games the clubs have played against each other:
a) head-to-head points
b) head-to-head goal difference
c) head-to-head goals scored
If two legged games between all clubs involved have not been played, or the tie is not broken by the rules above, it is broken using:
a) total goal difference
b) total goals scored
If the tie is still not broken, the winner will be determined by Fair Play scales. These are:
yellow card, 1 point
doubled yellow card/ejection, 2 points
direct red card, 3 points
Suspension or disqualification to coach, executive or other club's personnel (outside referee decisions), 5 points
Misconduct of the supporters: mild 5 points, serious 6 points, very serious 7 points
Stadium closure, 10 points
If the Competition Committee removes a penalty, the points are also removed
If the tie is still not broken, it will be resolved with a tie-break match in a neutral stadium.
Endret av Solaar
