Direct connect - erfaringer ??
Direct Connect SHDSL 512, Sør-Trøndelag. Trekk fra 1-2 ms grunnet lang nettverkskabel fra SHDSL-router til der jeg er nå (400 meter). Ikke så rask denne ser det ut som, men det var
jo endel routing underveis :!:
Ping har startet ...
PING 195.182.6.144 (195.182.6.144): 56 data bytes
64 bytes from 195.182.6.144: icmp_seq=0 ttl=51 time=75.843 ms
64 bytes from 195.182.6.144: icmp_seq=1 ttl=51 time=75.384 ms
64 bytes from 195.182.6.144: icmp_seq=2 ttl=51 time=78.267 ms
64 bytes from 195.182.6.144: icmp_seq=3 ttl=51 time=75.212 ms
64 bytes from 195.182.6.144: icmp_seq=4 ttl=51 time=74.761 ms
64 bytes from 195.182.6.144: icmp_seq=5 ttl=51 time=75.705 ms
--- 195.182.6.144 ping statistics ---
6 packets transmitted, 6 packets received, 0% packet loss
round-trip min/avg/max/stddev = 74.761/75.862/78.267/1.131 ms
Traceroute har startet ...
traceroute to 195.182.6.144 (195.182.6.144), 64 hops max, 40 byte packets
1 home.gateway (192.168.30.254) 1.224 ms 0.619 ms 0.395 ms
2 i162001.directconnect.no (82.148.162.1) 25.283 ms 20.727 ms 17.282 ms
3 vlan2646-ge.c1.hmgv.osl.no.nordhost.net (82.148.160.154) 40.790 ms 19.357 ms 16.189 ms
4 vlan158.msfc1.os1-oslo.teleglobe.net (80.231.90.45) 19.851 ms 15.309 ms 16.709 ms
5 if-1-0.core1.os1-oslo.teleglobe.net (80.231.90.1) 19.314 ms 14.971 ms 14.725 ms
6 if-5-1.core2.ad1-amsterdam.teleglobe.net (80.231.81.5) 56.606 ms 55.941 ms 52.500 ms
7 ge4-1-0-1000m.ar1.ams1.gblx.net (195.69.144.80) 54.341 ms 54.608 ms 50.637 ms
8 pos1-0-2488m.ar1.vie1.gblx.net (67.17.95.46) 73.069 ms 76.497 ms 75.160 ms
9 inode-telekommunikationsdienst.ge-2-0.ar1.vie1.gblx.net (146.82.33.218) 73.509 ms 75.478 ms 78.346 ms
10 self-gb-02-002.shuttle.vien.inode.at (62.99.171.66) 75.400 ms 73.918 ms 80.333 ms
11 85-124-188-219.sh-wien.inode.at (85.124.188.219) 76.092 ms 75.355 ms 78.383 ms
12 85-124-188-219.sh-wien.inode.at (85.124.188.219) 77.788 ms 78.372 ms 79.391 ms
Noen med DirectConnect som kan pinge 195.182.6.144? Takk :)
6047455[/snapback]
2Mbit SHDSL, utenfor Oslo.
Pinging 195.182.6.144 with 32 bytes of data:
Reply from 195.182.6.144: bytes=32 time=63ms TTL=51
Ping statistics for 195.182.6.144:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 63ms, Maximum = 63ms, Average = 63ms
Tracing route to 195-182-6-144.sms.at [195.182.6.144]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  SpeedTouch.lan [10.0.0.138]
  2    4 ms    3 ms    6 ms  i162001.directconnect.no [82.148.162.1]
  3    4 ms    4 ms    5 ms  vlan2646-ge.c1.hmgv.osl.no.nordhost.net [82.148.
160.154]
  4    4 ms    4 ms    9 ms  Vlan158.msfc1.OS1-Oslo.teleglobe.net [80.231.90.
45]
  5    4 ms    4 ms    4 ms  if-1-0.core1.OS1-Oslo.teleglobe.net [80.231.90.1
  6    38 ms    39 ms    44 ms  if-5-1.core2.AD1-Amsterdam.teleglobe.net [80.231
.81.5]
  7    39 ms    39 ms    39 ms  ge4-1-0-1000M.ar1.AMS1.gblx.net [195.69.144.80]
  8    62 ms    62 ms    62 ms  pos1-0-2488M.ar1.VIE1.gblx.net [67.17.95.46]
  9    62 ms    62 ms    62 ms  INODE-TELEKOMMUNIKATIONSDIENST.ge-2-0.ar1.VIE1.g
blx.net [146.82.33.218]
10    67 ms    62 ms    63 ms  self-gb-02-002.shuttle.vien.inode.at [62.99.171.
66]
11    63 ms    63 ms    63 ms  85-124-188-219.sh-wien.inode.at [85.124.188.219]
12    63 ms    63 ms    63 ms  195-182-6-144.sms.at [195.182.6.144]
Trace complete.
Fra Kr-sund med NGT... :cool:
Sporer rute til 195-182-6-144.sms.at [195.182.6.144]
1 8 ms <1 ms <1 ms 192.168.1.1
2 13 ms 13 ms 12 ms 1.80-203-113.nextgentel.com [80.203.113.1]
3 13 ms 13 ms 13 ms 217-13-0-161.dd.nextgentel.com [217.13.0.161]
4 20 ms 20 ms 20 ms 217-13-0-182.dd.nextgentel.com [217.13.0.182]
5 * 21 ms 20 ms 217-13-0-22.dd.nextgentel.com [217.13.0.22]
6 21 ms 20 ms 21 ms 217-13-6-194.dd.nextgentel.com [217.13.6.194]
7 20 ms 20 ms 21 ms ge0-3-0-103.ar1.OSL1.gblx.net [208.51.41.57]
8 61 ms 61 ms 60 ms pos1-0-2488M.ar1.VIE1.gblx.net [67.17.95.46]
9 61 ms 61 ms 61 ms INODE-TELEKOMMUNIKATIONSDIENST.ge-2-0.ar1.VIE1.g
10 61 ms 62 ms 61 ms self-gb-02-002.shuttle.vien.inode.at [62.99.171.
66]
11 61 ms 60 ms 61 ms 85-124-188-219.sh-wien.inode.at [85.124.188.219]
12 61 ms 61 ms 62 ms 195-182-6-144.sms.at [195.182.6.144]
Pinger 195.182.6.144 med 32 byte data:
Svar fra 195.182.6.144: byte=32 tid=63ms TTL=53
Svar fra 195.182.6.144: byte=32 tid=62ms TTL=53
Svar fra 195.182.6.144: byte=32 tid=61ms TTL=53
Takk skal dere ha! :)
Ser bra ut med den Oslolinja og NGT. Får 78-79 ms til den fra min BC-linje, så det er jo ikke så store forskjellen.
Svar fra 195.182.6.144: byte=32 tid=78ms TTL=53
Svar fra 195.182.6.144: byte=32 tid=77ms TTL=53
Endret av MrGlenn
Generelt så er NGT 5-10ms dårligere på ping enn Bluecom (jeg har testet begge herfra mot @EU). Dette skyldes at NGT har dårligere routing mot de fleste steder enn Telenor / Bluecom etc.
For min del så betyr det ikke all verden om jeg har 45 eller 50 i ping. Setter mere pris på 17Mbit kontra 4M eller 6M for samme pris...
En annen sak er at det er utrolig viktig hvor i Norge man bor. Bor man nær NIX (Oslo) vil man som regel alltid få lavere ping enn utkantene.
Med NGT har jeg 21ms til NIX & VG, mens B/C gir 17ms.
Om man har adsl, 2+ eller shdsl betyr lite eller ingenting. (inntil man belaster linja).
Svar fra 195.182.6.144: byte=32 tid=48ms TTL=52
1 <1 ms <1 ms <1 ms 10.0.0.1
2 3 ms 3 ms 3 ms 1.80-202-148.nextgentel.com [80.202.148.1]
3 3 ms 3 ms 3 ms 80-202-2-105.dd.nextgentel.com [80.202.2.105]
4 3 ms 3 ms 3 ms 80-202-2-170.dd.nextgentel.com [80.202.2.170]
5 7 ms 7 ms 7 ms 217-13-6-180.dd.nextgentel.com [217.13.6.180]
6 * 7 ms * 217-13-0-30.dd.nextgentel.com [217.13.0.30]
7 8 ms 7 ms 7 ms 217-13-6-197.dd.nextgentel.com [217.13.6.197]
8 7 ms 7 ms 7 ms so-5-0-0.ar1.OSL1.gblx.net [64.215.182.129]
9 47 ms 47 ms 48 ms pos1-0-2488M.ar1.VIE1.gblx.net [67.17.95.46]
10 48 ms 48 ms 47 ms INODE-TELEKOMMUNIKATIONSDIENST.ge-2-2.ar1.VIE1.g
blx.net [146.82.33.214]
11 47 ms 48 ms 47 ms self-gb-02-002.shuttle.vien.inode.at [62.99.171.
66]
12 48 ms 48 ms 48 ms 85-124-188-219.sh-wien.inode.at [85.124.188.219]
13 48 ms 66 ms 49 ms 195-182-6-144.sms.at [195.182.6.144]
2Mbit SHDSL, NGT, Krsand
Jeg har egentlig dårlige erfaringer med suport hos Direct Connect. Noen kjente av meg hadde ADSL fra dem (de bodde sentralt i Askim). Hastigheten og tjenesten var ikke noe å skryte av, de fikk bare halparten av det de skulle ha, og det var mye tull med ADSL modemet. Kundeservice lovte flere ganger at ting skulle fikses, men ingenting skjedde.
Endte med at jeg hjalp dem til å bytte til Tele2 (1,5Mbit). Det har fungert uten problemer i et par månder nå, og hastigheten er slik den skal være.
hittil er jeg meget misfornøyd, 03.00 på mandag til tirsdags natta kobla ngt ut linja mi pga dc.no skulle gi meg nett, de skulle på tirsdag da seneset ha nettopp vårt oppe til 17.00, enda ikke noe adsl her hos meg nå og sitter på DIALUP for å kunne betale regninger osv. på nettbanken...
på kundeservice var de bra til å hjelpe i starten, men når de ikke viste noe skulle de sende det til feilmelding så regna dem med at jeg får nett til uka...hipp hurra?:(
De fleste isp'er bruker forskjellige firmaer til å se på ledninger ja, bravida ++, det er vel også mulig at dc har linjer til en annen sentral, og de kan jo heller ikke vite hva nextgentel har brukt :)
F.eksempel har jeg snakka med 2 isp'er om linje til meg, den ene sier det er 1700 meter til sentralen og den andre 600, viste seg at den ene ikke hadde utstyr i sentralen som var nærmest .
wee, fikk adsl rundt 4 tiden idag, fikk tlf fra eltel eller hva det var om at de hadde funnet feilet før de skulle komme og så fikk jeg nett gett, deilig:)
hvor får jeg testa om jeg har 6000/600 linja som jeg er lovt?
Endret av Zaft
Bra det ordna seg da. Du kan jo teste her:
http://www.auditmypc.com/internet-speed-test.asp Denne virker veldig bra for meg.
Eller her:
http://www.dinside.no/php/art.php?id=91179
Evt. last ned TpTest fra http://www.tptest.se/ og kjør den. Veldig nøyaktig hos meg i alle fall.
:thumbup:
6129540[/snapback]
Endret av steveak
