Min harddisk`s tragiske historie
Hei
Fant litt info som kanskje kan være til hjelp:
Stop 0x0000007A or KERNEL_DATA_INPAGE_ERROR
The Stop 0x7A message indicates that a page of kernel data was not found in the paging (virtual memory) file and could not be read into memory. This might be due to incompatible disk or controller drivers, firmware, or hardware.
Frequently, the cause of this error can be determined from the second parameter, the I/O status code. Some common status codes are:
0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
0xC000009C, or STATUS_DEVICE_DATA_ERROR, indicates bad blocks (sectors) on the hard disk.
0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose data or power cables, a problem with SCSI termination, or improper controller or disk configuration.
0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination, defective storage controller hardware, or defective disk cabling, or two devices attempting to use the same resources.
Possible Resolutions:
Stop 0x7A can be caused by bad sectors in the virtual memory paging file, disk controller error, virus infection, or memory hardware problems. In extremely rare cases, depleted nonpaged pool resources can cause this error. If the first and third parameters are zero, the stack signature in the kernel stack is missing, an error typically caused by defective hardware. If the I/O status is 0xC0000185 and the paging file is on a SCSI disk, check for cabling and termination issues. An I/O status code of 0xC000009C or 0xC000016A indicates that the requested data could not be found. You can try to correct this by restarting the computer. If a problem with disk integrity exists, Autochk, a program that attempts to mark bad disk sectors as defective so that they are not used in the future, starts automatically. If Autochk fails to run, you can manually perform the integrity check yourself by following the instructions to run Chkdsk provided in "Stop 0x00000024 or NTFS_FILE_SYSTEM" earlier in this appendix.
Another cause of Stop 0x7A messages is defective, malfunctioning, or failed memory hardware, such as memory modules, Level 2 (L2) SRAM cache, or video adapter RAM. If you added new hardware recently, remove and replace it to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the system manufacturer to determine if the component has failed.
Check the hardware manufacturer's Web site for updates to disk adapter firmware or drivers that improve compatibility. Verify that your disks and controller support the same set of advanced features, such as higher transfer rates. If necessary, select a slower transfer rate if an update is not yet available. Consult your hardware or device documentation for more information.
Important[/color]You can install disk controller drivers not present on the Windows XP Professional operating system CD by responding to the following prompt shortly after starting Setup:
Press F6 if you need to install a third party SCSI or RAID driver.
Press F6, and when prompted, provide the appropriate storage controller driver (ATA or SCSI) supplied by the manufacturer.
The problem might also be due to cracks, scratched traces, or defective components on the motherboard. If all else fails, take the system motherboard to a repair facility for diagnostic testing.
Problems that cause Stop 0x7A messages can also cause Stop 0x77 messages. For more information about Stop 0x77 messages, see "Stop 0x00000077 or KERNEL_STACK_INPAGE_ERROR" earlier in this list.
Sjekk minne med memtest86: http://www.memtest86.com/.
Sjekk at du har de nyeste driverne for chipsettet på hovedkortet ditt.
Prøv et annet skjermkort (feil på skjermkort minne)
Prøv et annet hovedkort.
Good luck.
Etter å ha brukt Partition Magic til å formatere noen ganger ble hele harddisken fu*ka, med sector-, cluster- feil osv.
Anbefaler at neste gang du bestemmer deg for å formatere, så går du inn på microsoft sine sider å finner oppstartsdisketter til innstallasjon av XP uten auto-boot (er ikke sikker på om de samme funksjonene som finnes på diskettene finnes på Xp cd-en, da jeg ikke har innstallert med auto-boot fra cd-en). Disse oppstartsdiskettene (6 i tallet) formaterer, partisjonerer og gjør klart for en 'fresh install' av Windows XP.
(Frem til jeg byttet til oppstartsdiskettene fra MS brukte jeg òg et program som hette WD Lifeguard 2.8, som også formaterte og partisjonerte på et lavt nivå. Eneste var at dette programmet ikke kunne formatere i NTFS format, noe som gjorde at jeg fant en alternativ løsning (oppstartsdiskettene) etter jeg bestemte meg for å legge inn XP. Klarte heller ikke disker på over 127GB, men det var ikke et prob. da).
